Introduction: Barrelponics - Getting Started With Aquaponics
- No soil means no weeding, no soil-borne diseases, and no tilling!
- The fish provide free fertilizer.
- Plants grow as much as four times faster than those grown in soil or hydroponics systems.
- Water waste is minimal.
- Grow more with less space.
- No land, no problem; land isn't required.
- Fresh fish for the taking.
- Year round growing is easily implemented.
Step 1: Parts and Tools
Here is what you'll need to set up your system.
1 - 55 gallon food grade barrel (check craigslist*).
1 pump (I used a 200GPH pump I bought off of Amazon).
Grow Medium (Hydroton expanded clay grow pebbles or pea gravel is preferred).
1/2" piping for pump to beds, and siphon to tank (a 10' pipe is about $2 at the hardware store).
2 - #18 o-rings
2 - #14 o-rings
Bell Siphon:
1 - 3/4" PVC pipe, 18" long.
2 - 3/4" 90° Elbow.
1 - 3/4" Male and Female threaded to slip adapter
1 - 3/4" to 1 1/2" Bell Adapter
1 - 2" PVC pipe, 8" long.
1 - 2" PVC pipe cap.
1 - 3" PVC pipe, 10" long.
Tools:
anything to cut holes in plastic/PVC (I used a Dremel).
100% silicone and caulk gun
sharpie
Other things you'll need:
empty soda bottle (for peeponics)
Seeds
Fish
*neo71665 brought up a great point in the comments feed about buying barrels on craigslist and I wanted to expound on it here because I think its worth understanding. How do you know the barrel is indeed food grade safe? I myself buy from a person who sells food grade, and non food grade barrels of many different sizes including IBC totes. He receives them in mass quantities, cleans them up and resells them. If you can find someone who is doing this as a side business then I think you’ll find someone with a little more integrity than someone looking to make a quick buck for his personally used goods. Regardless of this I always do a smell test. Barrels used to store chemicals are a dead giveaway when you do the smell check. Most food grade barrels I’ve come across were used to store some kind of high fructose corn syrup and you can usually smell this if only faintly. Another dead giveaway is you may find dead bees inside the barrel, which have been attracted to the sweetness and got lost in the darkness (I see this often). Once you get your barrel home be sure to clean it out yourself just to be safe. If you're still worried about buying used barrels there's nothing wrong with buying them new.
Step 2: Building Your System
After you have divided the barrel into a lower fish tank (about 2/3 of the barrel) and an upper grow bed (the remaining 1/3), clean up your cut mark with sand paper and wash out the barrel. Then take the grow bed, flip it so the bottom of the bed is facing up, and mark the holes for the bell siphon and the intake hose. Both pipes/hoses need to fit snug so use the actual parts for a template. Use a shallow to mark your holes on the grow bed and carefully cut them out when you're ready. I used a Dremel for this step, but use whatever works for you.
Now prepare your fish tank by making two holes in the side. One hole to access the fish in the front, and another in the back for the water pumps power cord. First locate the 30 gallon mark. On my barrel there is a line that marks this for you. If you don't have a mark like this just measure 16 3/4" from the bottom of the fish tank, this is your mark. Mark a hole to cut out for easy access to the fish. Make any design you want, but just be sure you leave enough room for the water surface and the bottom of the grow bed. In the back of the fish tank make a small hole so that the power cord can pass through.
Now to bringing it all together, make eight sets of small holes to tie the grow bed to the fish tank. Drill 8 holes in the top of the fish tank (equally spaced), and 8 matching holes in the bottom lip of the grow bed. Run eight zip ties through each set of holes to ensure a secure fit.
Once the barrel is put together you can put together all the necessary plumbing. Screw the top and bottom of the bell siphon together making sure it fits securely through the siphon hole in the grow bed. Make sure it's tight and that there are no gaps. You will need a #18 o-ring to create a water tight seal here; I used two (one on each side of the grow bed). Now take the male and female 1/2" adapters and do the same thing for the intake hole (use #14 o-rings here). Place the water pump in the bottom of the fish tank and connect it to the bottom of the 1/2" adapter with a piece of 1/2" PVC pipe. You may need to tinker with the pump and pipe connection. My pump has a metric sized hole so I had to fashion an adapter out of vinyl hose and a quick connect to thread adapter. Do what you can to make it work.
Finish the pump line by fitting 9-10" of 1/2" PVC pipe into the top of the intake adapter in the grow bed. Then attach this to a horizontal 1/2" pipe or pipes with a 90° elbow, T-fitting, or T-fitting (this can be as long or short as you want). I branched my pipe into two. Cap any openings here. You will need to drill a small hole or holes in this horizontal pipe(s) to let water out. Start with one or two holes and check the flow rate; adjust by drilling more holes as needed.
Test your system as a whole paying special attention to the flow rate, drain rate, and any leaks; adjust where needed. If you have any leaks in the bung holes you can use 100% silicone to seal it. If you're satisfied with everything fill the grow bed with grow media (I.e. pea gravel or clay pebbles) up to the bottom of the horizontal pump pipes. This is necessary before cycling your system.
If you plan on using your new aquaponics system indoors I recommend painting the outside of the barrel to make it more attractive in your home.
*As a side note, it's perfectly fine to use 100% silicone over aquarium silicone (they are essentially the same). I've used "GE Windows and Doors 100% silicone" with great results.
Step 3: Cycling Your System
Before your system is ready to be stocked with fish it needs a healthy stock of nitrifying bacteria. The first step to build up bacteria is adding ammonia to the system. You can buy liquid ammonia, ammonium chloride, or provide your own (yes I went there). By sealing your own urine in a container for a week you will have a good enough source of ammonia, but this comes with a sense of disgusting attached to it.
Once you have the ammonia follow these steps:
Add the ammonia to the fish tank, start off with a little. Check the water with your water kit, your looking for ammonia levels of 3-5 ppm. Once this level is reached, take note of the amount of ammonia you used. Add this amount daily until the nitrite approaches 0.5 ppm.
Once nitrites appear, cut back the daily dose of ammonia you used to get it started to half. Once nitrates appear (5 – 10 ppm), and the nitrites have zeroed out then your system is ready for fish, and has been cycled.
Step 4: Adding Plants
tomatoes
lettuce
cucumber
shallots
celery
capsicum
chilli
snow peas
red salad onions
cauliflower
broccoli
cabbage
beans
egg plant
choy
basil
parsley
watercress
coriander
sage
lemongrass
strawberries
Well I think you get the idea; you can grow a lot of great food in your aquaponics systems, and 7 square feet of grow space is a great starting point. The list of plants that have been grown successfully in aquaponics systems is huge so if you're looking for specifics then check out this thread and post any questions there (or here in the comments feed). You will find a great community of experienced aquaponics hobbyists that will be glad to answer any questions you have.
Step 5: Adding Fish
Channel Catfish
Bluegill
Tilapia
Koi or Goldfish
I think tilapia is a great choice for aquaponics because they are a very hardy fish, are fast growing, and taste good. In a system of this size 5-6 Tilapia will do well; however you will probably need to eat one of them as they grow into adulthood.
Step 6: Feeding Your Fish
Depending on the fish you have in your system you have several options for feed.
Channel Catfish
Catfish are cows, they will eat and eat and eat. Most commercial farmers will feed them them until they can't fit anymore food down their throats. They will eat Mealworms, Crickets, red wiggler worms, and duckweed.
Bluegill
Bluegill's prefer a protein rich diet including worms and insects, but will eat vegetation and even its own young if food is scarce. Consider raising Mealworms, Crickets or red wiggler worms to feed them.
Tilapia
In nature Tilapia eat plankton, insect larva, vegitation and fish poop. In aquaculture they are commonly fed duckweed , a water plant that is very easy to grow yourself, which is why it's so popular (please don't feed your fish poop).
Step 7: Maintaining a Healthy Aquaponics System
Things that effect pH:
1. Dead fish in your tank
2. Grow medium isn't pH neutral (This is why I suggest Clay Grow Pebbles)
3. Fish Pounds exceeds plant balance (1 fish pound = 1 sq. ft. grow area)
4. Hard Water (common with tap water depending on your area)
5. Particle buildup in your grow beds (add worms to your grow beds to consume the particles)
If you find your pH level is either too high or low you can use a pH kit to fix the problem. Alternatively you can use baking soda to raise the pH and vinegar will lower it. If you find the problem returns you may have something in your system that you will need to change. Go to any aquaponics discussion board, or post your problem here. I'm confident we'll find a solution.
Step 8: Now What?
If you're interested in learning more, there's plenty of online blogs and forums devoted to the subject. Check out the book, Aquaponic Gardening, or take an online course to get an in depth look at what you can actually do from here on out.
As always I'm glad you made it to my instructable; I hope you have enjoyed it, and please vote for me in the hydroponics and indoor gardening contest!
