This digester is basically a compost bin with a twist. The twist being that the bin is sealed and partially buried to deter pests from feasting on the stuff inside.
I do not plan to harvest any material from the digester since my compost bin provides enough humus for my soil-building needs. The other reason for not harvesting the digester's contents is that it will be comprised of some nasty stuff, namely dog poop and rotting meat. Yechh!
My inspiration for the project came from the website of my local government: http://www.compost.bc.ca/learn/factsheets/3digester.pdf
Let's get started!
Step 1: Items You Will Need...
- Electric drill
- Holesaw kit
- Felt-tip marker
Step 2: Siting the Digester
Once you have found a good spot for your digester it is time to dig a hole. I made the hole slightly larger than the bin and about 8 inches deep. I'm sure it wouldn't hurt to go a bit deeper.
Step 3: Preparing the Bin
I used a 1-3/4" holesaw to make the holes. The molded supports on the bottom of my bin made it very easy to lay out my holes as you can see in the photo. You may have to use a different method to space your holes. Just make sure you leave enough material between the holes so as not to compromise the structure too much.
After you have drilled all the holes in the bottom, drill a series of holes around the lower circumference of the bin. Again I used the molded supports as reference lines to get the appropriate spacing.
Step 4: You're Almost Done!
Thanks for reading and good luck with your digester (if you make one - post some photos or comments!)
Cheers!
Visit Our Store »
Go Pro Today »
Basically it's the principle of using probiotics. You can even make your own. Highly effective and highly recommended, especially for your setup.
I built a similar concept last spring to work as a composter from the plastic salt tank of an old water softener. I drilled the holes on the bottom and sides like you, but made them much smaller to keep the compost in. Sadly, I did not document the process.
It has worked remarkably well this year, with all of our organic kitchen waste going into it, as well as much of our junk mail after passing through a paper shredder. No odor or animal problems at all. The compost will go towards a garden I plan on starting this coming spring.
Have you had much problem with odour when the lid is on?
