Balancer Tools for Self Tightening Propeller (using Unused Tamiya Rollers)
2,160
16
Published
Introduction: Balancer Tools for Self Tightening Propeller (using Unused Tamiya Rollers)
About: Designer, Artist, Engineer
I wonder, how many of u ever playing a tamiya... and how many unused spare part of it left behind... i just found my tamiya bumper roller and i tough i could make it for a balancer tools for self tightening propeller such a DJI 9450 prop or else... i need this balancing tools to reduce jello effect on my Quadcopter and basically it work like a dubro balancer...
what u need is:
4 x tamiya roller like http://www.tamiya.com/english/products/94739rolle...
and 4 x sort 4mm diameter screw...
Step 1: Prepare Your Tamiya Roller
Take out your tamiya roller from bumper...
try spin the roller, if it not smooth than don't use it...
Step 2: File to Print
download 3D files from
http://www.thingiverse.com/thing:2122808
and print it.... i use 40% infill for it, that's enough for it...
Step 3: Roller Holder
Put the roller to the roller holder.. like picture above...
PS: u need two of this
Step 4: Balancer Stand
Put the roller holder to the balancer stand, the one of roller holder in the back is upside down (the hole is below the roller)
Step 5: Propeller Rod
Put the rod in the hole and put the propeller on it... one side of the rod is CW and the other side is CCW
PS:Sand paper the surface of the rod which contact to the roller, more smooth are more better.
or u can use any other cylinder tube to replace the rod...
Step 6: Ready to Use
Try to move the propeller lightly CW & CCW, if the propeller is falling down than using sand paper try to reduce weight from the falling propeller leaf. than try to lightly move CW & CCW again.
if the propeller is steady or nearly steady enough in the middle than it balance...
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
