Basic Cube Structure (parrot Platform)
2,871
11
Published
Introduction: Basic Cube Structure (parrot Platform)
About: I've studied in industrial design, with an interest expanding into many fields. Curiosity and the motivation to improve my environment leads me to work on new personnal projects around the appartment. Once ...
It is possible to create functional structures using simple and cheap tools.
In this instructable I'm building a cube frame which can be adapted to many uses.
Submitted by DIN 2012, Université de Montréal, industrial design program, for the Instructables Sponsorship Program
Step 1: Materials & Skills
Materials are very basic:
+  rope / thread (depends on the look/solidity you need)
+  12 x poles / sticks / rods / ...
+  scissors
Skills, forgotten fundamentals:
+  knotting techniques
Step 2: Knots to Know
You'll have to learn these knots:
  1. Constrictor knot
  2. Square lashing
  3. Square / Reef knot
Step 3: Assemble
To create a cube, assemble corners with the knots.
  1. Start with the constrictor knot on the first stick
  2. Place the second stick on the first one at a right angle
  3. Bind the two sticks with the square lashing
  4. Add the third stick for the third axis
  5. Continue the square lashing
  6. Finish with the square knot
  7. Repeat on all the corners
Note: the rigidity of the structure depends on the tightness of the knots. Do the knots one step at a time, maintaining a reasonable tension on the rope while knotting.
Step 4: Finishing
When all the corners are bound together, slide the sticks to straighten the structure, but of course it will be more solid if the sticks are almost at the right place when assembled.
This technique is easily adaptable at large scales to build shelters or even forest furniture.
You're cube is now ready to be used for something creative!
Mine serves now as a picnic platform for my little parrot.
    • Casting Contest
      Casting Contest
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    I tried building one similar for chicken coop with composting, but was not successful.
    Then I found this page -
    my failed method - clove hitch, square lashing of two poles finish with clove hitch - add another pole for third axis then square lashing. First I built two rectangle frames (top and bottom), then added the poles for sides. They all fell. Will try your method -
