3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bar End Brake Light: BEBL
Step 10Master/slave connector
Measure the total length of the handlebar with a tape measure.  My bars measure 42 inches.  Add three inches for maneuvering room. Cut the two 50” wires to that length.
Solder two anchor wires to the outside pins of the 4-pin female header.
Place several half-inch heat shrink segments over the two long wires.  On the end, slide a heat shrink segment onto each of the long wires individually.
Solder long wires to the two middle pins of the 4-pin female header.
Solder two short wire segments to the outside pins of the 4-pin female header.
To relieve stress on the LED wires, heat shrink the middle wires to the outside anchor wires using the pre-placed segments on the ends of the long wires.
Heat shrink the long wires together evenly spaced all the way back with the remaining segments.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:WyoJustin(Justin Shaw)
