Step 3Layout the parts on sheets...
It takes about 2.2 sheets. see attached images....
ALso, below find the water jet cutting stats:
Estimated time to make this part: 2.5134 hours
Estimated cost to make this part: $62.84
Estimated abrasive needed: 121.67 Lbs.
Estimated time to make this part: 2.9491 hours
Estimated cost to make this part: $73.73
Estimated abrasive needed: 143.97 Lbs.
Estimated time to make this part: 24.688 min.
Estimated cost to make this part: $10.29
Estimated abrasive needed: 20.43 Lbs.
Around $150....
HERE IN DETAIL:
sheet 1:
Material: bamboo
Machineability: 500
Thickness: 0.7500 inches
Tool offset: 0.0150 inches
Taper offset: 0.0000 deg (0.0000 inches)
Cut stand off: 0.0600 inches
Rotation: 0 deg
Piercing: High pressure | Intelli-PIERCE(R)
Pierces: 65 (0 are wiggle pierces)
Cutting: High pressure
Width of path: 95.9883 (inches)
Height of path: 48.1242
Length of tool path: 2597.8700
Length of cutting: 1940.2480
(Values reported after tool offset applied.)
Pressure and nozzle setup:
High pressure setting: 45000.00 PSI
Low pressure setting: 20000.00 PSI
Mixing tube diameter: 0.0300 inches
Jewel diameter: 0.0140 inches
Abrasive flow rate: 0.8500 Lb/min
Abrasive size: 80.00 Mesh (US Std.)
Abrasive index: 1.00
Feed rate breakdown: (inches/min.)
Ideal linear quality of 1 speed: 34.99
Ideal linear quality of 2 speed: 30.01
Ideal linear quality of 3 speed: 18.83
Ideal linear quality of 4 speed: 13.52
Ideal linear quality of 5 speed: 10.46
Ideal minimum taper speed: 6.27
Definition of "Minimum Taper": 0.00100
Ideal dynamic pierce speed: 23.29
Ideal dynamic pierce length: 0.242"
Time for ideal dynamic pierce: 0.62 sec.
Dwell time for stationary pierce: 14.02 sec.
Average speed for entire part: 17.64
Fastest speed when cutting: 21.17
Slowest speed when cutting: 1.17
Average speed when cutting: 13.56
Total time spent cutting: 143.14 min.
Total time spent traversing: 4.09 min.
Total time spent cycling relays: 3.57 min.
Number of corner passes added: 283
Error mapping is not enabled.
Tilt-A-Jet(R) is enabled.
sheet 2:
Material: bamboo
Machineability: 500
Rotation: 0 deg
Pierces: 68 (0 are wiggle pierces)
Width of path: 95.8210 (inches)
Height of path: 48.0593
Length of tool path: 2941.8500
Length of cutting: 2340.7760
Average speed for entire part: 16.98
Fastest speed when cutting: 22.00
Average speed when cutting: 13.82
Total time spent cutting: 169.37 min.
Total time spent traversing: 3.83 min.
Total time spent cycling relays: 3.74 min.
Number of corner passes added: 201
sheet 3:
Material: bamboo
Machineability: 500
Rotation: 0 deg
Pierces: 4 (0 are wiggle pierces)
Width of path: 75.8726 (inches)
Height of path: 10.5950
Length of tool path: 385.0765
Length of cutting: 312.2366
Average speed for entire part: 15.74
Slowest speed when cutting: 1.75
Average speed when cutting: 12.99
Total time spent cutting: 24.04 min.
Total time spent traversing: 0.43 min.
Total time spent cycling relays: 0.22 min.
Number of corner passes added: 54
Add Comment
