Basic Minecraft Skills
35,725
42
33
Posted in PlayMinecraft
Introduction: Basic Minecraft Skills
About: I like doing neat stuff, including playing tennis, biking, DIYing, and making stuff.
This instructable will show you the basic survival skills to get past your first day in Minecraft.
Henceforth, "Harvest" means left click and hold until said block has dissapeared and you are able to collect it, and "Place" means to right click in said place with said block weilded.  Also henceforth,  if "Realtime" is not in front of "Day" it means that the day in an in game day.  If "Realtime" is in front of "day", it means an actual 24-hour day.
To henceforth again, henceforth, a "Mob" is anything that has the ability to move between and across blocks without the player touching, or adding anything to it. (E.G. sheep, ducks, spiders, zombies)
All of this is advice and how-to's for a beginner player in Minecraft.  You should advance and do more daring things once you are comfortable with these skills.  That should not take too long, if you play regularly.
Step 1: Punch That Wood! (or Dirt)
Your going to need a shelter and some light sources.  What do you do?  Get some tools!  (or dirt)  You can make tools by harvesting the tree logs.  Once you have about 5 logs, press "i", and make some planks (http://www.minecraftwiki.net/wiki/Crafting  This gives you information on how to make whatever you can make, what you need for them, and many other facts about the item.)  After you make the planks, make a wood pickaxe.
Now you need to find some coal.  Normally it is quite easy to find.  It looks like a normal stone block with black speck in it.  Mine/Harvest it, and collect the coal.  Then, make a torch (again, please refer to the crafting link I shared above.)
Now you can harvest anything you can see and make it into a house.  The building of the basic house is self explanitory.
At first, it will probably be just a small cube, then you will want to expand it, or build elsewhere.  You get to pick where you want to be.  You could be underwater, which would be a huge hassle on the first day.  You could be on a plain, which would be very good for a beginner, or you could be underground or in/on a cliff.  The last is my favorite, but making it look good is hard sometimes.
Step 2: Crafting/Smithing
Crafting is not exactly like the other parts of minecraft.  You cannot exactly make up a new tool.  But, even though crafting is crafting,  it must be learned.
Once you have punched the wood, and made a workbench,  It is time for you to make a few tools.  I will only be showing you how to make the basic and needed tools and items for now.  These are:
Pickaxes
Shovels
Spades
Axes
Minecart
Minecart tracks
Boat
Flint and steel
Torches
Glass
Ingots (Iron, Gold)
Etc.
Once you have a basic understanding of where the ingredients go for each item, all the other items are quite easy to remember.
These pictures are from the crafting page on the minecraft wiki:
Step 3: Your House.
When you begin, your house should be near/on the spawn point because it is easy to lose your way in the beggining. Also, do not get discoraged by photos you see online that have huge houses and intricate redstone gates for the doors.  That will be you.  If you have patience, and work at it.  The first day, your house will be small, and you will need to light it... Unless you want to be fighting mobs all throughout the night.  This is simple.  Just place the torches that you have so that they light the house.  Normally, the house is a one room house as you begin, so this should be easy.
Step 4: NIGHT TIME!!! (Dun Dun Dunnnnnn!)
During the night,  monsters come out, and bad things happen to you if you are outside.  Normally, you don't go outside unless you are sure you won't die... or your on peaceful mode.  Anyway, you are on Easy or above, and it's your first night. What do you do?
Wait.
Unless, of course, you happened to get some stone along with that coal I told you to get earlier.  If you did, you may have noticed that the item that you collected was not stone.   Your right.  That's cobblestone you collected.  Ill talk about that later.
If you do have things that you can make into other things, and you want to use those things that you have to make into other things that you will have if you choose to make them with the things that you already have,  then by all means, go ahead and make tools and other things.
But if you don't.
You must wait until DAWN!!!
Step 5: The Next Day. (And Mining)
Congratulations, you survived your first night! (Or, not)
The next day, you can do pretty much what ever you want.  Go kill cows, if you like!
If you choose to mine, then mine.  But, there are always dangers...  As long as you are on easy or above.  When mining, you may still run into some of the creatures of the night.  Because in caves, it's always night.
Step 6: More Mining.
You will find many things when mining.  All of them can be found here : http://www.minecraftwiki.net/wiki/Blocks
How to deal with mobs attacking.
If you run into a mob while mining, normally if it is a creeper or skeleton, i keep my distance, and kill them in quick attacks.
If it is any other mob, i just make sure that i don't get hit, and swing my sword (or anything else that i have) at it.
If you find a mob anywhere that you have already been, and plan on being a lot more often, then it's not lit enough.   Use the torches and light it up
I run into huge cave systems, and I still sometimes lose my way.  if you want to prevent that, it helps to lay something that is not native to the cave down.  when i do this, i go at least 10 blocks away before i lay it down again.  If you have minecart tracks, then those help, too, but you might want to lay them down in adjacent blocks, and lay them in such a way that you can actually ride a cart down into your mine.
Step 7: Mob Abilities/ Dealing With Mobs.
Mobs can be very frustrating.  That is why you need to know what they can do.  Good mobs (Animals) generally do not hurt you, or destroy buildings, or be a pain.  Just watch out for them when you are on cliffs.
Bad mobs (Monsters) are what you will be learning about here.
There have been instances where there is a "Mount."  This is a skeleton riding a spider.  These are extremely dangerous.  They can move fast and shoot arrows at you.  Only attack these with a bow and arrow if you want to stay safe as a beginner.
Version 1.2 added squids.  these spawn any depth in any light in any difficulty. They drop ink sacks when killed, and they are passive.
Step 8: The Nether
The Nether is near the center of the earth, like an underworld, and lets you travel eight times faster.  This is also the place where zombie-pig-men scream in pain as they wander aimlessly.  This is the place without water.  This is the place where giant flying ghost-jellyfish shoot exploding fireballs at anything they want to. (Mainly you)  This is the place where Instead of the sky, there is bloodstone.  This is the place of Lightstone and Hellmud.  This is the place of lava oceans.  This is the place of huge cliifs, and when you mis-step, you fall large heights to your death.  This is The Nether.  This is pure danger.
You can get into and out of The Nether by a portal.  You can make a portal by placing 14 obsidian block in a 4x5 square, and then lighting one of the inside blocks with flint and steel.  You can move eight times further with each step than in the regular world, so it is very useful for travel, but it is vastly more dangerous than the regular world, too.
Step 9: FIN! (for Now)
As you should know, minecraft is regularly updated with new features.  If you think that I missed something, or that something needs to be added, just tell me.  Also, I will answer any questions that you have.
Also, an upcoming installment on how to use redstone logic gates (or just plain redstone for remote ignition, Etc.) for doors and other things.
If you would like to read about other things in minecraft, go to these sites:
The official minecraft site:
www.minecraft.net
Notch's blog:
notch.tumblr.com
or the Minecraft Forums!:
www.minecraftforum.net
The Minecraft Wiki!:
http://www.minecraftwiki.net/wiki/Minecraft_Wiki
Step 10: Afternotes
Dieing in Minecraft is ALWAYS an option.  It just might not be the option that you want.  Many people die their first night, or even DAY in minecraft.  For example:  I accedentally drowned while trying to make an underwater sand fort as my house the first day.  A friend of mine was pushed of a huge (huge) cliff by a sheep, and fell to her death.  And, I have seen people die thinking that they could dig a deep hole in the beach, and put multiple blocks of sand above them, consequently trapping, crushing, and suffocating them as their first death.
And, As a finisher to the 'Ible, here are a few skins that i made. (The masks/ Helmets/ Hoods do work in multiplayer.
    • Make it Move Contest
    • Slow Cooker Challenge
    • Outdoor Fitness Challenge
    33 Comments
    I only need this for my homework, eventually I got tired of writing this; Minecraft
    Have you heard of minecraft? It is a
    sandbox game where there is only one point: to kill the ender dragon, but to do
    that you have to do the following:
    1) Get wood
    2) Make a pickaxe
    3) Mine
    4) Make better pickaxes
    5) YYYYAAAAYYYY! DIAMONDS!
    6) Mine the volcanic glass: obsidian
    10
    7) Make a nether portal
    8) Travel to the nether
    9) Find the nether fortress
    10) Kill blazes
    11) Go back to the overworld and
    kill enderman
    12) Make eyes of ender 12
    13) Find the ender fortress
    14) Place the eyes of ender into the
    ender portal frame
    15) Kill the ender dragon in the end
    That’s
    it.
    The basics
    Minecraft was made by Markus Alexej Persson,
    a Swedish programmer who had called himself a “nerd” because he was
    always interested in computers since he was 9 years old. He was born June 1,
    1979, he is also called notch. Notch looks like this, he created
    the tech demo for Minecraft in 2009, and most people liked it, so he worked on
    it and the official launcher to Minecraft was released in 2011.
    There is
    no actual point except to kill the ender dragon but people make up their own
    goals like do all the achievements or mine out the whole world, which will
    probably take forever. Also Minecraft is very informative and it teaches you a
    lot of things, for instance, did you hear of Redstone? Did you hear of andesite?
    I am sure you do not but I am an expert in Minecraft because I know every ore
    in your cubic world with no boundaries except bedrock. Bedrock is unbreakable
    even in real life! Yes it not just what Notch wanted to make up but it does exist.
    From the event when Mojang sold Minecraft to Microsoft®
    there is a lot of new stuff from the 1.8 update like the guardian, rabbit, and
    the endermite which are mobs, there were changes to the mobs;
    Villagers- They now farm their own crops (harvesting and replanting, and
    making wheat into bread) and have some new professions (like Fisherman and
    Shepherd). They can also turn into witches if hit by lightning.
    Wolves -Will now attack skeletons.
    Skeletons -Will now run away from wolves.
    Slimes -Can now swim.
    Spiders -Can no longer see you through opaque blocks.
    Blazes -Can shoot players through solid blocks.
    Creepers -Run away from other creepers that are about to explode.
    Also they added new ores like Granite, Andesite, Diorite,
    Prismarine, Sea Lantern, and the wet sponge which is used to absorb water, because in
    the previous updates sponges were only available in creative mode and they were
    pointless because they were not used for anything, so nobody cared about them.
    My opinion about Minecraft
    is that it is the second best game ever made because my first favorite game is Gary's
    mod or Gmod, and the third best game ever is . . . Sims 4!
    Creative mode is a
    gamemode where players have infinite resources and they are invincible. In
    survival mode you have hearts which are lives. Half-a-heart equals 1 hp, hp
    means, health point and if something hits you, you will lose a certain amount of
    hp, but I cannot tell you exactly because damage may vary. It comes from
    hostile mobs and natural damage such as drowning, burning, and fall damage.
    Hostile means the
    opposite of friendly ヅ. You may meet hostile mobs at night, but I never
    recommend looking for mobs, if you want to do that; not the first night because
    that is suicidal. One thing I forgot to mention is the shapes, everything is
    cubic.This is diamond ore with shaders. And no shaders
    12,000,000 peopleplay Minecraft on the pc,9,000,000 people play it on the Xbox, and6,000,000 people play it on the iPad, iPod, or android, and20,000 people buy the game daily, and3,200,000 people log on and play it each day on all of the
    versions, and5 people buy the game in a second, so27,659,254 people own Minecraft today.
    Wat seed is ths
    You needn't search for coal . Instead , gather logs and make charcoal ! It can be crafted into torches and used as a fuel , but unfortunately it cannot be crafted into blocks :(
    Hehe, I just uploaded the official 1.2 release... and now the zombies can bash your doors open! THAT was a surprise!
    U play hard mode then?
    way to comment after 1.4 is already out
    oh ok but the zombies breaking door feature was added in 1.2.5
    The 40 down theirs some one flying in the back round
    I have that airsoft gun
    Jump to THE sky my friend....i killed my pet cow,pig,and sheep cause i left the server for a day !:(
    that pretty much covers everything except the end
    a helpful tip i didn't know for a lang time, if you burn a wood block with a wood in furnace you get charcoal which is basically coal. i didn't see it in your instructables thats why i posted it
    what version is this ible on
