Props to my man Sam Noyoun for the idea, check out his video, he made it first im just adding my angle with a few more building tips and tricks allong the way.
also check out my new group - Surfer's Paradise
Disclaimer
this is a relatively cheap and easy instructable but the use of power tools comes with a risk as does working with MDF so wear a mask and if possible goggles whilst cutting, drilling and shaping the wood. likewise, the finished product, like most fun things, is a little dangerous. use a little common sense and use your balance board in an open area. if you break yourself or expensive items around you - you have been warned
Remove these ads by
Signing UpStep 1Hunt and gather - things you'll need
- wood - i used cheap MDF from my local DIY store, check the pic for dimensions
- 6 small bolts and nuts long enough to fit through the thickness of your wood x 3
- Wood glue
- An unopened 2 Litre bottle of coke or similar
TOOLS
- a Template - use mine for exact dimensions or experiment and make your own
- a jigsaw with wood cutting blade or a hand saw and a lot of patience
- a drill
- a screwdriver and ideally a countersink
- a hammer if you need it
- a metal hacksaw (or dremel)
- a G-Clamp or similar
- a plane and/ or sandpaper
- a facemask is using MDF as fibers in your lungs is very dangerous
4
comments
Add Comment
Add Comment
