loading
Step 2: Build the Boxes...
Let's build these boxes!
It's really easy and you don't need a diagram. Let me tell you how to build one. Afterward, just repeat this process to build the others. Just be sure to secure the boards well since wet soil places a good bit of pressure on the walls of the box once it has been filled and is in use.
For the long sides:  Take two planks and lay them down on the sidewalk on top of and perpendicular to three or four short lengths of 2x2 or 2x4.  Make sure everything is square and aligned. The planks should be slid down to one end of the support beams. Screw it all together.  Repeat until you have two long side pieces.
For the short sides:  Have someone hold the two long sides up as they would be in the final position for installation. Take two short lengths of planking and fasten them with screws to each end.  When you are done you should have something that resembles my photo.
I chose to have the support beams extend upward to allow the use of string and fabric to protect and support my plants as they mature through various phases of their growing cycle.
<p>as someone with a bad back I had to go with raised bed gardens some time ago. Now with serious arthritis in hips knees and back I had to modify further and actually putting 30&quot; 4&quot;x4&quot; legs up through the corners and a good sturdy 2&quot;x4&quot; cross members underneath to support the weight. I've used a design like yours with stilts! Mine are 3'x6' with a trellis on the southern facing side for beans and berries. My next project is a couple of basic concrete forms to have narrow paths for my gardening trolley. This way I sit high with a straight back able to do what I love. </p><p>You have renewed my excitement for Spring! I spent all Winter laid up with a shattered knee from my other love...my motorcycle..</p>
<p>Thank you so much for taking the time to read the article and post a comment! I like your idea a lot better -- now I have got to try building one on stilts. </p>
Great job! Raised garden beds are great for the backyard gardener.
<p>Thanks for the comment!</p>
<p>Oh Please! Please! Please! Take out your plants and dirt and remove the plastic! Your plants will die if the water can't drain! Instead, lay down 4-5 layers of newsprint in newspapers or corrugated cardboard and then put you dirt in. The critters won't come up and earthworms love newspaper and the plants can drain!</p>
<p>about the newspaper, do I have to wrinkle it? or just put it?</p>
<p>Thanks to the originator who posted their instructable!! But I do have a question...Doesn't the plastic leach toxins into the soil you are trying to grow your veggies in? I'm asking because I LOVE LOVE LOVE!!!! the idea of using it, but i am leary of using plastic because I do not want the nasty chemicals released into my soil as it breaks down. Any feedback would be greatly appreciated! :) <br></p>
<p>I don't leave the plastic in long enough to break down. I use this seasonally -- 5 months. My yard is way too small to have this space occupied all year. I use plastic sheeting because it's cheap, strong and retains moisture well for my purposes. It also makes cleaning the area up later nice since the dirt can be hauled back to a storage bin or compost heap.</p><p> You can use anything you want instead of the plastic. I've worked in landscaping for many years and there are tons of high quality plastics and other materials available--they just cost a good bit more. I have even known other guys to use various types of natural cloth and canvas, paper..etc. One even used a mixture of playground sand enriched with small chunks of homemade charcoal as his drainage layer (the lowest foundation layer). He grew some of the best watermelons I've seen.</p><p>If you are concerned about this and your beds will be more permanent than mine are intended to be, then you will want to ask some pros in your areas for what works best in your location. You may be able to achieve similar results simply by layering various soil types and moisture retaining materials and eliminating the plastic altogether.</p><p>Good luck!</p>
<p>in dry climates with sandy soil such as my home area the perforated plastic is essential! Water is our most wasted resource in America. We take it for granted. I use an inexpensive bagged compost soil, lay the perforated bags in flat and cut out the upper side. Stir in perlite to retain moisture for two to three days at a stable moisture release rate then plant. The same soil has served well in my above the ground boxes for three years running without water build up, plant rot or water waste.</p>
<p>Thanks for that good note 7nflgirl. I agree that newspaper is an excellent option and it's environmentally friendly. Most people already own some! I've used it plenty of times before in other places that I've lived and it's preferred. I didn't want to use it on this project this time around though. I used plastic last year too. I'm from the S.C. Low Country (@ sea level or below) and I can clearly see the point about having better drainage in many environments so that we don't kill the plants. Here in Northern California, I live at the top of a desert area nearly in the mountains. I switched to the plastic because it not only aids in cleanup when we move the bed after the growing season, but it is necessary to retain enough moisture in the bed to keep things living. It's just way too dry here, especially when there's drought conditions and water gets rationed. Without it, my beds dry out way too fast and I find that I end up wasting water and time trying to regulate it without further expense. My photos only show us putting a couple of holes in the bottom, but there's more than that. We carefully planned the drainage for each bed and my wife tested two of the beds. We took the third on faith. I guess I should have said something about that, my apologies. BUT it does drain well. Thanks for pointing out that everyone should verify that they have adequate water drainage and that there are choices for barrier material.</p>
<p>Oh thank you for easing my mind and I am so sorry for not noticing in your article that you had punched holes in the plastic....WHEW!!!!</p><p>Well then... carry on with my blessings as an avid gardener myself! I was brought in this world gardening and guess I'll leave it gardening!</p>
<p>Thanks again for looking out for us! Best wishes to you.</p>
<p>Sorry but, does moisture get trapped under the plastic? Wont that rot the wood? I don't think you needed the plastic so-much, just some leftover &quot;Non-Toxic&quot; paint or stain you may have in the basement or shed. Also, I would be afraid of not receiving good drainage and aeration even with holes in the sheeting.</p><p>Just some friendly sudjestions from one gardener to another. Beautifel raised bed, BTW.</p>
<p>I'm glad you enjoyed the project and thanks for taking the time to read it and comment! </p><p>Your comment about painting them sounds like a good idea to me. We should have done that. Coating the planks could extend the life of the boxes.</p><p>I constantly checked the drainage and moisture levels of the soil the very first year we tried this in California. We have done this for a couple of years now in this location and it works really well for us. The wood has shown no signs of mildew or rot. I don't recall the type of wood we used... perhaps that has something to do with it? </p>
<p>I saw a great project that helped me determine the size of my beds. I first used my paint sprayer to spray every surface of wood including cracks with some oil based paint that was left over from the house. But paint has chemicals so I didn't want them in the soil above or below! Your instinct with the plastic is great! But I just bought bagged soil (still works great after three seasons), laid them flat in my boxes and cut the side panels of the bag out which were now the tops leaving me 8 inches of rich soil! The bags of this inexpensive brand of composted soil cost about $10.00 each so with wood and everything, about $25.00 per box on an annualized basis. But it appears they will last many more years with nothing more than a little in soil composting with shredded paper and used coffee grounds (so as not to attract flies and flying bugs). Stick with what works!</p>
<p>sorry...ps..the bags came perforated so the drainage problem never was an issue.</p>
<p>I love the last picture - at least he didn't choose your new planter for digging :-)</p>
<p>my kind of project... minimalist...</p>
Great but don't use miracle grow or other manufacture soils ... Awful stuff in them... You can find recipes for organic soil making your own the best way to go... Find in your Area someone who makes worm casting ..! :)
<p>Thank you!</p>
About This Instructable
47,609views
421favorites
License:
Bio: I'm a Nerd and a garage inventor. My dad used to say, "There he goes...off to 'The Lair' to invent something. Try not ... More »
More by M.Hawse:Backyard Garden Boxes - On the Cheap! Tribute T-Shirt - Infocom's Zork I, II, III & Beyond Zork Hand-Painted Pottery | Family Fun in the Studio
Add instructable to:
