3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Band Saw to Pottery Wheel
In this instructable I show how I turned an bench top band saw into a electric pottery wheel. As with most instructable I've read, I worked primarily with what I had laying around the shop rather than off the shelf items, so your result may vary. Regardless of how you get there I hope my process may get you started in your own scavenger hunt to turn junk into something useful.
Step 1Strip down and Frame up
I began with a perfectly good 1/3 HP Delta BS100 band saw gathering dust in the corner of my shop that I just didn't currently have a use for it. My plan was to build a frame around the saw, mount it horizontal and use the wheel that was directly connected to the motor. I'd place the seat at the other end of the frame to save space and add some vibration reduction with one's body weight. The wheel/saw would be operated via a variable speed pedal.
The frame ended up being 34in x 18in and I use some salvaged water bed lumber for the outside of the frame which had a nice groove pre-cut to keep the deck/seat nicely in place.
7 comments
Oct 12, 2009. 11:01 AMRoger4Wheel says:
I appreciate your resourcfullnes, so this is not meant to insult, but did you have to start with a "perfectly good" bandsaw?  Couldn't you have started with something less usefull, like an old turntable?
Good job, I just hope it's reversable for when you want to use the bandsaw for cutting.  :^)
May 25, 2009. 10:06 AMIvoLucien says:
Excellent, thank you very much! BTW, how did you address the power switch and variable speed control? Did you have to orient the saw somehow to make its built in control reachable?
Jan 6, 2009. 12:29 AMesp711 says:
I'm an inventor as well, and the insight, creativity and imagination you put into this idea is simply... brilliant!! Bravo!
Jan 5, 2009. 7:00 PMkarylaj says:
Great creation!
Jan 5, 2009. 6:38 PMLADYBYTE says:
You the man!!! I know Beth is so thankful to have you and your wonderful imagination...;-) Connie
Jan 5, 2009. 1:49 PMsusie peach says:
GREAT FOR THE POTTTER AND OTHER USES
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Odovacer
Over the past few years, I have found great satisfaction in tinkering in various crafts/ trades/ fields thats I was not exposed to earlier in life. Now I feel my way through projects with the help of ...
more »
