Barrel Extension for 'Wrecktangle'
557
29
Published
Introduction: Barrel Extension for 'Wrecktangle'
About: Washingtonian aiming for simplicity.
Well, I told DJ a while ago that I made a barrel extension for the 'Wrecktangle', or 'Rectangle', that makes it work better with red or yellow rods.
This is it.
A couple things:
When it's actually connected, it doesn't bend at ALL. It does without the gun itself though.
You could also use yellow rods instead of blues for the extension, but then it obviously wouldn't work for yellow rods.
    • Casting Contest
      Casting Contest
    • Stick It! Contest
      Stick It! Contest
    • Oil Contest
      Oil Contest
    29 Comments
    Ok it looks weak. Like if you hit it, it would come off. And wouldn't it add some more friction
    Nah. It's actually pretty sturdy. Pretty much as sturdy as the rest of the gun. And yes, it does add friction. But it adds accuracy for yellow and red rods. So it's pretty much worth it. Try it if you have a 'tangle built.
    OK, if I ever built the tangle I'll use.
    Also can you post a picture of the wrecktangle?? Or is it the same as the rectangle??
    Same as Rectangle. Slight mods. Check page 3 of the Rectangle thread on KI.
    Mods:
    Mepain's modded trigger
    Ammo holder
    Reinforced pin guide structure at the back.
    Are the wrecktangle instructions ay KI?
    There are none.
    Oh, he took it down.
    But seriously, you need instructions?!?!?
    There were instructions on ibles, but oodalumps made the author take it down.
    Yep. The only thing you really need is the newer trigger.
    Yep. I've done it with white, blue, yellow, and red rods. (And using one size bigger for ammo. I.E. blue, yellow, red, and grey.)
    My favorite is yellow+red, but red+grey hurts a lot more. Due to the grey rod having a lot of mass. But if you really want to bruise someone, use a black rod. =P
    if you want to hunt, use blue rod +red con, yea i call it KFC ammo
    Knex-Freek-chuckable ammo
    I don't remember you telling me about a barrel extension.
    On my orangeboard in my reply to your "So watcha think of my OMEN?"
    Anyway... Whaddaya think of it?
    Oh I forgot.
    It looks cool, but it could fall off easily.
    No.
    No it couldn't.
    I mean if you use a lot of force, if you bang the front against a doorframe or something.
