loading
These aren't the big party tricks that amaze and astound friends, these are the ones that make them go, 'woah cool, how'd ya do that?' or 'nice, pretty slick'
These are the basics and are just things to do while you're bored or a new way to light your zippo, it's made as a follow up to Rewicking and reflinting your zippo.
Watch the video to see all the tricks done, it's only on the first and last step so people with slower connections aren't loading it every time they look at a new step. Also it's designed as a run-down of them, As of yet I don't have a camera with a high enough frame rate to capture the motions involved and slow them down effectively, at 30FPS most of these happen over a couple of frames.
Once You've mastered these you can go on to the second set of Zippo tricks
Step 1: Click your fingers...
This is an easy trick, when executed quickly and smoothly it looks really slick and it's actually quite hard to see what's going on...
All you do is click your finger near your zippo and it lights... Hmm not the normal way of doing it.
The secret to this easy trick is simply putting your clicking finger against the flint wheel, usually your middle finger, as your finger snaps down against your hand it spins the flintwheel, it looks pretty slick if you flip open your zippo and pass your hand right by it clicking, it lights...
The whole point here is just to have a normal scenario, not a big trick, people aren't looking for the method they just notice someone light their zippo with the click of a finger...
So again:
- Middle finger against flintwheel
- Click down hard while moving hand away
- Get admiration and free drinks
Doing it while moving is basically the same except you need to be able to click just as your hand passes the flintwheel...
Step 2: Snap Shut.
This is possibly the most well known and basic zippo trick, it's not complicated but it's pretty slick and attention grabbing, it makes a really nice snap sound.
Basically instead of closing the case with your other hand you snap it shut by flicking your wrist towards the other side of your body. The case will naturally snap shut.
However this isn't as good a snap, it's a much better sounds and looks cooler if you flick your wrist outwards then stop or back in a bit quite hard, the lighter snaps shut loudly and for some inexplicable reason mine sparks just as it closes...
Another variation on this one is to simply snap the side opposite the hinge against the palm of your hand, it'll snap shut that way and the motion looks nice when you hear the proper snap...
Step 3: The Squeeze.
Though this trick has been covered in another 'Ible I'm covering it in this one, mainly because some wont get thornburg's 'ible and some wont get mine...
It's a slightly harder trick and takes some practice, the basic rundown is to squeeze the lighter in your index and middle fingers and have it pop open and round so you're holding it...
So you put your index and middle fingers on top of the lighter case and your thumb goes down at the bottom...
The hinge should point towards the other side of your body, so if it's in your right hand it points left and Vice versa...
Try squeezing a bit to get a feel for when the lighters about to flip over.
Once you get a feel squeeze hard in one fast motion, the lighter flips into your awaiting fingers while popping open like some kind of arsonist jack in the box...
Step 4: The slice.
This one is dead easy and simply takes just a little practice getting the hang of catching the wheel on your way back.
Hold the lighter so the hinge is facing away from you.
Slice your hand across the top opening the lid, on the way back slice across again and turn your wrist a little to catch the wheel, the lighter lights up...
The slice is another dead easy move, it takes just a little skill but will have your mates trying to do it for half an hour, usually they hit the flintwheel going both ways and it wont spin on the way back...
Step 5: Black magic.
This one is great for amazing and astounding, not to mention surprisingly easy to master at the end of the day.
The first bit to this is setting up. You need to make a little arch in your wick, like the photo.
Now try lighting it and pulling your thumb and forefinger across the chimney, the flame should disappear, now wave your hand past the lighter or blow on it.
If it doesn't relight then you need to adjust the shape of the wick, what you are looking to create is a little space underneath the arch in the wick where a small flame can effectively hide and stay lit when the larger flame is out.
The reason the lighter relights when you disturb it is that the flame catches the vapour coming from the top of the wick. Once you start to get a feel for this you can invent your own way of causing the lighter to re-light, I personally like setting it on a table and stealing the flame then snapping my fingers while swinging my hand over it.
Others include saying something and giving it a tiny shake or pretend to pop the essence of the flame in your mouth, then slowly bring your hand flat and level with the chimney. Blow gently across your hand and let onlookers be amazed.
Step 6: Some other little things to do...
Well when you're sitting bored...
Flipping your zippo like a coin is always amusing, if you catch it just right you can flip it open and light it just after catching it... Or catch it and do a thumb or palm squeeze...
Another good trick and bar bet is to set a bottle (empty) on top of the zippo lying flat on the table, bet you can't get the lighter out without touching or knocking the bottle over.
Now this one is usually done by sliding your index fingers across the table towards the table, however that's just not cool enough for us...
Instead take your hands and get ready to click your fingers, put the middle ones against the lighter, Build up lots of tension in your hands and snap hard, the lighter will shoot out from under the bottle, the bottle will pop on to the table, wobble precariously and stand up.
Once you get really good you can use on hand to click, spinning the lighter out and into your other hand, this looks best if it's all just sitting set up and you simply bring your hand out click and catch the lighter, people are usually pretty impressed by this really easy trick.
It works much better with the likes of a plain brushed steel or polished one, designs tend to slow it down a bit...
Want to learn more tricks, the next instructable is already up, Right here!
<p>If your Zippo lights when you close it, the lighter assembly is up too high. Just push it down every now and then.</p>
I want a zippo now.
<p>seventhed</p>
too bad... i just got one today... i cant twentiethted lol
me too
i got one today to, its a chevy one :D
I got one!!
Seconded.
thirded
fourthe-- wait a minute....
fifthed. lol
sixthed
C'mon people, keep it going!
Okay, TWENTYTHED!!!
twentyfirstth
21ndthed
seventhed
eighth...lolz
um..ninthed?
lol
Me too. I have one, but it's one of the tall ones. You can't really do any tricks with those.
Nyah nyah, I have two silver ones and a slim one...
<p>Seventhed</p>
<p>seventhed</p>
<p>https://www.youtube.com/watch?v=5fmOtJzBKTs </p>
<p><iframe allowfullscreen="" frameborder="0" height="281" src="//www.youtube.com/embed/5fmOtJzBKTs" width="500"></iframe></p><p><br></p>
<p>its not working :/</p>
where can i get a zippo
<p>On dx.com you can have one for a few bucks ;)</p>
the wordage in this article bothered me so much i created an account. you snap your fingers, not &quot;click&quot; them...
I'm guessing we live in different parts of the world... Neither's wrong... <br> <br>As for the unclear thing - I went for simple. Autistic I ain't.
the lid probably hits the flint wheel
yay i got my first zippo today heres a pic:
Sorry, but thats a counterfeit zippo on real Zippo's the top does not go al the way down and Zippo's have 5 holes on the chimney oh and does it say zippo on the bottom
Acctually the bottom goes all the way down becuase ive worn it out and look at the ibles 1st step,killerjackalopes zippo has 7 holes
actually its eight<br>
i counted 7
Nah, it pretty definitely has eight; in the first photograph that you can see the holes, one is obscured by the curve, but looking in other photos you can see that it is there
Real zippos have 8, I just bought one.
Hmm what about the zippo in the instructablr?
Then it is fake.
My Dad caught me smoking at age 11, then he bought a pack of cigarettes and made me smoke the whole thing! I got addicted to cigarettes since then! <br>I own, a collection of Zippo lighters. 1 14K Gold , 7 Sterling Silver, 14 brass, 6 Stainless Steel. I have been looking for a copper one.
The black magic trick is amazing!!!!!! :-)
it was better when it was called The Twilight zone... many tricks have names, should have been around a few years ago when zippotricks.com / lightertricks.com was around. nowadays people are just ripping off old tricks as their own
Thanks, its such a cool little effect... It's also really good to play with, like doing it then lighting something by clicking your fingers instead of making a show of the whole trick...
About This Instructable
775,857views
239favorites
License:
Bio: A Northern Ireland based maker with a propensity to cause trouble and freshly constructed family.
More by killerjackalope:Stroboscopic Zoomography Balsamic Chilli Sweet Potato Fries Wire Belt Hook for Drills
Add instructable to:
