Basic 2D Printer VERY CHEAP
1,969
40
8
Posted
Introduction: Basic 2D Printer VERY CHEAP
So the idea is to build a very cheap 2 axis printer that can be later upgraded to 3 axis for various purposes.
I got my things from ebay:
8x SK10 10mm CNC Linear Rail Shaft Guide Support LJN New US $11.76
4x 5 x 5mm CNC Motor Jaw Shaft Coupler 5mm To 5mm Flexible Coupling Fashion US $9
metric threaded rod with some bolts
pieces of aluminium sheet
L profile
4x 5V Stepper Motor 28BYJ-48 US $8
20CM Dupont Wire Color Jumper Cable 2.54mm 1P-1P Female to Female N4U8
10 PCS Miniature Rubber Sealed Metal Shielded Metric Radial Ball Bearing Model US $2.42
Arduino UNO
Step 1: Adding Third Axis and Motor..
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    8 Comments
    We have the beam coupling,hahha
    I'm also making some 3 axis CNC with the screw mechanism but now I guess using belts and pulleys would be more precise because that way you have the advantage of easy microstepping .
    On the contraty, here you have motor Speed Variation Ratio 1/64 and for every revolution of the shaft, the nut moves just a little. Just imagine turning the screw and holding the nut.
    many thanks for sharing this,i wonder how to realize each 2 step motors move at same pace.what program you used?
    They are connected in paralel so same sequence goes to both 28BYJ-48 stepper motors, that way left and right side run simultaneously. You can find code for this stepper anywhere. I didn't write the code, I changed direction(or stopped) on motors.
    You are very smart.
    I used to use something like this waay back in the dawn of time for printing technical drawings it was called a plotter.
