Disclaimer out of the way, let's get started!
This how to will not include the gutter system, I figure that it's pretty variable depending on the scenario, but the barrel itself is easy and approachable by everyone.
Remove these ads by
Signing UpStep 1: Materials and Step 1
My choice is a 200 L bioprocess container. It used to hold glucose.
You can acquire these barrels from various sources. I got mine free from a local manufacturing company. They throw things like this out or back into recycling all the time. Another viable option is a local carwash, they have large barrels for detergent that they need to dispose of all the time. In any case, where ever you get yours, wash the heck out of it before you start watering your food crop with it.
You will also require:
Power drill
Rubber mallet
Drill bit (3/4 inch)
teflon tape
3/4 inch spigot union (this is going to be snug fit)
3/4 inch black connectors
plumbers putty
plumbers adhesive
standard house spigot (which should also fit a 3/4 inch fitting.
Step1:
Drill the hole into the barrel near the bottom (but not at the bottom (see figure 2).
Use the rubber mallet to seat the union through your hole. This will be pretty snug I assure you. Do not bang hard, just take your time. After you've seated your union, teflon tape the threaded bits.
Visit Our Store »
Go Pro Today »
If anybody wants some more information I've been using this as my go-to info page: http://www.aquabarrel.com/product_rain_barrel_plastic_parts.php
I've had one of these for many years at my bush cabin. I now use a bent copper pipe with a tap attached as a siphon stuck in the top, after finding the barrel empty one day due to a leak. I don't go there for months at a time, and just pull the pipe out and cover the hole when I'm not there.
This is a better system if you aren't absent for long periods.
In your bush cabin do you use the water for washing pots and pans and such?
