Basic Encoder
Published
Introduction: Basic Encoder
About: I'm engineer and like to design electronic and programming things with Arduino hardware.
This project was developed so that you have a basic knowledge about what an encoder is. With 9 switches and 15 diodes (1N914), you can construct an encoder that can also monitor it with 4 LEDs for observing the binary codes-- from 1 to 9.
Step 1: Bill of Materials
1 Breadboard (830 points)
9 Tactile switches
15 Diodes (1N914)
1 Jumper wires packet for breadboard
4 Red LEDs
4 Resistors of 220 Ohm
What you will need:
Multimeter
Analog or Digital Caliper
Any Cable Cutter
Step 2: Installing the Switches
When installing the switches, you should connect their upside to the positive terminal with the orange wires.
Step 3: Checking the Diodes
For recognizing a diode, it.is necessary that on it be checked its cathode terminal. That side of your diode is marked with a black line. Also note that, you should cut the leads of the diodes until obtaining a measure of an inch considering the diode body.
Step 4: Installing the Diodes
When installing the diodes, interconnect them and reserve for the follow step. Without forgetting to observe the diagram of your project so that you make sure of each connection that you do.
Step 5: Observing the Diagram
Observe the diagram of your project if you want to have the best results. That is, I had better study carefully the diagram before beginning to do any connection in the project.
Step 6: Checking the LEDs
For checking a LED, it is necessary that it be observed on its terminals so that you can identify the cathode lead or using your multimeter for obtaining the same result. Then cut the LED leads with approximation of an inch if necessary.
Step 7: Installing the LEDs & Resistors
Installing the LEDs and resistors is only a part of this step because it also implies to connect the cathodes of the diodes to the LED anodes so that you can connect the resistors to both LED cathodes and GND of the whole circuit.
Step 8: Completing the Project
Connect the switches at the rest of the circuit so that you complete this project. That is, check each one of the connections done in the project and compare those with the diagram of your own project and so you make sure of what you did..
Step 9: Probing the Project
For probing the encoder, you need to connect to +5V and so having the enough power to work with this project.
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Make it Move Contest
    32 Comments
    This project can also be seen in Amazon webpage at:
    https://www.amazon.com/JAMECO-KITPRO-Basic-Encoder-Kit/dp/B00R5CDX3M/ref=sr_1_sc_1?ie=UTF8&qid=1481317730&sr=8-1-spell&keywords=Basic+Encodert%2C+jameco+electronics
    This project can also be seen in Jameco Electronics at:
    http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&productId=2214627&catalogId=10001&CID=CLO
    LEATHERWORKING classes are now free in this site.
    PHOTOGRAPHY classes are now free in this site.
    BREAD classes are now free in this site.
    CANNING PRESERVING classes are now free in this site.
    WOODWORKING classes are now free in this site.
    GLUE classes are now free in this site.
    CONCRETE classes are now free in this site.
    MEAT classes are now free in this site.
    WEARABLE ELECTRONICS classes are now free in this site.
    RASPBERRY PI classes are now free in this site.
    LASER CUTTING classes are now free in this site.
    LAMPS classes are now free in this site.
    CNC classes are now free in this site.
    3D PRINTING classes are now free in this site.
    Robots classes are now free in this site.
    Electronic classes are now free in this site.
    Arduino classes are now free in this site.
    LEDS & LIGHTING classes are now free in this site.
