Step 3Bending rods
In the beginning I put the tip of the rod through the rim's valve hole, hammered it down then wrapped the rod around the rim and cut the bent tip off (picture 2). Later I found that if the valve hole allowed it was much easier to hold the rod with a vice grip, leading to a smother bend and less wastage (picture 3). Then using 3 vice grips I laid the rod in the rim, the first one not being removed. The next two leapfrogging each other so as to pull the rod into a nice ring correctly (picture 4&5). Cut off the extra bit, clamp it and weld (picture6). Take it off the rim and smack it till all the kinks are out.(7)
Add Comment
