loading
In this instructable, I'm going to show you how to make a simple circuit/code with an arduino, which will make an LED connected to it flash from off to on, with 1-second intervals, as shown below.
This is a very easy, basic idea, however it leads to many more complicated codes and circuits.
Step 1: What You Will Need
1 x LED
3 x Cables
1 x 330 Ω Resistor
1 x Arduino board (it can be any kind, but for this instructable i used the UNO board).
1 x USB cable
1 x Computer with Arduino software installed (http://www.arduino.cc/en/Main/software if you haven't already got it)
1 x Breadboard
Optional
Breadboard/Circuit-board Holder.
Step 2: Attaching the Power Cables and Resistor to the Breadboard
Firstly you will need to plug one end of a wire into the '5v' Power output on the arduino, and the other end into the positive section of the breadboard.
Then you need to plug one end of a wire into the ground ('GND') Power output, and the other end into the Negative section of the Breadboard.
Finally, you need to plug one end of the resistor from the Negative section of the Breadboard, to any horizontal line on the main section. (NOTE- It is very important to use AT LEAST a 330 ohm resistor with this circuit. If you don't, then you will almost certainly blow the LED.)
Step 3: Attach the Control Wire to the Breadboard
Attach a wire from digital port '0' on your Arduino to the hole directly above the resistor.
Step 4: Attaching Led
Now to attach the Led into the circuit. Be warned, it will NOT do anything until you have uploaded the code to the board, which is done at a later stage.
the way this is done is to put it so that each pin is next to a wire/resistor. This sounds unclear, but pictures should help
You have to put the LONGER pin next to the wire connected to the port, and the shorter pin next to the resistor.
Step 5: Plug Into Computer.
Now you need to plug the arduino board into the computer. Nothing really to say here, just make sure that you don't break anything!
Step 6: Upload the Code to the Device
I've attached the code here. All that you have to do is open it with the arduino sketch program, and click upload to device
Step 7: And... Shazam
Once the code is uploaded, if you have done everything right, the LED should flash. It will do that for as long as the device is plugged in.
Note- if the Arduino is unplugged, then plugged in again, it will still work.
Hope you enjoyed the instructable, keep looking at my profile for more arduino instructables soon.
<p>Hey,</p><p>I am using Arduino with RTC to operate the lights of my home.</p><p>I want at 10 PM all my lights should OFF and at 6 AM same should be ON.</p><p>I have completed everything but only unable to tell Arduino to read time from RTC to operate lights.</p><p>Can it be done by reading Arduino Serial Monitor? If yes, then HOW.</p><p>Also the other possible method to do same through Arduino.</p><p>Thanks.</p>
<p>There is no need to use the positive power rail for 5v from the arduino since you are just using the power from the digital pin.</p>
What is the code
<p>nice easy tutorial and a great intro to arduino for someone who has never used it before. As someone points out below, you don't need a wire going from 5v to the bread board. Also the directions say you should use at least a 330ohm resistor but I used 220ohm based on this article from ararduino: https://www.arduino.cc/en/Tutorial/Blink</p>
<p>Hi,</p><p>I'm just starting out with an Arduino and I did this project, but can't figure something out.</p><p>It seemed to me that the positive from the 5v to the breadboard doesn't really go anywhere, and I confirmed this by removing it. The LED still blinks. I'm assuming the circuit is completed by the jumper to the digital pin 0.</p><p>So, why the 5v jumper to the breadboard?</p>
<p>You most certainly do not need a wire running from the 5v to the breadboard. The voltage you need is coming out of the digital I/O pin. </p>
<p>Very Nice Learning</p>
thanks for the tutorial. it was my first.
<p>How would that work with the nano on the breadboard? I know that the Nan gets its power from the USB but what about all the plugs that the Nano is sitting in on the breadboard? I assume they are dead?</p>
<p>I'm a 27 years old girl, look what I did! It's never too late to learn anything! Your tutorial was great! </p>
<p>Hi, where did you buy that bread board from?</p>
<p>Here is a super easy Arduino breadboard:</p><p>http://www.dcoptimum.com/arduino-beadboard-schematic/ </p>
<p>Great tutorial!!<br>I'm new to all this stuff and before I jump into programming the Arduino I'd like to start by learning a little with analog circuits.</p><p><br>Can I use the Arduino purely as a power supply for my breadboard?</p>
<p>Hello, these are some of the great tutorials on starting with Arduino...<br>I have some other tutorials on Arduino that might be helpful:<br><br><a href="http://www.zseries.in/embedded%20lab/arduino/" rel="nofollow">http://www.zseries.in/embedded%20lab/arduino/</a></p>
Perfect for me and I'm so danged glad you posted this. If you have time, keep going! This is incredibly helpful. Thanks again!
I know there are a lot of Instructables on Arduino, but most of them begin beyond a beginner level. Arduino is very new and unfamiliar to me. I appreciate your very basic approach for a &quot;newbie.&quot; I look forward to anything like a step-by-step tutorial for someone not currently involved with Arduino. Right now my questions involve, &quot;What is it?&quot; and &quot;Why would I want to use it?&quot; If I were to use Arduino, I would want it to do some useful and necessary task best done by it. I would not be interested in &quot;cool&quot; for the sake of &quot;cool.&quot; Thanks.
That was my original idea, because when I started using Arduino, I couldn't find any tutorials on basic ideas, and I got very unnerved, So i made this tutorial for beginners, and am looking at making more. Thanks for the feedback!
About This Instructable
168,827views
36favorites
License:
More by fergal:Basic Arduino Tutorials : 01 Blinking LED
Add instructable to:
