Bacon Roses
 by kaptaink_cg
Contest WinnerFeatured
Flowers make a nice gift to the friend that needs a smile or for that special someone in your life. Roses are even better. But sometimes even roses don't cut it. Sometimes you need something a little more non-cliché, something...extraordinary... Sometimes, you need BACON.
Step 1: Materials
BACON - I like to use one regular pack and one thick cut pack
Rose Stems
Glass Vase
Mini Muffin Pan
Broiler Pan
Drill with bi
t (I used an 1/8" bit, but any similar size will work)
Gravel or marbles for vase (not shown)
Step 2: Preparing the Pans
Drill holes in the bottom of the muffin pan. This will allow the grease to drain when cooking the bacon.
Place the muffin pan on top of the broiler pan.
Step 3: Prepare the Rose Buds
Preheat the oven to 375degrees Fahrenheit
Open the bacon and begin tightly rolling the roses, one piece at a time. Start with the widest end of the bacon, with the fat edge down. I like to use a combination of thick and thin bacon so I end up with a variety of rose shapes.
Place all of the bacon in the muffin pans pushing down slightly to "seat" them. The bottoms will flair out a bit.
Place in the oven and cook for 30-40 minutes. Check in on them occasionally. Sometimes you will have to lift the rose so the grease will drain out the pan.
Step 4: Prepare the Rose Stems
While waiting for the buds to cook you can start working on the stems. I found the stems that work best can be purchased at Walmart in bunches of 7, for under a dollar each.
Pull all of the roses off from the stems.
Pull the green backing off from the rose and then separate it into individual parts.
Discard the petals and center red piece. Reassemble the remaining green parts as shown.
Put the green piece back on the stem, but force it down so that roughly 1" of the stem protrudes.
I like to tape the stems together at this point, but this is optional.
Put the stems in your vase and fill with gravel or marbles to hold them in place.
Step 5: Assemble and Present!
When the bacon buds are done, remove from the oven and place on paper towel to cool.
You'll now have a variety of rose buds to choose from. Pick your favorites and slide them onto the protruding stems. Arrange the roses to your liking and then present the aromatic bouquet to your favorite bacon fanatic!
1-40 of 189Next »
snackqueen says: Apr 14, 2011. 8:06 PM
I would just like to say, that these roses were not only beautiful, but also tasty, delicious and aromatic!!! After receiving them, I laughed (in the best possible way) every time I looked at them for the first day or two. When he gave me these, I was ecstatically happy to say the least.
breumer says: Feb 10, 2012. 2:43 AM
This was such a fantastic idea! I made these for my husband ! they turned out great! Thanks you for sharing this awesome fantastic idea!
kaptaink_cg (author) in reply to breumerFeb 13, 2012. 9:11 AM
Wow, those look great!! Excellent idea using the tealight tins.
Corbo88 says: Feb 14, 2012. 1:52 PM
I made these today.
ditzyclutz in reply to breumerFeb 14, 2012. 9:12 PM
Thanks for posting the pic of the tea light candle tins... I totally stole your idea and it worked out great!
asmith96 says: Feb 15, 2012. 6:14 AM
This was an incredible idea and well worth the first prize for the bacon contest. I just made this for Valentines day and it was a hit.
Several people have had problems cooking the bacon fully beacuse the fat pools and boils the bacon insead of cooks it. I had the same problem until I opened up the drain holes about the size of a dime, or around 1/2 inch.The larger the holes, the better drainage beacuse bacon fat is your worst enemy, at least for this project!
Thank you so much for this idea!!!
breumer in reply to ditzyclutzFeb 16, 2012. 1:56 AM
johnnyromani says: Mar 28, 2013. 8:21 AM
This is perfect. I've tried to do myself, but I messed it up! hahaha My bacon just doesn't rolled in, Then I ate it. So delicious :D As we say in my blog, at least we tried, if don't works, eat it!!
365DaysofBacon says: Mar 5, 2013. 4:56 PM
Check out this cool variation we did dipping the bacon roses in chocolate!
dawnsrecipes says: Feb 26, 2013. 4:34 PM
Your instructable inspired me to make a rose bouquet for my husband for Valentine's Day. Thank you!! I didn't quite stick to your method, but I blogged about it and gave you credit for the idea. Hopefully it drives a little traffic your way. :)
http://www.dawnsrecipes.com/bacon-rose-bouquet-2794.htm
Bacon-Rose-Bouquet-Dawns-Recipes-blog-5.jpgBacon-Rose-Bouquet-Dawns-Recipes-blog-7.jpg
kaptaink_cg (author) in reply to dawnsrecipesFeb 26, 2013. 5:21 PM
Awesome! Thanks!
I like your baking rake method. That definitely alleviates the fat draining problem!
carterdana says: Feb 15, 2013. 8:26 AM
Made these for my girlfriend for V-Day this year. Fairly easy to follow and awesome Instructable (tho it took me closer to 90 minutes from start to finish...kept my bacon in for 45 minutes at 375 to crisp the non-fat edges). I used shiny mini-muffin cups with holes punched in the bottom with a chopstick laid on a roasting pan with grill for the fat to drip into (lifted up the roses a few times to let the fat drain). I also tried different lengths of bacon (some strips cut in half) to make smaller 'buds' and used the leftover petals from the stems for tabletop decoration....she's not a huge flower-lover but she absolutely LOVED these...thanks gang!
kaptaink_cg (author) in reply to carterdanaFeb 15, 2013. 10:41 AM
Those are awesome! Great job! Glad you enjoyed my instructable. :)
jprekopa says: Feb 3, 2013. 6:23 AM
And, of course, there should be a "wash the stem pieces" after discarding the petals.
PWhito says: Jan 31, 2013. 2:14 PM
nailing it for Valentines Day this year!!!
DividersMaker says: Jan 18, 2013. 10:00 PM
that is awesome,
lbryant3 says: Jan 17, 2013. 10:01 AM
Would it work if I were to wrap part of the rolled bacon with foil (for example around the middle), and just sit it on a rack instead of muffin tins?
kaptaink_cg (author) in reply to lbryant3Jan 17, 2013. 6:18 PM
Possibly. It's worth a try at least!
dubstepmaker says: Nov 28, 2012. 11:14 PM
this has got to be one of the coolest things i have ever seen!
walkingpureheart says: Nov 24, 2012. 1:04 AM
Thank You...Thank You..! My son is a bacon freak and this is going to be great for Christmas. You Rock!
aroy18 says: Nov 15, 2012. 10:50 PM
excellent post and wonderful blog, I really like this type of interesting articles keep it u. I am really loving the theme/design of your web site.kerala tourism .
becka94 says: Oct 21, 2012. 10:27 PM
I made these today! Instead of drilling holes in a muffin pan, I used the muffin paper cups and put a paper towel piece under each. I changed the paper towels when they were halfway cooked. Its messier, but its cheaper! They turned out great and my friend loved them :)
kristy4022 says: Sep 10, 2012. 7:35 PM
I made these last Valentines day. My boyfriend and his family got a kick out of them. Next year I think I'll try covering them in chocolate. Girls shouldn't be the only ones catered to on Valentines Day!
kristy4022 in reply to kristy4022Sep 10, 2012. 7:38 PM
Also for an easier, less tool handy person like myself, they also work by using a disposable aluminum muffin pan and poking holes with a knife.
JaredBlake says: Aug 18, 2012. 8:43 PM
I'm not sure why but this makes me very happy. Mm bacon.
cowstick says: Aug 18, 2012. 5:57 PM
I love you. Thank you for this.
B_____Squared says: Aug 18, 2012. 1:12 PM
Or Coffee Beans to stay with the B-Fast theme!
elsienjake says: Jun 17, 2012. 10:16 AM
Thank you so much for the great instructions and pictures! I didn't want to drill holes in a muffin pan so I used a jalapeno popper grill rack. I turned them half way through and they came out great! Now, using the thinner cut bacon won't work because they won't be wide enough and will fall through the holes. The thick cut bacon worked great though. Can't wait to give them to my dad for Father's day.
FaeDine says: Feb 22, 2012. 2:35 PM
I just wanted to give a proper Thank You! to the author of this. I used these for a recent wedding proposal to my girlfriend and they were a total hit! Thank you so much! They went great with the bacon ring ;)
For anyone curious, I didn't want to drill through a pan so did end up using a "silicone mini-muffin" pan and it worked quite well. I still think a metal pan is likely ideal if you're going to make more than one "batch" though.
Also, wow, the bacon gets even tastier when it's all curled up.
ditzyclutz says: Feb 14, 2012. 9:14 PM
Oh yeah! Mama's bringin home the bacon, baby! These turned out AWESOME! They were sooo easy to make. I picked up everything from the dollar store (2 six-rose stems, 3 green filler stems, 1 green vase, 2 bags of glass floral beads). Only $8.00 + tax, not counting the bacon! I didn't have a mini muffin tin, so I stole Breumer's idea of using the aluminum part of a tea light candle - poked holes in the bottom and set them all on a cookie sheet. Worked perfect! I gave the bacon bouquet to my fella for Valentine's Day today! The best part... upon first glance he didn't even realize they weren't real roses! Thanks for the great idea!
piratecupcake says: Feb 14, 2012. 1:33 PM
I didn't want to drill holes in my tins so I used a pizza pan with holes in the bottom and put a cookie pan under it. I also skewered the bacon so they would stay together and put some brown sugar on a couple.
And then I made chocolate cupcakes with the intention of making them look like a bouquet....but they exploded so I ad-libbed a little.
markio01 says: Feb 14, 2012. 12:23 PM
Made this for valentines day came out awesome.If you want to save some cash use cupcake liners instead of muffin pan worked fine.
ErinMichelle says: Feb 13, 2012. 8:58 AM
I am vegetarian but am making these for my fiance. Normally I don't admit my food orientation but in this case, it says a lot about my (lack of) knowledge of good eatin'. As I don't know the first thing about cooking meat - & this is my first time even handling it - there are two instruction components I am unclear on: the first being that I can't tell which is the "fat end". Is it the white-ish part? Also, is the referenced grease something I need to do to the pan, or does this naturally come from the bacon? Please help, anyone! Today is his birthday, & I've got just a couple hours before he gets home.
Thanks sincerely :D
kaptaink_cg (author) in reply to ErinMichelleFeb 13, 2012. 9:10 AM
A vegetarian making these? That must be true love! :)
Yes, the white-ish part is the fat. The grease just naturally comes off from the bacon as it cooks. You don't need to do anything to the pan (except drill/poke holes in the bottom)
ErinMichelle in reply to kaptaink_cgFeb 13, 2012. 10:11 AM
Between my love for him & his love for bacon, there is a whole lot'a' love here! I guessed right about the fat edge & am in the midst of coooking them now. Your instructions were very thorough & helpful. It's just that I can't cook. Not even a grilled cheese. If I could, I'd send you a dozen also! Thanks again.
AromaticDuck says: Feb 13, 2012. 9:03 AM
These look (and taste) lovely! Try painting them a vivid red colour with a liquid food dye and a paintbrush, to make them look even more realistic.
emmaleighcat says: Feb 12, 2012. 6:14 PM
When I made these, the middles of my bacon didn't cook. I was hoping to make them for Valentines day for my honey but now I don't know what to do. Any suggestions on how to fix this?
kaptaink_cg (author) in reply to emmaleighcatFeb 12, 2012. 7:37 PM
Did you use a pan with holes in the bottom, and did you ensure that the fat was draining from the pan? If you did that, then they just need to be cooked longer. If the fat stays in the pan they'll take forever to crisp up and wont cook properly.
numm3r says: Feb 11, 2012. 11:19 AM
Has anyone tried putting a date filled with cheese in the middle? I'm curious how it would look! I think I'll try that version!
adamjmagyar says: Jan 7, 2012. 3:31 PM
Hahaha, this is so awesome. The Snack King here! Adam Magyar http://thepeoplesmarketing.us
1-40 of 189Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
