Introduction: SIMPLE Knex Gun
A GREAT secondary weapon for knex (I think) if you have made mods for it please post them. I would like to see, and possibly make them, and add them to my gun!!!! This gun is superb for people who dont have alot of knex.  PLEASE be nice as this is my first Instructable thing.
Heres a parts list: (aprox.)
Pole things:                      Connectors:                        Other:
Grey: 4                                White:8                                Tan Clips:11
Yellow:1                             Yellow:8                               Fist:12
Blue:2                                 Green:2                               Grey spacer:6
White:8                               Red:3                                   Blue spacer:3
Green:14                            Orange:3                            Sellotape strips:1
                                             Grey:4                                  Rubber bands:3 or more
Sorry about the blurry pictures the camera is old.
Step 1: The Main Body
The bit at the top of the gun it is also the barrel! This is very simple.
1. Make
2. Add to part one
3. Add this
4. Add more
5. Make two
6. Attach the two together (see the greens)
7. Add the other one!
Step 2: The Trigger
This part will block the firing pin and allow the gun to fire. SO SO SIMPLE.
1. Make
2. Add the grey
3. add the other grey through the circle on it.
Step 3: The Handle
The handle is quite comfortable very simple but if you have more pieces you can modify it. This is a moderate make.
1. Make two
2. Add the supports
3. connect the two parts together
4. Second angle
Step 4: The Magazine
The magazine gives a better affect on the guns handling and improves fire rate. But on this gun it might break so...   MODIFY IT. This part is also moderate.
1. Make
2. Make both
3. Add to only one of them
4. Attach
5. Attach
6. Add the greens.
Step 5: Adding All of the Parts Together
I'm surprised if you've read this far....  This is basically the assembly of all the pieces you've made.
 This is quite hard.
1. The trigger goes in between the to greens on the barrel
2. Add a rubber band from the place shown on the picture
3. Other angle of the trigger
4. The handle goes at behind the trigger as shown in the picture
5. Magazine clips on to the snowflakes at the front
6. You have the gun but the firing pin and the mag pusher need to be made...
Step 6: Magazine Pusher and Firing Pin
This two parts will allow the gun to actually fire and to auto-reload. One word.... SIMPLE         These pictures are blurry so please strain your eyes!!
1. Make note the sellotape
2. Add to a grey pole
3. Make
Step 7: The Rubber Bands!
The rubber bands cause the gun to fire. SIMPLE if you have rubber bands.
1. The mag band stretches over the top of the gun
2. The final band stretches from the firing pin ,which is now in the barrel, all the way to the front of the barrel. If your band doesn't go that far make an alternative
Step 8: Loading and Firing
To load, fill the mag with white poles. To cock the gun pull the pin back and wait for the click of the trigger. To fire... well thats obvious but for the beginners... pull the trigger.
    • Trash to Treasure
      Trash to Treasure
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    meh... its ok
    have you added bands and moded it that makes alot of difference
    havent made it yet! lol
    ill try it after my ball machine ( ill add a ible )
    k, thanks!
    no problem!
