loading
This is a fun and easy project to make. The goal is pretty simple: remove the large ball from the puzzle. You might notice that the solution is similar to the puzzle I made a few weeks back. As for materials, I used a scrap piece of wood, excess wood beads from the last project, paracord and a plastic ball that I scavenged from the kids old toy box. Note that I'm not the originator of either of these puzzles. I understand these types of puzzles have been around for 500+ years before patent protection :).
Unfortunately, I give away the solution while showing how to make the puzzle. As a challenge, try to figure it out from this picture. Once you are done or give up, watch the video to see the puzzle being solved and how to reset it for the next person.
Step 1: Tools/Materials
Tools:
  • Saw
  • Drill or Drill Press
  • Drill Bits (1/2" and 1")
  • Sander
  • Ruler
  • Pencil
  • Scissors
  • Lighter
Materials:
  • Wood: 6" Long, 2" Wide, 1/8" to 3/4" Thick
  • Paracord: 5/32" Diameter x 36" Long
  • Wood beads: 3/4" OD, 3/16 ID (x2)
  • Ball (1.5" Diameter) or Block (1.5" Cubed), 1/2" Hole Through Center
Step 2: Block
Cut a block to 6"x2". Thickness doesn't matter. I used a 3/4" thick piece of wood. Drill holes in block as shown. Sand to break sharp edges. You also might want to chamfer/round the holes to allow the cord to slide freely.
Step 3: Feed String Through First Hole
Step 4: Feed String Through Middle Hole
Step 5: Feed String Through Last Hole
Step 6: Counterbore Beads
I used a drill to add counterbores to one side of each bead. These were needed to capture the knot in the paracord. Note that this picture is showing both sides of the beads.
Step 7: Place Beads Over Ends of String
Tie a knot at he ends of the cord. Press the knots into the counterbores. Cut any excess string. Use a lighter to sear the ends of the string.
Step 8: Puzzle Is Now Ready to Add Ball
Step 9: Pull String Out As Shown
Step 10: Feed String Through Ball
Step 11: Feed String Through Hole on Beaded Side
Wrap string around bead.
Step 12: Pull on Ball
This will pull the loop through the hole. Twist string to the opposite side of the beads to add more deception.
Step 13: Final Pictures
Enjoy your puzzle!
Step 14: Similar Version
The previous version is shown here.
<p>Here is a variation on this puzzle. One more step to solve.</p>
<p>Nice variation. Drilling a hole through a golf ball was pretty clever as well.</p>
<p>Thanks for the inspiration...again!</p><p>3D print version. As with the earlier puzzle, it's less manual skill to make, smaller, and so, easier to carry in a pocket! You've done it again. Great instructable.</p>
<p>That's cool. I want a 3D printer!</p>
About This Instructable
10,782views
85favorites
License:
Bio: I like to design and build random things.
More by mtairymd:Raspberry Sherbet Deer Repellent Bags Captain America Shield Fidget Spinner
Add instructable to:
