3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bar End Brake Light: BEBL
Step 8Install LED D2 on slave
Insert free end of R2 into the outside hole on the board as far as the end will reach. Solder. Do the same for the free end of the jumper.   One side will use the copper connection already on the bottom of the board; the other connection is made manually by bending the end over to the LED lead.
As with D1, insert D2 into the bar end plug until it stops.  Fit the PCB into the slit and bend the LED leads so that they reach the holes adjacent to the free lead of R2 and jumper wires.  Solder in place.
Fasten slave PCB to bar end plug with thin gauge wire, as the master was done.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:WyoJustin(Justin Shaw)
