Ballista Project 2017
1,281
8
4
Posted in PlaySiege-engines
Introduction: Ballista Project 2017
About: Hello, My Name is Matthew, I have 8 (almost 9) siblings. I LOVE Woodworking (DIYing) me and my family made a string quartet and we Love music. My Grandpas are both Woodworkers and they work with me on some o...
I've wanted to make a ballista for a long time but I couldn't find the instructions online so I ended up deciding that I should make one just from a picture, Then I thought that I could make instructions so other people could follow my instructions and make their own ballista.
Step 1: Tools and Material Needed
Tools Needed:
Tape measure
jig saw
Miter saw
Drill
Hammer
Sander
Material Needed:
Plywood
2 x 4
Rope
1.5 inch thick wood
1.5 x 3 inch wood
and a ARROW!
Step 2: Making the Bottom
Cut a piece of plywood 28 x 11 inches.
Then sand it.
Step 3: Making the Top
Measure a piece of wood 28 x 11 then put a roll of tape on the wood the middle should be at 24 inches from the end of the wood (as shown in photo). Put a straight stick next to the tape and draw a line by it.
Then cut the piece out.
Then sand it.
It should turn out like the photo.
Step 4: Making the Sides
Cut out four 14 x 7 x 1.5 inch wood.
Set two aside. Take the two pieces you did not set aside, Measure halfway on one side of both pieces wood. Then make a half circle the middle of the circle should line up with the middle of the wood (as shown in photo).
Then sand all the pieces.
Step 5: Making the Arms
Cut Two pieces of wood 28 x 2 x 4.
Then sand them.
Step 6: Making the Middle
Cut a piece of wood 49 x 3 x 1.5 inch.
The use a router to carve out the middle.
Then sand it.
Step 7: Screwing the Sides to the Top and Bottom
Screw the sides to the top and Bottom. The first piece of wood should be 1 inch away from the end of the Top and Bottom. The second should be 8.5 inches away form the end. Then the same on the other side.
Step 8: Rope!
Cut holes in the top and bottom piece of wood. Then loop rope around two pieces of wood as many times as you can then tie the ends to the other rope.
Step 9: Making the Rope Into Springs
Stick the 24 x 4 x 2 inch wood into the rope. Then use a hammer to twist the wood that the rope is raped on. Then go to the other side of the rope and do the same. the tighter the better.
Step 10: Screwing the Middle Piece on to the Bottom
Cut the Three pieces of wood to fit in the middle hole. Then screw the three pieces of wood into the bottom one at a time, then screw the middle piece on to the third piece of wood. Putting the three pieces of wood there will make the middle piece be at the level of the arms.
Step 11: Tying Rope to the Ends of the Arms
Drill a hole in the ends of the arms to make room for the rope, Then tie a knot at the end of the arms with the rope.
The rope should be tight.
Step 12: Done!
You are now done!
Put the Ballista on something then start firing.
If you liked it, don't hesitate to leave a comment or even vote:)
Make It Fly! Contest 2017
Second Prize in the
    • Make it Move Contest
    • Spotless Contest
      Spotless Contest
    • Outdoor Fitness Challenge
    4 Comments
    Wow! That is really amazing that you made it and it works super! Now you can really shoot arrows far! Where will you keep it? Great job, MattheWe're so proud of you!
    Very clever! It's cool to see how you put this all together, and then to see it working. Nice!
