Balanced Piezo Contact Microphones
Published
Introduction: Balanced Piezo Contact Microphones
About: I am creating interactive installations and performances. Inviting the spectator to participate in various ways I use any media possible to bring "the idea" to life. Electronics, computers, wood, rope, wat...
At the illutron art ship, we are using a lot of piezo elements to make contact microphones and hydrophones (underwater microphones)
Piezo elements can be a noise nightmare. And if you are using the piezos for hydrophones, to capture underwater sound, the noise can be even more challenging, unless you get everything very well sealed.
We came up with a trick, to get a balanced signal from piezos:
Simply using two piezo elements sandwiched, back to back, you can generate a balanced signal, that will be completely noise free.
Step 1: How to Make It
You need
  • 2 normal piezo elements
  • Microphone cable
  • XLR plug
Connecting
  • Sandwich the two piezos "belly-to-belly" (crystal and wires in, metal out)
    • We just use a wad of normal silicone sealant in-between the piezos (Think Oreos)
  • Join the two (black) wires from the capsules and connect to Gnd on your xlr / microphone-cable
  • Connect the centre wire (red) from piezo A to + (hot) and the red from piezo B to - (cold) on your xlr / microphone-cable
  • Connect a XLR-plug to the other end of your cable
Step 2: Try Your Noise Free Contact Microphones
Plug the xlr-connector into the balanced input of a mixer or recorder, and enjoy the crisp clear noise free sound from your piezos.
This is a recording we did with two balanced piezos mounted on pieces of burning firewood.
Headphones are recommeneded - Enjoy! :-)
Experience so far
  • The sound from the piezos are very clear and noise free
  • The oscilloscope have verified, that the output truely is balanced
  • The piezo microphone is very sensitive and responsive.
As hydrophones
I tried this piezo-design out as hydrophones. I could just stick them in the water and get sound. I didn't even care to waterproof them, and they worked perfectly and noiselessly under water too.
So, for quick and dirty underwater microphones, just sandwich two piezos like this and dump them in the pond.
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Creative Misuse Contest
    26 Discussions
    I did the soldering, then didn't have silicone so stuck the piezos together with blue tack and it works, finaly a buzz free sound, thanks a million!
    I was wondering, it is important to make sure that the metal discs don't touch each other, isn't it?
    We have done different configurations - Sometimes back to back or side by side with the two piezos. As MikB points out - The most important thing is, that the white disks does not touch each other in the middle.
    Our reasoning for putting the metal disks outside and to ground was, that this would effectively extend the cable shield all the way out and around the piezos, giving the best possible protection against noise.
    Yes it is: As shown above, the gold/brass discs are electrically connected to each other as "ground". But when physically mounted, the "white" discs are apparently next to each other. If these touch they will short out the signal.
    ApoC2
    1 year ago
    Hey there,
    Awesome project and really stunning results!
    I'm trying to use the piezo on my guitar (classic guitar {non-electric}) and welp, I'm getting hell loads of noise, I've seen that when people did it on their guitars, they pre-amped, could that be the reason? Should I make a pre-amp circuit? (I don't know if it would help increasing the picked-up melodies as well)
    I'd really appreciate any possible help, and thanks a lot in advance!
    (and anything else should I keep in mind as a piezo newbie? :D)
    First make sure you can get the piezo working noise-free outside of the guitar.
    And make sure you connect the piezo to an input that is actually a balanced input. (xlr-input)
    Usually the noise comes from some part of the piezo electrically connecting to something, picking up 50Hz noise.
    What kind of noise do you get? Is it 50/60Hz line noise or other?
    Hope you get it working :-)
    Nice bit of lateral thinking: The output from a piezo is very high impedance and so very easy to interfere with. The normal way to solve this is to put a preamp right there with the piezo, to give some "robustness" to the signal. This solves the problem in a different way.
    It's like a humbucker pickup technique, but not using magnetics!
    This is more than lateral thinking, it's lateraly balanced thinking! :)
    -deef-
    2 years ago
    Hi there! I just came across this instructable and think this is exactly what I'm looking for. I'm amplifying the sound of a very large and heavy rock wobbling on a stone tile. The sound this produces without any amplification is already quite loud.
    At the moment I'm trying to figure out what kind of preamp I'll need. Can someone tell me how to choose the right preamp for the kind of sound I'm amplifying?
    Thanks in advance!
    Regards,
    Dave
    One great tip I learned from <a href="http://www.nicolascollins.com/handmade.htm">Nic Collins</a> is to dunk the piezo and lead wires in some Plasti-Dip. Two coats is what he recommends. It makes the whole apparatus water proof, protects those delicate wires that are soldered to the piezo, and has surprisingly little effect on the response of the microphone.
    This is just the way the piezos we use came from the manufacturer. It's a simple plastic ring. I have used the method described here with the piezos without the plastic ring, and it works equally well.
    What would happen with the performance if you were to mount the piezos back to back (metal side in)? I think it would greatly simplify wiring because both metal backs are touching, but I don't know if that would make the piezos not perform well.
    Well, we just have to try it and see, I guess :-)
    But I don't think it will have any influence on the sound. I have placed the two piezos side by side in some setups, and it was just as good as back-to-back.
    - My reason for putting the metal side out is from a mechanical aspect. The crystal exposed on one side are quite fragile and sensitive.
    I just felt that it would give a better mechanical protection having the metal side out.
    I guess if you applied some other form of mechanical protection to the crystal side, having the crystal facing out would be just fine. :-)
    Hi. I'm trying to record heartbeat sounds using the piezo element. And I want to record using my computer. Can I use a XLR to 3.5mm converter? Also what kind of preamp would be necessary when I want to connect to a computer.
    Thank you :)
    Nikhil
    Hi Nikhil - If you want to use the piezo to record heartbeats, you should get a good preamp before sticking it into the computer.
    If you want to gain anything from the balanced signal, you should choose a mixer with balanced inputs (like xlr)
    Personally I use a small Soundcraft mixer for my recordings. Finding a mixer with low noise on the inputs can be a challenge. Some of the small Behringer mixers are really a nigthmare of noise.
    I would try to find a used mixer of good quality on ebay, if your budget is restricted.
    Good luck with your recordings :-)
    Heartbeats? I'd get a stethoscope (it's cheap) and a mic capsule (condenser one, probably, so that means add a 3v plug in power) that fits into the tube.
    https://rockoys.wordpress.com/2013/09/09/electronic-stethoscope-2/
    Hello chrlilje,
    It's really a simple and great idea !
    Don't you think the sealant is a bit too soft and might absorb a significant amount of the vibrations ? Wouldn't a stiffer material like epoxy glue be better ?
    Thanks!
    I can very well imagine, that "something harder" between the two elements would be better. Would love to try it out. :-)
    I just always end up using some sort of silicon based sealant, because that means "Done in 5 minuter" - where epoxy-stuff means "Done in 20 hours"
    So far I think the biggest issue at all with these comes from the piezo elements themselves. The ones we use are from a random China-batch, and we don't have any specs on harmonic response etc.
    Hello...! Great idea.... Since you are in to Arduino, I have to ask you for help using your Piezo elements on our ROV ,at 380 meters waterdepth. Do you also have an idea of how to transfer signals from the piezo elements, via rs232/485 ,and to a computer or amplifier? I would like to be able to listen to the subsea equipment ,and hear how noisy our Magnum ROV is underwater :)
    Hilsen Kjetil
    Hi Kjetil - Looks like a magnific piece of ROV you got there :-)
    I actually would not be surprised, if the signal from the piezos would be able to travel the full 400 meter of cable, if you mount them in this balanced configuration.
    I don't know how many leads you have available in your umbilica, but if you have a spare twisted pair, I would just use those and send the audio through those.
    If you need to boost the signal, then I would suggest you getting a line driver, maybe even an active line driver, powered.
    But, one of my friends have used piezos at I think 800 meters of cable, so give it a try the simple way first.
    Good luck with it, and do share your experiences! :-)
