For this instructable you will need (ideally):
Apple Pro Speakers
2 beers
a 12v motor with a shaft diameter not bigger than 1/8" and a housing no deeper than 2" (The ideal motor should have 3 or 6 threaded holes on the output side. The one I used was a samsung capstan motor from a trashed video deck. The most important things are the threaded holes)
fire
Wire cutters
a rubber band
a big nail
super glue, or really, really good glue, let's not get too high on ourselves now
a reamer-like file (I used an old phillips screwdriver, I had time to kill)
bolts that fit the threaded holes on your motor
a 9-volt battery
a 9-volt battery connector with useable leads (see parts source in the next item)
on-off switch (destroy one of your, or your friends' children's battery-powered toys - they need to use their imagination more anyway!)
wire
soldering iron (or you could forgo the switch and soldering iron and just twist everything together)
a wheel from the toy you busted up - minimum diameter 1 3/4"
1 bottlecap leftover from your Laptop stand from 4 bottlecaps
3 nails or other hard, metal, pointy things
3 arms
Remove these ads by
Signing UpStep 1Disassemble the Apple Pro Speakers
I love the design of Apple products and it's a shame to have a big plastic ball that's kinda pretty just sitting around doing nothing. The same could be said about a big plastic cube as well (see pic).
Keeps a 40 year old father of 2 entertained.
Keeps my restless hands busy for the duration of 2 beers.
Further demonstrates my love of Apple products.
Gives me another thing to stick an LED into in the future. CRAP! I knew I forgot something! Pics or video of the BALL OF DEATH for the nocturnally visually impaired will be on their way shortly!) - Thanks w00t!
If that doesn't work....
1 sec. - I turn it on.
3 sec. - I turn it on it's side and it flops around in a circle until it settles in an upright position at about 6 seconds.
7 sec. - I invert it completely and set it spinning again. This time it stays spinning through the remaining 5 seconds.
There, now you don't need to see it. :)
