First time/long time...Inspired by the Guerrilla Drive-in Instructable by plusbryan, I built a temporary backyard theater. This Instructable will cover the basics on building a projection screen that won't break a budget or be pushed around by an evening breeze.
Step 1: Materials
My vision was a 8' x 16' screen. At the local Lowes I purchased:
4) 4' x 8' sheets of 7/16 OSB ($7 per sheet)
3) 10' 2 x4's ($3-4 per board)
8) 8' 2 x 4's ($2-3 per board)
1) Box of 1 5/8" dry wall screws (coarse thread) ($5/box)
1) tube of painters caulk ($2/tube)
1) partial can of white-ish paint I had around.
Tools --
skill saw
screw gun
tape measure
speed square
various clamps
Other items needed for the final event were donated by friends or I had already
DVD player and amp
Speakers + 50' of speaker wire
Raiders of the Lost Ark DVD
HD Projector (courtesy of my employer).
Step 2: Assembly
Like I said before, the vision was a 8' x 16' screen. Once I mocked this up with the 4 sheets of OSB, I quickly realized there was no freakin' way I could erect this and have it safely stay vertical, without buying more lumber. Change in plans...8' x 12' is manageable and still an impressive size for a backyard.
Step 3: Assembly
After settling on the layout, I then used the 1 5/8" screws at every 2 feet. I wanted to keep this something that can be easily taken a part or modified. On the outside edges of the OSB I screwed into the edge of the 10' 2 x 4. Then where I joined the 2 horizontal sheets with the single vertical sheet, I screwed into the face of the 2 x 4. Probably not needed but it seemed to add surface area to screw to.
Step 4: Paint
I located a partial gallon of white-ish paint we had from some other project. I employed my 11 year-old and 3 year-old to swab the paint on. After the paint dried, I added a bead of caulk at the joints. This should have been done before paint, but the painters could not wait. Caulking the joints is probably not necessary, but I didn't want a rough joint distracting from the movie.
Step 5: Footing Gussets
With the now "extra" 4th sheet of OSB, I cut into a 4' x 4' square and then a diagonal cut for the gussets. Screwed off and moved to the next one.
Step 6: After Paint Assembly
I clamped the 2 x 4 to the face of the screen for temporary support. Tipped the structure up and clamped support legs to the back. Pounded some steaks - screwed the steaks to the legs on the structure to secure.
Step 7: Final Thoughts
This made a fairly impressive outdoor screen for a projector. Next summer when I do this again, I will lay all 3 sheets of OSB vertical and build the frame similar to a wall with common house framing construction...and leave it up for the summer!
Thoughts of hanging speakers from the screen and adding some sort of a sub woofer as well.
As for the event itself...it was a huge success. Most of the neighborhood arrived as well has close friends and family. My wife's Wasabi popcorn was a hit! Looking back, Raiders of the Lost Ark probably wasn't the best choice for a family event. My 3 year-old still talks about a dead monkey and some guys face melting???
Thanks for checking out this Instructable! Look for "Phase 2" next spring!!!
DavidRobertson says: Jun 1, 2010. 11:18 AM
FFS IT'S GUERILLA NOT GORILLA!!!
hbjngf says: Mar 30, 2011. 9:18 AM
lol captain Ron
MedMisfit (author) says: Jun 1, 2010. 9:36 PM
Lighten up, Francis.
static says: May 30, 2010. 10:38 PM
Periodically the powers that be ask for suggestions of what to do out at the local township lake to get more people out there to "recreation".  Next time I'm going to suggest building a movie screen and purchasing a projector to rent out. However I can hear them now complaining how about how the hoodlums might  tear it up.  That is a very real possibility, but I growing tired of this down letting what may happen from doing anything interesting.  Anyway a good instructable of how you did yours, thanks for taking the time to document it.
mccoy31 says: Mar 24, 2011. 2:31 PM
Do you live in my town? LOL.
mgauvin8810 says: Jan 20, 2011. 8:29 AM
There is a company in NJ that's sells White Tarps (like the more common blue or green ones with the grommet holes). I used one of those for a couple of summer's showing Nascar night races, I think it was 16'x30' for about $60.00
porcupinemamma says: May 31, 2010. 2:49 AM
This looks like so much fun!!! Could you please tell me more about the projector, and how it is used with the DVD player? I'm not technically competent, if you could explain in really basic terms, I'd really appreciate it.  Also, roughly, what would the projector cost, and where can a person purchase one?
chaydgb says: May 31, 2010. 2:31 PM
Projectors connect to the DVD player in much the same way as a TV, the only difference being that they (generally) don't have speakers built in (the ones that do generally have small speakers that are more suited to indoor use) - so you also have to means to amplify the sound, such as a stereo / Hi Fi / amplifier with an external input, plus some speakers. For oudtoor use, you may need quite a bright projector (they are rated (and priced) by the number of lumens they put out) unfortunately this would mean more money. These can be brought new from electronics / computer stores like Best Buy, or you could pick up a second-hand one on eBay for much less (although the problem then is that the bulb may be nearing the end of its life and they are expensive to replace, so it may be a false economy).
porcupinemamma says: May 31, 2010. 5:43 PM
Thanks a lot for helping me understand.  Did I mention that my friend converted his garage into a drive -in movie theater?  Well.. the car was NOT turned on, but everyone huddled in to the car and ate popcorn and licorice and drank pop and watched old black and white movies. I love stuff like that.
CallMeJeremy says: May 31, 2010. 12:07 PM
One thing you might want to look at for improving your screen next year is shower board. It's the glossy white laminate you normally use to create a custom shower surround. It's about $10 per 4'x8' sheet - works great as a dry erase board and as a projector surface too - though I wouldn't write on it if you dedicated it's use to a projector. Nice project!
kcls says: May 31, 2010. 7:24 AM
Great job! Did you only use it once?
HandyMan1959 says: May 30, 2010. 4:49 PM
For those that want a better experience check out www.screenpaintsupply.com/  They have a white reflective paint that will make it more like what you get in the theator.
Sakla says: May 30, 2010. 10:38 AM
Nice.  I couldn't build a permanent screen in the backyard because there are times of the year with SEVERE wind.
I did build an 8' x 4' screen with melamine that I would roll out on wheels.
Then I built a screen that I can assemble in 15 minutes.  The frame is made of 3/4" EMT conduit.   The screen material is 15' x 12' piece of painters drop cloth (grommetted) that I attached to the frame with those ball bungee cords.
I couldn't be happier.  I was at first afraid that I would see the seams of the canvas -- happy to say I can't.  The dimensions are great because I not only can see current 16:9 ratio films on the "big screen" but I can also watch 4:3 TV shows (and some older films like "The Shining" ) on the "big screen".
Cost be about $120 to build.
FrenchCrawler says: Nov 1, 2007. 5:22 PM
Great job... I did a similar version to this about 1 year ago. My screen came out to be the same size: 8' high and 12' wide (made up of three 8'x4' sheets). It was gonna be temp, but became perm. after we discovered how heavy it was. Stood for the longest time, until we had a storm with strong winds (half asleep, heard huge bang, went back to sleep knowing it was the screen). This summer bought some white movie canvas off off ebay and planted some PVC pipes to hold the material. Works out great (especially since there's no lines in the picture now).
Greasetattoo says: May 30, 2010. 6:55 AM
Hey FrenchCrawler,
I did a search on Ebay for movie canvas.
Nothing came up!
What exactly is Movie canvas.
Or just regular canvas.
thanks
Oh, GREAT instructable  Medmisfit!
5533888 says: May 29, 2010. 4:01 PM
Cool!!  My friends have a large barn like garage and every tear they put a movie on it with there projector. I Just did an Instructable on how to go to the drive-in with style, you should check it out.
zigzagchris says: May 29, 2010. 12:25 PM
hmm so u live in below the equator or did u just take a while to put this up?
zascecs says: May 29, 2010. 12:11 PM
Weapons of mass construction, good one!
uncle_al_0 says: Nov 1, 2007. 5:55 PM
If I were you I would have used 1/2 inch MDF (about $10 per sheet where I live) for the screen because it has a finished surface and doesn't show the large chips of wood in it. Then I would have used a little wood filler in the gaps before painting.
mg0930mg says: May 21, 2009. 12:35 PM
That's exactly what I want to do. Thank you.
bloomautomatic says: Mar 24, 2009. 9:32 AM
Nice work. If anyone wants to go really cheap and easy, white shower curtain liners make nice screens. hang them off the awning, the gutter, or wherever and you're set. tape 2 together for a screen of about 6'x12'. check out www.backyardtheater.com for more ideas. we did two movies last summer and they were huge hits. plan to do many more this year.
DIY Dave says: May 11, 2008. 7:29 PM
cool
marcintosh says: Mar 6, 2008. 9:58 PM
You might like to use MDO. It stands for Medium Density Overlay. It's used for signs ( stop, yield etc.) It's available in 1/2 and 3/4 thicknesses and 4x8 sizes. It's a bit more pricey but lasts a long long time and is very smooth. You could edge seal the panels with epoxy as well but that's kind of gilding the lilly. Think about using one of the newer high performance construction glues to avoid screw heads. Just a thought
Gamer6460 says: Jan 8, 2008. 8:30 PM
Thats a really good idea, I think I'll have to build one of those when the weather gets warmer.
PerfectlySquare says: Nov 2, 2007. 9:12 AM
Speaking of faces melting off... Wasabi popcorn? ;)
vaxjo says: Nov 2, 2007. 7:55 AM
I have a similar screen in my Odeon: it's a piece of OSB (similar to plywood) but rather than paint it I stretched a sheet of blackout fabric (which is white and, I believe, is designed to go behind curtains) over the front of it to project onto. As long as there are no wrinkles in the sheet (which is pretty easy to do) it works quite well.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
