3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bandsaw Box Basics
Bandsaw Box Basics
Bandsaw boxes are not new, but they are not very common in some regions. While bandsaw boxes come in a wide variety of shapes and sizes, I’m writing this Instructable for a box made from a section of log that is about 10 inches tall and about 6-8 inches in diameter. I’m using red cedar for this box, but I’ve made them out of oak, mesquite, pecan, and pine. The main difference in these species is the effort required to make the various cuts.
Step 1Getting Started
Getting Started
Your list of supplies needed for producing bandsaw boxes is pretty simple:
• Section of a log
• Glue
• Sandpaper (various grits starting at 80 and working up to 120 or more – depending upon the type of finish you intend to apply to the wood)
• Finish material. Depending upon the wood and the look I want to achieve I’ll use Danish Oil (neutral) or diluted polyurethane varnish.
The list of tools you will need is also pretty short:
• Bandsaw capable of cutting your log section from any angle. I use a 14” bandsaw with a 6” riser block. This allows me to slice wood that is up to 12” thick.
• Two bandsaw blades, one wide and one narrow. I typically use a 5/8” blade for the rough slicing of slabs and a 1/8” or 3/16” blade for cutting the curves.
• A sander (I use a 5” random orbital palm sander)
• A Dremel tool with a sanding drum attachment.
• A variety of clamps for the re-assembly process.
Because my customer for this box wanted only cedar heartwood, I had to split off the sapwood. If you look at the first photos you will see the heartwood of this log is a distinctive red color. The sapwood is white. Because this is cedar, the wood splits easily. I use a 1 inch wide chisel and a mallet to split the sapwood from the log.
The sapwood and bark are saved for fire starters. Yes, I feed my wood stove my scraps. The nice thing about working with wood is any mistake can feed the stove and nobody has to know how badly I messed up my first (or second) attempt.
Once the sapwood is mostly removed I’m ready to lay out the cuts I intend to make.
23 comments
Jan 12, 2012. 10:08 AMLaser28 says:
Great piece of work. Just ordered the 6" riser for my bandsaw. Is there one particular blade Mfg that you prefer.
Nov 8, 2011. 1:41 PMAaronius says:
Fantastic box and instructable. Thank you!
Aug 25, 2011. 2:14 PMtriumphman says:
Don't you love the smell of the Cedar ? I do! It fills my basement woodshop with a great smell too. The trees that die on my property are re-born as wonderful gifts. I am thankful for them! I just found six tall ones that died years ago. I cut them down, trimmed the branches, and built a Teepee frame. 18 feet high and forty feet around. I'm still searching for a suitable & affordable cover for it. Its on my wishlist! Nice work, be safe, seek Peace & Joy. Triumphman.
Jul 7, 2011. 12:10 PMtriumphman says:
Nice job. I have an 'ible on a similar three drawer jewelery box made of red cedar. Check it out. Cedar is great wood to work with, smells nice too and is a natural moth repellent. I even made some tiny boxes with hidden hinged lids. See picture attached. These little boxes are challenging, but make great gifts. A pair of earrings fits inside, barely. Keep that bandsaw blade hummin' !
Feb 11, 2011. 5:34 AMWinterhawk says:
Wow Chuck, I always knew you were an artist and master woodworker, but you are also an excellent instructor! Thanks for the lucid, simple, logical step by step instructions to make a complicated process seem doable to the average wood butcher such as I. The boxes are beautiful, but I expected nothing less from you!
Feb 11, 2011. 8:15 AMWinterhawk says:
Speaking of dull tools, you might consider doing an instructional on sharpening! I never knew anyone who does it better!
Feb 11, 2011. 8:13 AMWinterhawk says:
Chuck, you know I live in the land of "Someday Isle!" You know that story. Someday I'll get by there...Maybe, one day, I hope. Say, if I do can I bring my knives and chisels? They are getting pretty dull... ;-)
Feb 6, 2011. 8:16 AMthenickp says:
Excellent, excellent job. I have always been drawn to such beautiful things that help to give our precious trees "life" for many, many years to come. Thank you for what is obviously a labor of love. Very well explained, documented... great pictorials. I very much look forward to "bringing my first piece to life"... thank you again.
Feb 8, 2011. 6:27 AMthenickp says:
I'll do that. Thanks again for sharing your art!
Feb 1, 2011. 9:22 AMRaisedByRobots says:
neat! I wish I had a bandsaw! what sort of glue did you use?
Jan 31, 2011. 9:42 PMHisart says:
Beautiful job!
Do you leave any of the cedar open?
Jan 31, 2011. 7:36 PMcdawisconsin says:
Beautiful. I love the grain pattern on the star, I'm assuming that you pieced it together
Jan 31, 2011. 2:38 PMcanida says:
Beautiful work, and I love the color!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:malsonc
