Step 7Building up the joints/lugs
This means building up the joints in virtually every direction, but especially laterally where I will place a great deal of torque at the bottom bracket and upper and lower head tube. To do this I actually cut roughly 6 inch strips of the string - about 25 of them for each lug. I lay them straight across the joint on the side I am trying to reinforce. I then wrap around the this wrapping around the tube then criss-crossing around say the head tube for instance, creating almost an x accross the front of the tube.
Check out photo number 3 below for this on the bottom bracket as well as photos 4 and 5 for the same at the head tube. This process is repeated time and again while doing some random crossing over as well.
As for special treatment, read the part about heat treating to harden the sugars in the cane to make it hardy and change the color. You really musn't skip this step. And absolutely you can do this at home. the only 2 parts I did outside on this project was heat treat the bamboo cane, and paint, and only because I had to! The fumes from both are OBNOXIOUS! Best of luck to you!
Nice job again...The carbon is awewsome just like you sad.My first try with hemp string was a fail,but now with carbon I am really happy.Your instructable is probably the best for a project like this.One thing I discovered really helpfull about wraping is to put carbon fiber on an empty fishing line role and than start wraping.this way you can go continuosly all the way for one wrap without stopping.I hope this will help you in exchange for all the help you give me.
