loading
loading
Picture of Bacon Roses
Flowers make a nice gift to the friend that needs a smile or for that special someone in your life. Roses are even better. But sometimes even roses don't cut it. Sometimes you need something a little more non-cliché, something...extraordinary... Sometimes, you need BACON.
Step 1: Materials
Picture of Materials
BACON - I like to use one regular pack and one thick cut pack
Rose Stems
Glass Vase
Mini Muffin Pan
Broiler Pan
Drill with bi
t (I used an 1/8" bit, but any similar size will work)
Gravel or marbles for vase (not shown)
Step 2: Preparing the Pans
Picture of Preparing the Pans
Drill holes in the bottom of the muffin pan. This will allow the grease to drain when cooking the bacon.
Place the muffin pan on top of the broiler pan.
Step 3: Prepare the Rose Buds
Picture of Prepare the Rose Buds
Preheat the oven to 375degrees Fahrenheit
Open the bacon and begin tightly rolling the roses, one piece at a time. Start with the widest end of the bacon, with the fat edge down. I like to use a combination of thick and thin bacon so I end up with a variety of rose shapes.
Place all of the bacon in the muffin pans pushing down slightly to "seat" them. The bottoms will flair out a bit.
Place in the oven and cook for 30-40 minutes. Check in on them occasionally. Sometimes you will have to lift the rose so the grease will drain out the pan.
Step 4: Prepare the Rose Stems
Picture of Prepare the Rose Stems
While waiting for the buds to cook you can start working on the stems. I found the stems that work best can be purchased at Walmart in bunches of 7, for under a dollar each.
Pull all of the roses off from the stems.
Pull the green backing off from the rose and then separate it into individual parts.
Discard the petals and center red piece. Reassemble the remaining green parts as shown.
Put the green piece back on the stem, but force it down so that roughly 1" of the stem protrudes.
I like to tape the stems together at this point, but this is optional.
Put the stems in your vase and fill with gravel or marbles to hold them in place.
1-40 of 224Next »
breumer made it!3 years ago
This was such a fantastic idea! I made these for my husband ! they turned out great! Thanks you for sharing this awesome fantastic idea!
Thanks for posting the pic of the tea light candle tins... I totally stole your idea and it worked out great!
kaptaink_cg (author)  breumer3 years ago
Wow, those look great!! Excellent idea using the tealight tins.
asmith96 made it!3 years ago
This was an incredible idea and well worth the first prize for the bacon contest. I just made this for Valentines day and it was a hit.
Several people have had problems cooking the bacon fully beacuse the fat pools and boils the bacon insead of cooks it. I had the same problem until I opened up the drain holes about the size of a dime, or around 1/2 inch.The larger the holes, the better drainage beacuse bacon fat is your worst enemy, at least for this project!
Thank you so much for this idea!!!
Corbo88 made it!3 years ago
I made these today.
snackqueen4 years ago
I would just like to say, that these roses were not only beautiful, but also tasty, delicious and aromatic!!! After receiving them, I laughed (in the best possible way) every time I looked at them for the first day or two. When he gave me these, I was ecstatically happy to say the least.
Absolutely beautiful!
elliotnash16 days ago
Tasty! This is the perfect present for those who love bacon whether they're a boy or a girl.
CalebK31 month ago
Highlight of my breakfast. perfect V-day Breakfast
KattNBoots2 months ago
Instead of drilling wholes in the pan I found it easier to place rits crackers under the bacon roses to collect grease, when they got to greasy I just replaced them with a new cracker.
PatrickBishop3 months ago
Beautiful and tasty. These are my types of flowers!
This is such an awesome idea. My girlfriend loves bacon and guess what I'm doing for her next birthday ;)
smartmiltoys4 months ago
I think it is very nice flowers for home using!
Thanks for interesting presentation!
starforest4 months ago
I see that you used regaler bacon.
Perhaps if you used bacon that was sliced thinner you would be able to add more detail to the roses.
kimmy5114 months ago
So I just made these for my husband...they are adorable, and I followed the directions but the inside of the rise was still a little raw and uncooked :( I tried to not wrap them too tight so it would cook evenly. Not sure what happened.
kaptaink_cg (author)  kimmy5114 months ago
If I had to guess, I would say it either didn't cook quite long enough,or perhaps the fat wasn't draining well enough?
jproffer made it!4 months ago
Made a batch here! Turned out awesome.
Do you have to refrigerate after making them? Or can they be left out for a while, say if you make them in the morning and plan to give them away in the evening?
sgolobay4 years ago
this is not a food safe item? the flower stems what sort of strange cooties are living in this? besides ewwww
the "besides, ewwww" tells me you have no intention of having anything to do with this besides criticize, but since this comment is three years old, for the edification of others I will make this simple suggestion... the flower stems are made from plastic and nylon... um... WASH THEM? heh.
jovino4 years ago
Step 1 has me concerned because you are taking a metal object to a teflon coated baking pan. You are breaking the barrier seal, exposing toxic chemicals into the food you are cooking as well as the air that you breathe.
Search for "dangers of teflon" if you wish to learn more about protecting your health.
Taranach jovino4 years ago
While this may be so IF you overheat the pan, one should always be paying attention to your cooking, not wandering out of the room to attend to other things, that is how kitchen fires can start which are FAR more dangerous than a minuscule amount of gas. Basically, if your pans are smoking, not steaming, then you the heat is to high. Next is the drop in the bucket compared to the thousands of other toxins we take in on a daily basis. You are in effect removing one "possible" source of toxins from hundreds if not thousands more. Living on the planet earth is toxic and ultimately fatal.
Let's not forget that most dangerous toxin of all... look up "dihydrogen monoxide" better known as DHMO at www.DHMO.org why has this NOT been banned! it is FAR more dangerous than ALL the possible toxins discussed here!
True, Dihydrogen monoxide (also known as hydric acid) is responsible for injury, death, and property damage all over the world. Visit the Dihydrogen Monoxide Research Division online at www.dhmo.org, or send email to info@dhmo.org for more information. Tell the EPA to ban Dihydrogen monoxide!
But but but I just can't liiiiive without my DHMO! Is there a 12 step program out there anywhere for it? If not maybe we should form one!
::snickersnort::
jovino Taranach4 years ago
DHMO... HAHAHA!!! This one always makes me laugh!
Why does DHMO make you laugh?
Dihydrogen monoxide. AKA water
kaikudo4 years ago
OMG that look good 0_0 i would marry the guy who give me some of that XD will not really but close enough LOL :3 sign if only my family wasn't so Asian i would be making them right now ):
My family's Asian (Chinese Malaysian) and we're big bacon fans, why aren't yours? =D
We are D: my brother and i loves it but my mother is all like is no good for u ):
sderyck kaikudo4 years ago
Bacon's actually relatively healthy when you cook it in a pan, especially when you allow the grease to escape (such as here), so these are... well, not exactly healthy, but a bit further away from walking heart-attack.
Actually, the purported link between saturated fat and heart disease has been thoroughly broken. And the link between carbs and heart disease is gaining strength with every new study.. SOOOOO in actuality, these are probably much healthier than the chocolate alternative :)
use turky bacon for hers :)
I hate turkey bacon.
Sean B -
ipad alternatives
Snellingkorey5 months ago
pretty clever, but drilling holes in the cake tin is a bit excessive!
Haha very good Korey!
davidbarcomb7 months ago
Those look great. I will definitely going to try this. Thanks!
aj123ps49 months ago
Who loves BACON???
I do!!!!
1-40 of 224Next »
