Introduction: Bamboo Picture From a Calendar / Cuadro De Bambu Usando Un Calendario.
I have some gift calendars from an asian dollar store, I didn't need so much calendars even I have some from 2012 I has never used.
But images are nice, with bonsais, gradens, and great wall. So I recicled them to use as wall pictures without calendar numbers and ads from dollar store.
This instructable is a very fast and easy one, no tools are needed, only glue (and a flat surface)
Como tenia varios calendarios de un bazar asiatico y en realidad no los uso (algunos del 2012 han estado guardados un año entero), pensé en darles un uso mas decorativo a las imagenes, que son bastante bonitas, con bonsais, jardines, la muralla china... Asi que os he convertido en cuadros, descartando el calendario y la publicidad de la propia tienda.
Es un instructable muy rapido y facil, no se necesitan herramientas, ni cortar el calendari, solo pegamento y una superficie plana para poder doblarlo y pegarlo
Esta vez no haré los pasos en español e inglés, los haré solo en inglés y un al final en un paso extra un resumen en español. Como ya digo es muy sencillo, espero que con éste resumen y las fotos de los pasos anteriores quede bien expicado.
Step 1: Pre and Post Operaton Comparation.
This is our start point.
One from left is finished one (one calendar from 2012), and the other two are the ones I get this year,
We only need one but i'll like to show the kind of pictures they have.
We'll fold the calendar part instead cutting, cause I want something easy to make.
Step 2: First Fold
First fold is montain fold just where picture ends.
* with montain fold I meant pick the lower part and fold backwards.
Step 3: Second Fold
Second and final fold.
With back side up, take the wodd bar and put it in lower part making a valley fold.
Check folds, and glue both of them.
I don't take photos of glue step, but it's easy to imagine where. The bottom half is 3 layer with, so put glue between them,and let it dry.
Be carefull and don0t use so much glue, glue can flood between straws and stain or even joint calendar to whatever is under it
Step 4: Resumen En Espa�ol
Instructable is already finished, but all my others instructables are in english/spanish.
This is very simply one so instead make steps in two languages, I'll summarize this instructable here in spanish.
Para los hispanoparlantes, y para no perder la costumbre de poner los instructables en dos idiomas, resumo todo aqui, al ser todo muy sencillo y rapido no he querido complicarlo haciendo los pasos en dos idiomas, con este pequeño resumen y las fotos de los pasos anteriores no os costará trabajo entenderlo.
Paso 1 Materias primas
Solo necesitaremos un calendario como los dela foto, el de la izquierda es uno acabado (es mas corto porque es otro modelo, de otro año) los dos de la derecha son los dos que he conseguido este año, como dije solo necesitaremos uno, pero lo puse para que veais el tipo de dibujos que tienen) He borrado el nombre y la direccion de la tienda para no hacer publicidad :P
Paso 2 Primer doblez
Doblar hacia atras la parte del calendario, la de los numeros, (doblez en montaña) justo por la parte de abajo de la imagen. dejando la varilla de madera debajo de la imagen.
Paso 3 Segundo doblez
Dar la vuelta, dejando la parte del calendario visible, y llevar la varilla hasta la parte de abajo, donde hicimos el doblez anterior (doblez en valle). Ahora solo queda comprobar si los dobleces son por donde queriamos (no se ha movido ninguno) y aplicar pegamento para fijar los dobleces, Hay que poner pegamento entre las tres capas que han quedado en la mitad inferior de la foto. No useis mucho pegamento ya que se puede filtrar enrte las varillas del calendario y manchar o incluso pegarlo a lo que tengais debajo.
Un saludo y gracias por leerme :)
Reuse Contest
