UPDATE 7/9/11: The AC power fed relay has been replaced with a DC battery fed relay system as shown in step 10.
UPDATE: We have been selected as finalists in the microcontroller contest! Thank you for voting and rating. Thank you also for all the feedback on the safety of out relay system. We hope the new instructions are clear. We will be continually updating as we make progress on the new design.
Hello Everyone!
My name is Clover and I am in love with vascular plants and robots.
This summer I wanted to combine my two loves of plant science and engineering. Thus I am constructing my very own greenhouse in my backyard. I am an undergrad, and as any former student knows, this means I move around constantly, and I am not always around to take care of my vegetable garden. I love my plants but since I am moving back to school in July, and my family is unreliable, I need a way to make sure that they are taken care of. Enter Arduino!
I have constructed an automated watering and temperature system. This includes sensors that will turn the systems on only when needed. This is essential when the ever-changing New England weather demands some intelligence in watering and heating patterns.
This is my first project using an Arduino so I am using wonderful articles from MAKE and Instructables as very helpful templates. Already the Instructables, MAKE, and Ladyada blogs have been ridiculously helpful so, worry not biology nerds, you too can show the engineers just how awesome we are!
Remove these ads by
Signing UpStep 1Plant Science 101
Warning! Science...
Sources: Much of this information/ images came from Northeastern Univesity Professor Donald Cheney's Plant Science lecture and the textbook Botany which is linked in the more information section.
Greenhouses
There are a lot of reasons that I am building a greenhouse. Greenhouses are a really cool way to grow larger and healthier plants faster and artificially extend the growing season. Greenhouses work by using a transparent airtight cover to trap in light and moisture to create a mini- ecosystem that is separate from the environment around the greenhouse. Heat is generated both from the sun’s rays that penetrate the greenhouse but do not escape as well as the trapped heat given off by the plants during their biological processes such as photosynthesis. This results in a very fascinating microclimate. This general idea of a layer of material trapping in heat and increasing the climate below is why sometimes global warming is called “the greenhouse effect” by people who like to oversimplify complicated climate phenomena.
Greenhouses can be made of glass or plastic. They create a controlled microclimate that makes experiments and procedures such as grafting or tissue cultures easier to perform.
Plant Anatomy and Physiology
Vascular Plants (plants that have stems and roots) develop mostly from seeds (a lot of nonvascular plants like mosses and ferns develop from spores which work a little differently). A seed consists of three types of tissues. The epidermal tissue is the outer layer for protection against the elements. This is usually embodied in the hard seed coat (Think the hard shell around sunflower seeds). The middle layer is called the ground tissue. The ground tissue is where photosynthesis takes place. The vascular tissue is in the very middle of the plant body and is where nutrients and water are conducted and stored. The roots are the first thing to grow out of the seed. The roots are made up of the same tissues except on the tips of the root is a number of epidermal cells called the root cap that are made to die and be ripped apart as the root burrows through the ground. The roots provide water and nutrients to the plant. Sometimes nutrients can be stored in the roots such as in the case of root vegetables like carrots or turnips.
The stem of the plant grows from what is called the coteledon in the seed. Longitudal growth is initiated by the apical meristem which is the primary growth bud. Lateral meristems are responsible for making the plant larger in diameter. There are two structures called the auxillary buds that grow on both sides of the main meristem. In case the axial bud is cut off for some reason the surrounding auxillary buds take over and grow the plant in a new direction. This is how pruners reroute tree growth by cutting off certain branches.
NOTE ABOUT WEEDING: This anatomical knowledge is very useful when you are weeding- particularly with grass. Grass is a special category of plants called a monocot. With grass the meristem is on the bottom of the grass blade which is why it grows even if it is cut. So do not just rip out the grass blade but make sure you get at the root system too.
Gardening: Plant Nutrients
Even though most plants grow well with just old fasion dirt and water there are a lot of other things that they need to grow and produce good fruits. These are broken up into two catagories: Macronutrients which take up more then .5% of a plant's dry mass and Micronutrients which are only present in trace amounts. Some macronutrients that are essential for all plants are Nitrogen, Magnesium, and Sulfur . Sulfur is in proteins and vitamins. Magnesium is in the chloraphyll which are involved in photosynthesis. All of these are found in the soil. Plants are also about 45% Carbon which comes from the CO2 in the air and 45% Oxygen which comes from water and air. Some micronutrients that plants need are Boron, Chlorine, Manganese, Iron, Copper, and Zinc. All of those are naturally occuring in soil but the most important one is Iron. Iron deficiencies lead to a yellowing of the leaves. Fertilizers usually provide all the minerals needed for a plant to survive. The ratio of Nitrogen, Phosphorus, and Potassium are listed in that order on most fertilizer bags in ration form. For example: 10:20:10= ratio of N:P:K.
Photosynthesis
Photosynthesis is how plants turn sunlight into sugars. The chemical equation is 6CO2 +6H2O --> sunlight--> C6H12O6 +6O2. Photosynthesis happens in two stages: The dark and the light. First is the light stage where , as the name implies, the sunlight is needed. What happens is electrons are taken from the water molecule and excited in photosystem 2. Then the electrons are transported down what is called the electron transport chain. This chain is nothing more then a series of oxidation and reduction reactions that progressively bring the electrons down into a less excited state. Once the electrons hit photosystem 1 they are excited again and go down another smaller electron transport chain. While the electrons are moving from a more excited state to a less excited state they are also turning a substance called NADP+ (Nicotinamide adenine dinucleotide phosphate) into NADPH. This is used in the dark stage, also known as the calvin cycle. The Calvin Cycle is a series of modifications starting with a reaction with starting material RuBP (Ribulose bisphosphate) and Carbon dioxide using a series of enzymes and redox reactions. It is called a cycle because after the sugar is produced the starting material RuBP is again synthesized. For every round of the carbon cycle there is 1 sugar derivative output and 3ATP (the source of our life's energy). So it takes 6 rounds of the Calvin Cycle to create one glucose molecule. There are a lot of plants that utilize different variations of this cycle.
pH
Part of my experimentation is to come up with a low tec pH monitor for the soil. pH measures relative acidity by taking the log of the concentration of hydrogen molecules present. pH is measured on a 14 point scale with 1 being very acidic and 14 being very basic. Water is neutral or 7. I measured the acidity of my soil with an at home pH kit that I bough on amazon for $5. The acidity of my soil was about 6.5 which is perfect for the types of plants I am growing (strawberries, peas, basil, broccoli). If there is a problem with your plants and the fertilizer is fine I would suggest checking the pH.
Not criticising, just always curious how others do stuff in order to learn
Question for you about the moisture sensors. One nail was connected directly to +5V. And the other nail was connected to the Arduino analog pin (zero in your case) correct? In your video you can see how one nail has a red wire connected to it (I assume this goes to the Arduino). The second nail looks like it may have a black wire connected to it but it's not exactly clear. And you don't mention that it is getting power. You don't mention it in the video or describe it above, so I just wanted to make sure I understood how to do it correctly. Your diagram seems to show it is connected directly to power. Please confirm.
I love it. Can't wait to build my own. Great job!
I just noticed the swimming pool at the end of the video. You could put a fan/radiator in the Greenhouse and pump water from the pool to circulate between the radiator and pool.... heating the pool and cooling the greenhouse.
Oh, and -- got Aquaponics? ;-)
Thanks. :)
http://www.amazon.com/SainSmart-8-Channel-Relay-Module-Arduino/dp/B0057OC5WK
We used this relay from sparkfun:
http://www.sparkfun.com/products/100
It is activated by 5 volts and can handle 250 volts AC
Helga out
Hope that was the right reference.
Water is actually far less significant. I'm afraid this setup would cook the plants on the first sunny day.
I would like to see this controller applied to a 12'x 16' greenhouse with some AC fans to blow the heat down into undersoil Perforated Drainage Pipe.
That stores the heat in the ground and pulls in clean outside air the plants will suffocate without.
In thermal extremes, a misting system can be employed via a solenoid.
Just a minute of water pressure will give you four minutes of mist.
Water can be used for thermal mass as well. Combine the fan with a heat exchanger such as an automotive radiator. Pump the water from a reservoir (I'm using two 35 gallon rubbermaid trash cans) through the radiator using a 12/24v pump.
The water in my system typically fluctuates between 40 and 65 degrees F. Which translates into roughly 14500 Btu's of heat storage. Presently in the process of implementing a larger heat exchanger to get more BTUs... to keep the greenhouse above freezing at 7000 feet in January.
Meanwhile ambient air temps are managed at under 90 deg F in my 14x8 greenhouse - whereas without the heat exhanger, temps were well over 110 :-)
Build_it_Bob
Peace,
Clovercreature
I love how you came up w/ a green house and your love for plants!
I love your creativity and style for the birdhouse! (even tho it's not for birds)
You're awesome "Clover"!
I was going to save the pdf for future reading and maybe doing the relay thing next year but I noticed the wiring hazards. I didn't want to save the pdf and have anyone I know find it later and think the wiring was safe. Please, for your own safety, install, or have an electrician install a gfi at your power source. Your 110 wiring entering and exiting your outlet box should be protected from abrasion and tension as well as all the other forms of wiring abuse that come with a movable circuit. Inside the box, and what caught my eye, you're using stranded wiring on your outlet. Stranded is good in many cases and can be the safer bet where flexing is present in a wiring project but special connectors should be used on the ends to prevent things like....FROG HAIRS....
'But frogs don't have hairs!' you say?' You're right! Frogs don't have hairs and neither should your outlet wiring. All those loose strands of wire might appear innocent and safe but, with a little flexing, they can go in lots of directions and should a hot hair touch a neutral or ground hair, your focus will turn from plant science to plasma research in less than a second. Even with a gfi, you can generate an arc and plasma hot enough to turn clothes...and things like skin or fingers to charcoal in a fraction of a second. Plasma is a different state of matter that is fine on the sun or in a lab but not close to nice but unprotected living things such as your plants or yourselves.
You might ask an electrician about helping with the 110vac portion of your project. The rules and regulations those folks work with come from painful and deadly experience of earlier people and are the attempts of the industry to prevent or minimize the hazards of electrical power. Stranded wire, by the way, might not meet residential building code in many cities and towns.
Please protect yourself and those you care for, hopefully that includes everyone, and find an electrician friend to help with the power planning and wiring.
I do like the rest of the project, however. Thank you.
I am not sure why you would darken your wire ("tint") or deep fry it ("breaded")? You probably mean "tin" it as in cover with solder, and it is "stranded" not "braided".
Either way, if you do not have proper training, PLEASE call your local electrician to help you. it could save your family a trip to the morgue. Electricity is not to be played with. Even with a GFCI protecting you it can get hairy (especially if you went cheap on the GFCI and it is one of the bad non-protecting Chinese versions that get into residential construction sometimes).
Using the push in connectors on a switch or outlet will contain the stranded wires like a crimp terminator. That, however, isn't what we are talking about because it isn't what happened in this case.
A GFCI will not protect you from arc flash and won't trip on all power faults. It trips on hot neutral imbalance only. All other faults would fall back to the circuit breaker which is much slower than the GFCI. (Do you do your pm work on your circuit breakers?)
GFCI and circuit breakers will fail and are not a substitute for a the safest wiring job you can provide.
I particulary like the comments looking for low voltage solutions to this situation.
That's very good thinking and I think I'm going to look into that and try this.
Thanks, again, and good luck!
(estoy pensando en modificar los sensores de humedad por dos terminales de cobre ya que el salitre acabaría muy rápido con el galvanizado de los clavos) Gracias otra vez!
I think the point's been made adequately about the dangers of unruly electrons, but I'll reiterate all the same...please fix that.
There's a lot to be said for low voltage D.C. systems in this type of application as well. Easily adapted to solar. Less dangerous. Simpler to back-up for power outs. Not detracting, just throwin' it out there for further consideration.
Also thermal mass helps to buffer extreme temperature swings. Water vessels, piles or layers of rock, concrete - all work like giant thermal batteries.
I've built and used many different types of methods and houses, and even in New England you're apt to encounter problems with over heating. Swamp coolers, thermostatic vents, fans and earth tube ventilators are all potential solutions, but leaving your little terra-hut completely untended may produce some unwelcome surprises upon your return. Might want to check out a shade cloth depending on when you're going to be around and when you're not.
Again, great job...but what's with the lid? Even biology majors have to take history and math don't they?
What do you mean by lid?
Peace,
Clover
Peace,
Clover
what are you using to turn the water flow on an off on the hose? I've been trying to find a cheap solenoid valve for my project, but so far haven't found anything.
http://www.sparkfun.com/products/10456
Thank you very much for your comment!
Peace,
Clover
Peace,
Clover
I've favorited this and will be borrowing many details.
One thing i will change is the power source. The other comments about movable AC hold true (which could be fixed), but I'm looking at AC as being overkill also.
I just need a reliable DC power source, and for that a portable car charger would do (and would probably last 2 weeks or more on a full charge). [of course, solar is an option, but again the rule about getting things done.
My other planned changes are using metal conduit and a manual pipe bender. I have read that UV light will make plastic conduit brittle after a couple of years. I'll bend the pipe to fit INSIDE the soil box, inside 1 foot 1" plastic conduit "brackets" so it's anchored more and offers less chance of flexing at the base.
The walls of the greenhouse are only attached to the wooden frame with staples from a staple gun; so although the greenhouse is closed enough to keep in condensation and moisture, it still lets in a steady air supply.
Thank you for your comment and all those who responded below.
Amy, you are absolutely right. The door panel is not attached at the bottom even when it is velcrod, letting air in too.
Keep the comments rolling!
Peace,
Clover
