3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bacon Cheesecake
Bacon Cheesecake
Make your very own Bacon Cheesecake!
Preparation time approximately 2 hours.
What you will need:
I. Food
a. 1/3 Cup of melted butter
b. 1 Box of cinnamon graham crackers or 1½ Cup crushed cinnamon graham crackers
c. 26 oz, 3¼ packages, cream cheese
d. One 14oz. can sweetened condensed milk
e. 2 tsp. vanilla extract
f. 2 eggs
g. 3 pounds of bacon
II. Cooking Instruments
a. 9”x2” cake pan
b. Cooking sheet
c. Rubber spatula
d. Wire whisk or automatic mixer
i. If you are using a wire whisk look for special notes
e. Measuring cups
f. Measuring spoons
g. Paper towels
h. Aluminum foil
i. 1 large bowl
j. A few small bowls and some plates
Step 1Cooking the Bacon!
Cooking the Bacon!
The first place to start is with the bacon because of how much you will be using and wanting to eat while cooking. Each batch of bacon will take about 20 minutes the amount of bacon in each batch depends on how large of a cooking sheet you have.
What you will need:
A. Cooking sheet
B. Aluminum foil
C. Bacon
D. Plate
E. Paper towels
Cooking steps:
1. Cover top of plate with 2 paper towels for the bacon when it is done cooking.
2. Cover the top of the cooking sheet with the aluminum foil.
3. Place the bacon on the aluminum foil, you don’t need any space in-between the bacon but don’t have the bacon overlap.
4. Place the bacon on the cooking sheet in the oven on the center rack then set the oven to 400°F.
5. Let the bacon cook for 16 minutes, after this time look at the bacon if it is a golden brown or darker take it out. You do not want to bacon to look pink at all this will end up with the bacon being under cooked and not crispy enough. If the bacon needs more time let it stay in for 2-5 more minutes then check again.
*NOTE* I used thick cut bacon and it took about 23 minutes for my first batch to be crispy enough if you have thin bacon it should take less time.
6. After the bacon is the right color take it out of the oven and transfer it to the plate with the paper towel on it and dispose of the excess bacon grease.
7. Repeat these steps until you have cooked all of the bacon.
*NOTE* You do not need to let the oven cool down to room temperature after cooking the first batch. Still check the bacon after 16 minutes and extend time as needed.
8 comments
May 4, 2011. 10:13 PMBartboy says:
Similar idea to mine, but I covered four different types of Bacon Cheesecake in my ible :P
Yours looks really good though! Well done!
Apr 22, 2011. 12:30 PMsplazem says:
Yum. I have to try this.
Apr 22, 2011. 5:35 AMartem_stk says:
Apr 21, 2011. 5:17 PMComputothought says:
Definitely different. A true semi-savory cheesecake,
Apr 21, 2011. 7:39 AMscoochmaroo says:
Bacon cheesecake - I love it! How did it taste? If you have any brighter pictures of the finished product to put in the intro, I would love to feature this!
Apr 21, 2011. 3:44 PMscoochmaroo says:
Works for me!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:leik_leviathn
