Basic Ring
369
Posted in Technology3D-Printing
Introduction: Basic Ring
The following information is a single lesson in a larger Tinkercad project. Check out this and more projects on Tinkercad.
In this lesson you will learn to make a ring using Cylinder shapes. Here we go!
  1. Drag a cylinder to the workplane and make it a hole.
Step 1: Basic Ring
  1. The cylinder should be scaled to fit the finger it is being made for.
  2. We will use 17mm for the diameter in this example, but feel free to adjust the size to your needs.
Step 2: Basic Ring
  1. Drag a Cylinder shape to the workplane. This will make the outside of the ring.
Step 3: Basic Ring
  1. Scale the new cylinder to be 4mm larger than the cylinder hole.
  2. Since we used 17mm we will scale the diameter to 21mm (17mm + 4mm = 21mm).
  3. If for example your cylinder hole is 10mm, then you would need to scale to a diameter of 14mm (10mm + 4mm = 14mm)
Step 4: Basic Ring
  1. Select both shapes and scale them to a height of 4mm.
Step 5: Basic Ring
  1. Keep both items selected and group them together using the group button on the menu bar.
Step 6: Basic Ring
  1. Rotate the ring so it is standing up on the workplane.
Step 7: Basic Ring
    Great Job! You made it!
    Now that you know how to create a ring, you may want to try adding a decoration to your ring.
      • Microcontroller Contest
      • Woodworking Contest
        Woodworking Contest
      • Make it Move Contest
