3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Basic Gas Blow Back airsoft pistol maintenance: FIeld stripping and lubricating.
If you own a gas blow back airsoft pistol, you should be lubricating it at least every 3000 shots you fire to maintain the guns accuracy and prolong the life of your gun, this instructable will show you how to properly field strip your gun, as well as show you how to lubricate your gun, bear in mind that this is only a basic guide and does not cover cleaning, repairs etc, i may include that in a future instructable if i get enough interest. The gun that i will be using for this instructable will the an LS M9 gas blow back pistol that fires at about 300 FPS, this will be the second time that i have lubricated this gun, so it should last me a fair while to come.
The field stripping and lubrication of your gun may vary to this guide so you may have to familiarize yourself with the way your gun strips (levers, buttons, slide release etc) but if you own an M9 then this should be practically the same for you as most strip in the same way, so enough chat and lets get on with the instructable!
NOTE: This gun used to be clear, so if you get the same one as me it wont look like this...you should only alter the appearance of an airsoft gun if you are a registered airsofter depending on your countries airsoft policies.
Step 1What you need.
What you need.
Very simply, all you need is your gun, and a small tube of silicone oil. DO NOT use anything other than silicone oil as this is what keeps your O rings in good condition, any other oil would degrade your O rings and make your gun function badly, so if you don't have any silicone oil, it would be worth going into any hardware store and getting some. NOTE: It does not need to be airsoft specific, you can get silicone oil for household or automotive use for much cheaper than airsoft silicone oil, so i recommend getting hold of some of that type of silicone oil rather than the airsoft specific stuff, does the same job, much cheaper.
10 comments
Dec 27, 2011. 7:39 PMtyrolee says:
Well if you have a airsoft innovations adapter you can use pc duster
Apr 20, 2011. 12:24 PMTH3MAST3R says:
where did you get this airsoft gun
Oct 9, 2009. 9:52 PMbrandon borick says:
hey is there a way to lower the fps on a gbb
more spacificly a agm m4 gbb
Oct 10, 2009. 5:22 PMbrandon borick says:
propains all i can get and i add a drop of silicon oil in the adapter afere every use
Oct 13, 2009. 8:43 PMbrandon borick says:
noy for 12 dollors a can i thought propan lowered fps anyway
 im hank hill and i sell propan and propan acesserys
terrebly spellingz
Oct 7, 2010. 9:00 PMxana says:
http://www.airsplat.com/Items/GG-1100.htm
Oct 13, 2009. 8:44 PMbrandon borick says:
ment not not noy rated five starse
Apr 14, 2011. 2:20 AMbrandon borick says:
sorry just found this my friend trying to type to be british i think pleas dont hate me i can spell
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:bedbugg2
I like mountain biking, its my main sport and i own 2 bikes so anything to do with bikes interests me, i also used to make K'nex guns but have since retired...to making instructables about games and o...
more »
