Balance board for sports training and general fun!
this ible will show you how to build your very own balance board to almost the exact same dimensions of the leading brands product (think surfer nickname for indonesia). however instead of costing you GBP 80 or howaver many dollars that translates into it will only cost you the basic materials and a few hours of projecty fun.
Props to my man Sam Noyoun for the idea, check out his video, he made it first im just adding my angle with a few more building tips and tricks allong the way.
also check out my new group - Surfer's Paradise
Disclaimer
this is a relatively cheap and easy instructable but the use of power tools comes with a risk as does working with MDF so wear a mask and if possible goggles whilst cutting, drilling and shaping the wood. likewise, the finished product, like most fun things, is a little dangerous. use a little common sense and use your balance board in an open area. if you break yourself or expensive items around you - you have been warned
Step 1Hunt and gather - things you'll need
Hunt and gather - things you\
MATERIALS
- wood - i used cheap MDF from my local DIY store, check the pic for dimensions
- 6 small bolts and nuts long enough to fit through the thickness of your wood x 3
- Wood glue
- An unopened 2 Litre bottle of coke or similar
TOOLS
- a Template - use mine for exact dimensions or experiment and make your own
- a jigsaw with wood cutting blade or a hand saw and a lot of patience
- a drill
- a screwdriver and ideally a countersink
- a hammer if you need it
- a metal hacksaw (or dremel)
- a G-Clamp or similar
- a plane and/ or sandpaper
- a facemask is using MDF as fibers in your lungs is very dangerous
4 comments
Apr 25, 2010. 5:54 PMjlew says:
 I used 4-6 inch PVC pipe (depending on length of balance board), wrapped in duct tape.  This was strong and durable.  The added height of the roller will allow for more play in board.  Add a stencil and some textured paint for the finishing touch. NICE!
Apr 2, 2010. 6:19 PMspencerjackson says:
Hey, this is nice. I practice all the time on my core fitness wobble board ... but much better to make your own.
Nov 11, 2008. 11:06 PMduck-lemon says:
A-nice
Aug 15, 2008. 8:02 PMTeacherOfTheWays says:
very cool!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:Chard
i love what the comedien Danny Wallace refers to as "Boy Projects" which is pretty much what this site is about!
