3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bamboo Bike #2
Bamboo Bike #2
  • last photo ←
Why bamboo - why a bike -
2 passions I have are fitness - primarily cycling, and well, gardening and anything that comes from the ground.  In my garage you'll find bike parts and bikes in different stages of assembly/disassembly, and in my yard, palms, bamboos, flowers, oh yeah - and more palms...
Bamboo bikes are just cool.  I've found a way to incorporate my passions, plus recycle unused items and come out with an end product anyone can enjoy - whether it's just looking at it or riding.
GETTING STARTED - I am just under way on this project, and will document this from the beginning with photos, so that this instructable is, hopefully anyway, easier to follow and better described than my last.  Last time, I came to the instructable having finished my project, trying to go from memory, and axplain what I'd done several weeks before.  This time I will update, both photos and commentary, as I go.
WHAT YOU WILL NEED
Raw Materials -
Bike frame -
Aluminum, Carbon, steel, titanium, scandium, boron carbide - I've found many places to get wrecked/damaged bikes - local bike shop, yard sales, friends, in your own garage!
Bamboo - Blue Hennon Timber Bamboo - is thick and very strong, but several other species will work just as well, and may give you a different look.  I used this gal her name is Charlene - http://myworld.ebay.com/rainbowsatoz/ There are other bamboo suppliers in the US, but stay away from Big Bamboo Company - Terrible Customer Service.  Completely blew me off - perhaps my order of 5 bikes worth of bamboo was too small, and he didn't want to waist his time.  When business kicks off, I guess I know who I won't buy from!
Carbon string/tow - A quick Ebay search of Carbon Tow brought up these guys -  http://myworld.ebay.com/creative-ds/ and a quick Google search -  http://www.fibreglast.com/showproducts-category-Carbon+Fiber+Fabric,+Tapes+&+Tow-15.html You can get 3K, 6K and 12K.  I probably used about 1500 - 2000 feet of carbon on the first project.
Resin - A good resin is key to this project.  I used this - Max CLR - hp - from these guys (also on ebay) http://myworld.ebay.com/polymerproducts/ Here again - I probably used about 1/4 gallon resin/hardner on "Project Uno" - but much of it, perhaps as much as half, was wasted.
Misc. Small Parts - Things like cable stops, brake bridges, tubes if you want them - Nova Cycle Supply -http://www.cycle-frames.com/bicycle-frame-tubing/BRAZONS-SMALL-PARTS/ - Careful though with small orders - they will charge you a fee for an order under $50, just a head up!!!
Finishing Stuff - Clear coat, colored paint if you wish, wood stain (again if you wish), misc. rags, Tung Oil Finish, carnuba (car) wax - any kind, I like Meguiars Gold Class...
Misc. Bike parts - depending on what level of build you want - fixie, mountain bike, roadie, etc...  But you'll definitely need a fork, headset, crankset, brakes, bars, and pedals at the very least!
Tools -
Plumber's torch - for the heat treating of the Bamboo
Gram Scale - To measure accurately the resin and hardner mixture
Dremel multi-tool - This is a huge part of what I do with this project - from cutting apart the old bike frame, to sanding bits, to the final finish the Dremel Multi Tool is my main go to item!
(Note, Carbon Fiber/Fibre dust is SUPER irritating to the skin, and mucous membrains of the mouth, nose, and throat.  But, also will destroy your Dremel tool!  Dremels have a couple of openings where the engine sheds heat.  These also are a point of entry for carbon dust to go directly into the motor.  You should over these with some sort of filter, cotton face pad, something, to keep the dust out.  I've been making several bikes over the last many months, and was going through about one multi-tool a month, before I decided to cover the holes.)
Die Grinder/Angle Grinder - For cutting
Sand Paper - 100 grit, 220 grit wet/dry, 600 grit wet/dry
Measuring device - Tape measure, yard/meter stick, etc...
Marking Pens - for marking cuts
Assorted Rasps and Files - round and flat
UPDATE - RE: Galvanic Corrosion
I've been reading alot about this Galvanic Corrosion lately, as I plan on building bamboo bicycles as a business...  It appears that Galvanic Corrosion can present a problem with the bond between Aluminum and Carbon Fiber.  This is shown primarily in aerospace.  Having some experience, though limited, with carbon and aluminum in cycling, MANY manufacturers combine the 2 substances with little or no problem over the typical life cycle of a bicycle.  In aerospace, you have tremendous and dramatic changes in temp and humidity in a short period of time.  This interaction of the elements on the two materials not only causes issues with galvanic corrosion but since the coefficent of thermal expansion is also very different for carbon and aluminum there are expansion issues there too.  Delamination is destined to occur under these circumstances.  Titanium is the best material to bond to carbon as their coefficent of thermal expansion is almost identical.  Also Titanium is incredibly resistant to corrosion of any kind - thus it's use in aerospace and in internal medicine.
If you are concerned with this being an issue with your ride, you can use hemp in place of carbon, or use titanium lugs rather than aluminum or steel (did I mention expensive!!!).  You can also utilize a carbon frame and take the exact same steps as outlined in this instructable and have none of these issues.
But after going into all that, most of us don't have 100 degree F swings in temp over a short period of time (minutes) and at the same time have insane swings in humidity, like an airplane experiences.  I would dare to say, neither thermal expansion, nor galvanic corrosion will have a tremendous affect on what we are building.  Remember - you don't HAVE TO BUILD ONE OF THESE!  But, it sure is a whole lot of fun!  Good luck all!!!!!!!!!!!!!
See this - http://www.bikeforums.net/archive/index.php/t-222592.html for a conversation on aluminum and carbon...  After reading it, it basically says the same thing.
Step 1Prep and begin
Initial step is to make sure you have all items to get started.
Once you've done that, and you have your bamboo, you can begin the heat treating process.  I used the plumber's torch method.
WARNING - Make sure you punch out the nodes inside the bamboo prior to the start of heating your pieces or you'll be in for a very loud surprise - bamboo WILL EXPLODE if you do not do this!  Between nodes is a pocket of air that if heated has no where to go under expansion, the build up of pressure will cause the cane to burst.  It's fun, if you're face isn't right next to it, as mine was when I discovered this little secret!!!  Also heating bamboo gives off a certain smell and will kind of make you sick to your stomach (me at least).  Don't do this inside, do it somewhere with plenty of ventilation!
Take the torch and run it along the bamboo about 3 inches at a time while turning the bamboo slightly.  You can take the bamboo to whatever color you are happy with at this point.  I chose to go pretty dark, even burning the bamboo in a couple of small spots - not badly though.  Don't stay in one place too long or your bamboo will burn badly or split  due to uneven heating and shrinkage in that one place.  Slow, smooth and easy...  Use a couple of test pieces to get started, but once you get the pace down, the flow begins to make sense, and the rest is quite easy.
As others have stated, the reason for heat treating is to cook the sugars in the grass (bamboo is a grass) and carmelize them for strength and rigidity.
NOTE - Remember to go a little darker than you expect, or want, the final product - you will be sanding the canes and removing a good portion of the darkened surface to reveal a lighter shade below.
148 comments
1-40 of 148next »
Jan 14, 2011. 8:23 PMfinky says:
You should totally offer classes on construction of these bad boys --
definitely the "next big thing" I think --
I'd buy one and/or attend a class.
Mar 12, 2012. 9:06 AMcletero says:
Hi, great frame and specially like the lug color! Nice job! I'm toying with the idea of building my own carbonfiber bike and already have all CF tubes taked together with epoxy, but am stuck on how to reinforce the jonts. I would like to use this carbon fiber tow technique, but would like some ideas on what pattern to use around the joint, specially for the bottom bracket. I would appreciate any comments or help with this issue. Thanks!
Mar 13, 2012. 11:02 AMcletero says:
Hi, I will be checking the videos inmediately, thanks!! As for the carbonfiber tubes, I got them from RockWestComposites (http://www.rockwestcomposites.com/browse/bicycle-carbon-frame-tubing) , they have bicycle specific tubesets but no chainstays (only seatstays) although I believe Calfee and Parlee use the 16mm seatstays as chainstays (because their chainstays look too thin) so I ordered them as well (hope this made sense!). I also contacted Joe Bringhelli at www.bringheli.com who has dedacciai carbon tubing, a little lighter than the Rockwest but more expensive, but he can get only the rear triangle for you (Firebox quoted for about $275, I believe). I decided for the Rockwest to get everything from the same place, but now think it would have been easier to use the Deda rear triangle, as it's 2 pieces it's easier to manipulate, center the wheel, and more reasonable diameters, etc.
Hope this helps
Ciao.
Jan 24, 2012. 12:34 PMcosmopuli says:
I used your instructable to build my first bamboo bike. It is awesome and I thank you for taking the time to make my first attempt easier than it would have been. I am planning on making more and would like to speed up the process by using the west marine epoxy and hardener. The max clr looks nice but, takes way to long to cure. I spent more time waiting for the epoxy to cure than I did building the bike. I know you now prefer to use the west systems 105 epoxy. My question is which hardener did you use? Was it the 205 206 or 207? What did you use for your heat source? I learned a lot on how to maximize my time and speed up the process with my first build. The only thing slowing me down now is the epoxy. Thanks so much for your help. Thanks to you I am now the proud owner of a self built bamboo bike and my wife and friends will be able to join the club too.
Jan 25, 2012. 7:55 AMcosmopuli says:
I have another question for you. Where do you recommend I look for Campy or Ultegra groupsets? I really want to build up my roadbike with good components. Any help sourcing the groupsets at a reasonable price would be greatly appreciated.
Jan 25, 2012. 7:43 AMcosmopuli says:
Thanks for your fast reply. My first frame has been built up into a beach cruiser as I live at the beach. I will be building my next frame into a road bike. I will post some pics soon. I think I will go with the slower hardener because even though it is winter here, we have been getting plenty of 60-70 degree days. It's amazing how much you can learn from your first build. I learned which tools and techniques work for me. Have you moved onto using a jig yet? Is your business under the radar or are you trying to go legit? I ask these questions because I'm interested in the business side of things as well. I figured going legit would pose some issues, insurance being the biggest. Thanks for your help and your detailed answers. I love to build stuff and this has been really fun and rewarding.
Nov 27, 2011. 4:48 PMScience Swine says:
AWESOME BIKE! Why did you leave the original chain stays though? Does it help with the strength?
Nov 29, 2011. 4:04 PMScience Swine says:
Thanks for the reply! You have been really helpful and I agree with you that it does make the bike look very nice. Thanks for the help.
Nov 15, 2011. 11:27 AMsmalbrough says:
Hi, I have a donor bike that has a tapered seat tube and a down tube that is significantly butted at the head tube for strength. I'm not too concerned about the down tube, my thought was to cut the frame a half inch below the butted area and build as directed. So as far as the seat tube is concerned, do I build up a carbon wrap on the narrow end(seat end) of the existing tube to accept a larger diameter of bamboo, or do I taper the inside of the bamboo on the bottom bracket side?
Aug 12, 2011. 8:37 PMTyler5 says:
What is the difference in 3k, 5k, and 12k tow? I've even seen 48k. Is one preferable?
Jul 24, 2011. 5:05 PMjgilbert5 says:
so when I'm cutting I'm having some splitting about 1/4th of the way through the bamboo and about 1-2 inches long.
Can I still use the bamboo and just wrap more carbon around this split or will it eventually go all the way through and start creeping down?
Jul 15, 2011. 9:00 AMMoritzB says:
Hello, Tanks for your instructable.
But I have two questions left:
Some of my bamboo rods have a few very little cracks.
Do you think that I can build a bamboo bike no matter if I use these rods with very little cracks in it?
Which way of preparing the bamboo is the most strongest? -
Hardening it with a propane torch and leave the walls, that comes after each bamboo segment intact - or hardening the bamboo with a propane torch and make a hole into the segment walls and fill everything up with polyurethane foam?
Can you say what option is better?
Thanks for your answer.
Greeting MoritzB
Jun 30, 2011. 3:14 PMsk8kat says:
you bike is outstanding! what diameter bamboo did you use ? what carbon tow did you use 12K , 6K ..?
thanks for the help
Jun 27, 2011. 4:49 PMTyler5 says:
So do you not compress you joints after freshly applying epoxy and stuff?
Jun 27, 2011. 1:04 PMTyler5 says:
I was looking for resin on that link and I saw that there were different types of resins, you suggested the Max CLR, but would other resins work just as well? I ask because you can buy more for less of some of that other stuff, my suspicion (pardon the spelling) is that the other products aren't as well suited for a bike joint.
Jun 27, 2011. 4:51 PMTyler5 says:
Thanks! I'll check it out.
Jun 23, 2011. 3:58 PMmisguided maker says:
Did you notice any change in the bamboo's diameter before vs. after heat treating, or did it pretty much stay the same?
p.s. Beautiful work these frames, excellent photos/explanations. I cant wait to get started
Jun 24, 2011. 3:39 PMmisguided maker says:
Thanks for getting back to me so quick. I have couple more silly questions before I dive headfirst into this beast of a project.
And they are; were you measuring inner or outer diameter of the bamboo? And if I have a close (but too small) fit, is it safe to shave off a bit (less than 1/8 in.) of the inner core to make a better joint, or does that compromise the bamboo?
To be honest, I haven't even picked any supplies up yet, but I love summer projects and this right up my alley. Can't wait!
Jun 24, 2011. 3:20 PMTyler5 says:
After further studies I have realized you answered all my questions in this instructable. Once again, quite a good instructable.
Jun 24, 2011. 12:21 PMTyler5 says:
Hey! Great instructable, I just read through it the other day and now I'm inspired, but I also have a few quetions:
About how much total Carbon Fiber Tow did you use? And why did you choose Carbon over hemp?
I'm just looking to start small, so could I build a single-speed bike and have the option to make it into a multi-speed later?
And what kind of bamboo did you use?
Jan 29, 2011. 1:24 PMbikelust says:
Hi, i just turned Pro of this just an hour ago just to make a bamboo bike for me. i have a question, i don't know all characteristic of resin but are they all have a strong smell?
thanks
Nov 8, 2010. 1:41 AMbicycletechnocrat says:
Whats the total weight of the finnished frame? Not the whole bike - that will be pretty light anyway due to your Campa Chorus etc.
Did you save weight from the aluminium-incarnation of your frame to the bamboo-reincarnation?
Nov 9, 2010. 11:54 PMbicycletechnocrat says:
Thanks for the info, thats good to know! The only Bamboo-Frame I could lay hands on up until now is pretty badly built, and heavy as f* (seems like something around 2700g - its a road frame). I guess the guy who built it took the next bamboo he could lay hands on. Also he used an excessive amount of epoxy and fabric. Propably because he was afraid and wanted to make it last.
I'll try my own in the next months based on your instructable and post the results.
Nov 8, 2010. 1:35 AMbicycletechnocrat says:
This color is amazing! Nice way of building a Bamboo-Frame without the need for a frame jig!
Oct 31, 2010. 1:20 PMTechnochicken says:
I love the new 29er! The sanded down bamboo looks great. Another note about galvanic corrosion- lots of people who have built bamboo bikes recommend wrapping the aluminum in a layer of fiberglass to prevent corrosion. As you say though, it may well be a non-issue over the lifespan of a bicycle.
1-40 of 148next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:BAMBOOBIKER
