Ball Sander
1,774
9
Published
Introduction: Ball Sander
About: I am a senior laboratory technician in a analytical facility by day and by night I make and fix things. I prefer to work with wood but will give anything a go. I also enjoy gardening and an kept busy by my ...
This instructable is for a simple ball sander used for sanding inside deep turned work on a lathe, which is much safer than putting your fingers in.
I have assumed knowledge of woodturning tools.
WARNING: I am bilingual in my use of measurements so expect mm and inches
Materials and Tools
1x bouncy/rubber ball about 30mm diameter
A length of M8 threaded rod about 40cm long
2 x M8 nuts
1x small piece of timber (1 3/4" x 3")
Epoxy glue
A square of the hook side of Velcro (enough to cover the ball)
A lathe and tools
A file and vice
Scissors
8mm bit and something to use it in
Velcro backed sand paper
Step 1: Wooden Coller
  1. Take the piece of wood and mark the centres on each end.
  2. Drill a 8mm hole through the wood blank. I had to drill from both ends ,if you do to take care to line the hole up carefully. (My screw chuck requires a 8mm hole to mount to it and this is also the hole size needed to pass the threaded rod through)
  3. Mount the blank on the screw chuck, I have also mounted a sacrificial disc in front of the chuck to save my tools from hitting the chuck.
  4. Turn a cove into the end the same contour as the rubber ball.
  5. Turn down the sides to a taper ensuring the thin end is still a little larger than the M8 nuts
  6. Sand and part off
Step 2: The Ball
  1. Carefully drill a 8mm hole about 10mm deep into the ball (only use light pressure when drilling)
  2. Epoxy the rod into the ball and clamp until dry
  3. Using epoxy, glue the Velcro to the ball covering it as best as possible (its a bit fiddly)
Step 3: The Rod
  1. Put the collar and nuts onto the rod (important to remember this as they will not go on afterwards)
  2. File about 40mm of threads off the bottom of the rod to help the drill chuck jaws hold when using the sander in a drill
Step 4: Finishing
  1. Cut a square of sandpaper and cut a square out of each corner so you are left with a rough cross shape.
  2. Wrap the ball and secure all the ends with the collar and lock in place with the nuts.
  3. The sander in now ready for use either in your hand or slowly in a drill
Note: Always sand on a low speed lathe settings and rest the bar on the tool rest for support.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    Be careful and don't pull the trigger without it being up against your project or it will whip on you. Take a baseball and cut the threads, that way you can see the pattern giving you a better idea of how to cut your sandpaper, I would also wrap some tape around the all thread so it doesn't scratch your project. Besides that I like what you did trying to solve a problem that a lot of people deal with on the lathe.
