Note: Build and operate at own risk. I am not responsible for any harm or injury caused by building or operating boat.Life jacket recommended.
Materials:
(2) 2x2x4 feet
(2) 4 foot landscaping timbers
(2) 2x4x4 feet
Duct Tape
3" Screws
55 Gallon Plastic Barrel
Counterweight ex. barbell weight
Tools:
Drill & Drill Bits
Jigsaw & wood/plastic blades
Measuring Tape
Saw to cut wood
Remove these ads by
Signing UpStep 1: Seal and Cut the Barrel
Next cut the barrel. I don't have any actual pictures but do have a Google SketchUp Model. Trace in the bottom of the barrel like shown a opening based on your size. Cut the hole big enough to get in and out of but not farther than half the length of the barrel. Drill a hole in the middle of your traced opening for the jigsaw to start cutting. Than with the jigsaw cut out the traced opening. If you have rough edges sand them smooth with sandpaper.
Visit Our Store »
Go Pro Today »
The weedeater shaft would have to be solid, because the flexible shafts wouldn't handle the torque needed to turn the water and the resistance of the water against the prop. I believe to much stress of resistance would be placed on the motor.
Also with a solid shaft it would have to stay as short as needed, or to much torque will be lost in the length.
Another good idea though. ;)
If you could find a high torque cordless drill, like ones used for mixing mortar, that would be an awesome portable prop. Good idea kdf.inc1969 :)
To add buoyancy and balance, replace the landscaping timbers with 2x4x4s and attach 3x 3 litter bottles under each of the replacement 2x4x4s. They will act as pontoons.
Also you could add a hand controlled rudder to the back cross arm if you turn this into a sail boat.
Happy sailing :)
how much weight would you say this boat can support?
PS i'm glad an aussie replied with kg..i can't understand pounds! hehe
The project is very good.
Also, since this is your first published project, have you seen this group? You could get free stuff, just because you've posted your first project.
(Spread the word, tell your friends to join an post their own projects!)
