loading
Step 11: Sand Your Drawers
While your glue is drying you can sand the outside of your drawer body
<p>wood chuck. i looked at your website. i would like to know if these plans are step by step. i meant to the t before i buy something i got scammed once before im not looking to have it done again.</p>
<p>Jack<br></p><p>Thank you for your inquiry about the plans on the website.<br> The plans on the website are all detailed 3d graphic illustrations of a<br> particular project, so in answer to your questions it <strong>DOES NOT</strong> <br>give you step by step construction details. You do need to have a basic <br>woodworking background to complete any of the projects on my website.</p>
Nice instructable it helped me make mine https://www.instructables.com/id/Band-Saw-Box-With-a-Secret-Door-and-Swinging-Brace
<p>Very cool your band saw box looks great, I'm glad I provided some inspiration. Bruce</p>
sorry link is wrong https://www.instructables.com/id/Band-Saw-Box-With-a-Secret-Drawer-and-Swinging-Brace <br><br>
<p>Hey Woodchuck-- I'm looking to get back in my shop after a long hiatus and these look super fun to make and will turn out unique finished products. Thanks for posting!</p>
<p>Welcome back to woodworking .... Enjoy. I now have a website with over 125 plans available, drop by sometime for ideas. 3D woodworking plans</p>
<p>I wonder if instead of using the 8x4 as a core, and then the two additional end pieces, you could use roughly 12, 1x4 pieces, and glue them all together, so you could see the streaks down through the box.</p>
Howard you can build your blank however you please. Any variation will add some sort of design element.
<p>Yes! a good project for Gramps and I this holidays. Thanks</p>
<p>Have fun. Anyone you make one for will be appreciative</p>
<p>Have fun!. I'll bet you make more than one :)</p>
Actually is more than just that questions <br>Why was that particular type of wood used? <br> <br>7. How big is it? What are the dimensions? <br> <br>Thank you
Kiosko <br>The original blank was made with an 8/4 walnut core and a piece of lace would laminated (glued on the front and back. The overall rough blank size was 3 x 6 x 11. <br>Good luck with your project. You can download the complete pdf of the project on the first page. I believe. The nice thing about band saw boxes is that nothing is wrong if its not the same than its just a design change :) Checkout my project videos on my website 3dwoodworkingplans dot com. <br>Bruce
Hi, im doing a bandsaw box at school, i need to do some research on bandsaw boxes first,and i chose yours, i would like to know what type of wood this bandsaw box was made of. <br> <br>Thank you
Here is a picture of one of my prototype bandsaw boxes. Its actually two cedar tree trunks that grew together. I pulled them apart and made two tower jewelery boxes. Thanks for your 'ible. As ever Triumphman.
holy snap that's cool!
I was wondering what type of bandsaw you use? I have finally received permission to get one from the boss and have been doing my research. Any input would be great.
I use a 14&quot; Delta model # 28-206. When I was researching bandsaws I liked the blade support system both above and below the table. I have been pleased with the peformance of the Delta. Hope that helps. Bruce
I like those blade guides so much I made my own. My sears 14&quot; did not come with these. Just pin type guides which constantly need adjusting. Now I am happy! Love being able to make my own stuff! Thanks. See my bandsaw boxes on the bandsaw box web site. Triumphman.
I will have to put my bandsaw to the test- very nice step-by-step.
This is the step that sets the limit for a box size... a full size band saw can typically handle 6-7&quot; while a benchtop band saw is limited to about 3&quot; or so... the same design style can be made, but smaller saws require scaling the pattern down.
And... don't forget the largest design for a bandsaw box is limited by the bandsaw that one is working with... benchtop bandsaws won't be able to handle the 6&quot; width dimension.
<a href="http://dbfstudio.com">interior design nyc</a>
Nice looking box that you made there! Band saw boxes always make me think of Alice in Wonderland... You've inspired me to give one a try; I've always been a little wary of my bandsaw abilities, so I tend to stick to mitered jewelry boxes and the table saw.<br><br>BTW, if you're looking for nice, figured woods for smaller projects like this, you should check out Horizon Wood Product's online specialty shop. It's got a pretty slick setup with zoomable photos and whatnot!.<br><br><br>http://www.horizonevolutions.com/eshop/
Nice use of photos... clearly shows the steps! Bandsaw boxes are an easy project and a good way to use up shorts by laminating them up to make the box blanks. <br><br>My students usually finished of the interiors of the drawers by brushing them with a coat of enamel paint and then blowing in a puff of rayon flock of a matching color. It gives them the look of being lined in felt and hides any minor sanding faults.<br><br>Very creative shapes in your examples!
Thanks ebergh, those boxes were my first three I made. I have since started flocking the insides, even the inside of the opening which takes up a lot of the bandsaw cut lines and the drawers slide very nicely.
Nice instructible. i saw on of these in a store that sold homemade wood projects and made onee myself in carpentry class. mine was half of a tree stump (semicircle flat side down curved side made of bark) and gave it to my grandma for mothersday. i plan on making one like yours soon
Thanks for the comments - have fun
Nice job. I think it should be mentioned that this size box cannot be made on a benchtop sized band saw... those typically have a max. height capacity in the neighborhood of 3 1/2&quot;. This project was cut using a full sized band saw whose capacity is likely closer to 7&quot;. The step where the back is cut off is the limiting step... if the box on its side is taller than your saw's max. height capacity, then you can't cut off the back. Benchtop band saws can certainly make boxes with this method, but the design has to take that dimension into account... same with scroll saws, whose max. height capacity is typically around 2&quot;, give or take a little depending on the model.
Thanks for you input sawtooth1953, it's amazing what you have to consider when writing one of these instructables. Cheers
While sawtooth is correct I think it prudent to say that you don't NEED to use a band saw to cut off the back. Other tools may be used. However a full size band saw would probably make the BEST cut.
Actually all you really need for capacity for this particular box is about 3&quot;, you just lay it down to cut the back off
i was about to say.... these pictures look really familiar. but then i saw that it was in fact Bruce aka. wood chuck. my favorite youtube channel did a piece on you and you bandsaw boxes. thanx
Corsi; Where might that be? You must be refering to the Woodworking for mere mortals site. Steve was the one that suggested entering this instructable.
It was infact the very one. Have watched all of his videos. I have made several bandsaw boxes with the help of this instructable.
wow, thanks so much Wood Chuck. I'm going to give this a try, the instructable is great!
Your welcome - have fun
Very nice work! Im going to have to try this as my next wood working project, Thank you. Now only if I had one of those sanders. And the saying goes, you can NEVER have too many clamps.
Very nice. Inspiring. When ever I try to make sharp turns on my bandsaw like you're doing, my blade breaks. What am I doing wrong? Any turns that I make on my band saw has to be very slight. Any Ideas?
You shouldn't be breaking blades, unless you are trying to make turns that are too sharp for the size of your blade or your saw needs a basic setup. I've included a link to Marc Spagnolos site (aka The Wood Whisperer) He goes over a basic tune-up, in particular blade tension. I hope this helps you out. Bruce http://thewoodwhisperer.com/bandsaw-setup-tuneup/
Thanks!
I wonder how well this would work on a scroll saw? wish I had a band saw. nice work.
boognishmofo: there is no reason why a scroll saw wouldn't work. I know my scroll saw is very small and the stroke distance is too short - unless your going to make very small boxes. WC
All three of your boxes are beautiful!
Absolutly amazing you have changed the game for woodworkers
Thanks Igor
Beautiful work!
Thanks everyone for the encouargement and kind words. They really are fun to make.
Nice. I've been meaning to make a bandsaw box for a while but never got around to it. Your instructable is nice and clear, well done!
About This Instructable
319,791views
253favorites
License:
More by Wood Chuck:Heart in Heart Picture Frame + Bandsaw Circle Jig Plan Bandsaw Boxes Made Easy
Add instructable to:
