Balloon Rocket Car
Published
Introduction: Balloon Rocket Car
A rocket is simply a chamber filled with pressurized gas. A small opening called a nozzle allows the air to escape, causing thrust that propels the rocket. You can demonstrate this when you blow up a balloon and let it go without tying it off. The balloon will fly through the air as all the air inside escapes.
Materials
•16-20 oz. plastic water bottle
•Drinking straws
•Wooden shish-kabob skewers
•4 plastic bottle caps
•Balloon
•Duct tape or masking tape
•Nail, hammer, knife, scissors
Procedure
The water bottle forms the chassis, or body, of your balloon car. You can start by mounting the wheels on this body.
1. Cut a drinking straw into two pieces as long as the water bottle is wide. Use strips of tape to attach them to the bottle - one near the front and one near the back. The axles for the wheels will run through these straws, so line them up carefully so the wheels won't be crooked.
2. Use a hammer and a small nail to poke holes through the center of four bottle caps. Cut two pieces of a wooden skewer about an inch-and-a-half longer than the pieces of straw you taped to the bottle. Push one end of each skewer through the hole in the center of a bottle cap. If the cap doesn't fit snugly on the skewer, use some modeling clay to hold it in place. Next, thread the skewers through the straws on the bottle and attach the other wheels to the other ends. Make sure your car rolls smoothly.
3. Stretch out a large balloon by blowing it up and then letting the air out of it a few times. Next, make a nozzle. The size of the nozzle is very important. If it is too small, the air can't escape with enough force to propel the car forward. If it is too big, the air will escape too fast and the car won't go very far. Create the nozzle by taping four drinking straws together. Insert the straws into the mouth of the balloon and seal the opening by wrapping a strip of duct tape around it several times.
4. To mount the balloon/nozzle on the car, use a knife to cut two perpendicular slits (to make an X) in the top of the car about 4" back from the mouth of the bottle. Thread the nozzle through this opening and out through the mouth of the bottle. Leave about an inch of the nozzle sticking out of the mouth.
5. Find a hard surface, like a long table, linoleum floor, or sidewalk. Blow up the balloon through the straws at the mouth of the bottle. Pinch the base of the balloon to prevent the air from escaping too soon. Set the car down, let go of the balloon, and watch it go!
    • Pets Challenge
      Pets Challenge
    • Make it Move Contest
    3 Comments
    Content stolen from http://www.hometrainingtools.com/balloon-rocket-car-project/a/1346/
    Fun! What kind of things might someone learn from doing this project?
    The first thing that comes to mind is Newton (as in Sir Isaac): For every action, there is an opposite and equal reaction. There is also potential vs. kinetic energy. There is also "work." And check out The Second Law of Thermodynamics.
