Introduction: Bangle Box Converted to Emergency Light
Picture of Bangle Box Converted to Emergency Light
Hello,
This is most useful & small in size emergency LED light made from bangle box
In this instructable i used bangle box & old nokia(any) mobile battery to make this emergency light
it have more features like very small in size &we can carry this any where....it provide high brightness
finally we can charge it by using mobile charger
lets see how to make this!!!!
Step 1: Components & Tools Required
Picture of Components & Tools  Required
COMPONENTS:
1.Plastic bangle box-1 no.
2. 3 W LED with heatsink-1no.
3. Old mobile battery-1no.
4. 5mm red LED-1no.
5.general purpose PCB-as required size
6.DC jack-1no.
7.Diode In4007-1no.
8.Resistor 470 ohm - 1no.
9.Switch - 1no.
10.Flat PVC sheet - as required size
11.Screw - 4no's
12.Paint any color
13. Wire - as required size
Tools:
1.Soldering kit.
2.Glue gun with sticks.
3. Paint brush.
4.Wire stripper & cutter
5. Aksha blade
6. Insulation tape.
Step 2: Circuit Diagram
Picture of Circuit Diagram
This is the circuit diagram of this instructable... many of the people already gave this circuit....but here i used the different container to reduce the size and weight to carry any where....
Step 3: Placing the Components & Connections on PCB
Picture of Placing the Components & Connections on PCB
Now place the LED,resistor,diode,on the PCB....while placing LED just place it on corner because we have to project little bit out side of box...then make connection as per circuit diagram...
Step 4: Paint the Bangle Box
Picture of Paint the Bangle Box
In this step take the box & paint it .....just leave it on top side alone ..
Step 5: Place Everything in Position
Picture of Place Everything in Position
Now take flat PVC sheet & cut it in the size of bangle box then place the 3Watts LED on it for more details refer attached image.
then cut the flat PVC sheet as required size to fix the battery inside of box..
after that solder two wires on battery (+)&(-) terminals ..for safety purpose glue it and cover with insulation tape..
now give connection as per the circuit diagram..& place the LED sheet on top then screw it all
Step 6: Final Painting & Testing
Picture of Final Painting & Testing
Now paint top round PVC sheet & closed it
after this just connect the mobile charger at that time red color LED will glow...now battery getting charge& ON the switch 3 Watts LED will glow
everything done.....................
rafununu (author)2016-03-30
Two things : You're counting on the internal battery resistor to limit the current so your Led will heat much more than normally and, as lifetime is a reversed function of heat, it won't last very long. Next, you cannot load any type of battery like this, some Lithium and most of the rare earth based batteries will burn ! They need a controlled current for charging.
gsantony (author)rafununu2016-03-30
I never told anywhere like this battery will last for very long ....it's just for emergency purpose.... i think u know the meaning of emergency...&one more thing u have to mind it all the mobile battery have internal protection circuit....this will limit the load current & charging current then 2nd one here we are using OLD mobile battery ...see i am using this circuit for past 6 months ...till now i didnt face any problem what u have mentioned....so dont tell just like that... i am using to charge the battery with mobile charger only...my battery & my light working well ...one more we can load upto maximum capacity of battery but the only one thing its wont provide power for long duration...i think now u got it....
momoluv (author)2016-03-29
Very helpful! Great job
gsantony (author)momoluv2016-03-29
Thank you....
About This Instructable
1,120views
14favorites
License:
More by gsantony:Bangle Box Converted to Emergency Light 360 Degree Multi Purpose Bright LED LightLEAD ACID BATTERY CHARGER
Add instructable to:
