3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Batarang from "Arkham Asylum" Game
Batarang from \"Arkham Asylum\" Game
This is an instructable for making a replica of the batarang seen in the game “Batman: Arkham Asylum.” I wanted a batarang that unfolded with an action similar that that in the game. Not counting the cost of the tools, which I had already, and the paint (ditto), the entire project cost me about $17 and took perhaps 10 hours.
Step 1Tools and Shopping List
I decided to make this prototype batarang out of Plexiglass, because a) it is easy to work b) it has no grain and doesn’t splinter or chip c) it is transparent, which helps with aligning the pieces d) it takes a metallic paint better than wood, and, finally, e) I didn’t have access to a metal-cutting bandsaw. Needless to say, you won’t be knocking any thugs unconscious with this one. You probably won’t be throwing it anywhere, either, unless you want to see your hard work shatter into bits.
Shopping list:
.093”x11”x14” Lexan (or Plexiglass) sheet
Furniture joint connector nut, ¼”-20 thread
¼” x 3/8 flathead machine screw
four neodymium disc magnets .47” x .11” (12mm x 3mm)
Tools required:
Coping saw
Straight and curved files
Power drill
Various drill bits, including a ½” spade woodborer
“Liquid Nails” clear silicone adhesive
Cyanoacrylate superglue
Two part epoxy resin
Sandpaper
68 comments
1-40 of 68next »
May 24, 2012. 9:18 PMoptimus_89 says:
hi can anyone tell me how to download the pdf?
May 14, 2012. 2:14 PMcprich22 says:
Do you have any rough dimensions for it? such as the height and length of the blades?, i printed out your template and made a card version and i found it so be a little on the small size, a rough idea on how big yours is would make it alot easyer to scale the drawing up. thanks
May 16, 2012. 9:01 AMcprich22 says:
sure, im in no particular hurry
Oct 22, 2011. 6:17 PMcurious youth says:
great ible my friend but may i ask for a link to a website you may know for cheap lexan? see i am from australia and im finding it hard to track some down
Oct 22, 2011. 8:04 PMcurious youth says:
ok then i shall look around. hopefully i can find some thanks :)
it really bugs me that alot of my creating and modding work is halted because i need to track down products that are so easily accessible in the us
Apr 25, 2011. 5:48 PMEGT1984 says:
What did you use for the "cap" that hides the screw?
Aug 16, 2010. 5:20 PMbluesquirrel says:
This is pretty cool! And better yet, it translates into instructions for making almost any retractable throwing-blade type thing (ninja stars, batarangs, etc etc) for a costume :D
Apr 25, 2011. 5:47 PMEGT1984 says:
One could even make a Bird-a-rang (Robin's version) if they wanted to.
Apr 24, 2011. 1:56 PMEGT1984 says:
Be sure to check for protective sheets of plastic before one transfers the pattern to the plexi-glass.
Dec 12, 2010. 4:22 PMpaco_91 says:
Thanks looks amazing!
Nov 12, 2010. 6:29 PMoud25 says:
im looking at coil springs from knives and stuff so it will whip out and stuff but u would have to use a stronger material probably
Aug 20, 2010. 9:33 PMseltzer10 says:
dude i like it you should make steel one!
Aug 23, 2010. 4:16 PMHamzah says:
yeah, I agree. but, how to install the magnet on the metal?
Sep 1, 2010. 3:51 AMdevinda says:
ya , isn 't there another stronger substance
Nov 12, 2010. 6:27 PMoud25 says:
kydex but its pretty expensive
Sep 29, 2010. 8:16 PMGage987 says:
I wish the one I got with the collector's adittion opened like that
Nov 9, 2010. 11:27 AMknoxmj19 says:
Amen, What a let-down that piece of crap was!
Oct 6, 2010. 12:55 PMdr.zedd says:
now that is gaddang good sir. would you consider doing these via commission?
Sep 24, 2010. 9:33 PMmephit says:
Just as a note to others looking for the furniture connector. These are called chicago screws, screw posts, or (and no, I'm not kidding) sex bolts. You can find them in nylon, aluminum, steel, etc. and flat, phillips, allen, torx, whatever heads.
Sep 1, 2010. 3:32 PMFFVIIBOY says:
this so awesome
Sep 1, 2010. 3:52 AMdevinda says:
Good work, i am making it as a gift
Aug 22, 2010. 12:30 PMTecDroiD says:
does it really work like a boomerang? i'd like to see some video :)
Aug 23, 2010. 10:49 PMkaterpeter says:
i'd imagin you cold fashion the plexiglass with a sander to match that of a boomerang... although i'm not sure if the abscence of a 90 degree angle will matter or not... awesome craftsmanship, two thumbs way up
Aug 29, 2010. 6:08 PMInfiniTTTy says:
Beautiful! That explains it. Thanks!
Aug 29, 2010. 7:48 AMInfiniTTTy says:
I don't get how the batarang folds in half (as in the video). The pieces don't seem to allow for that kind of movement / position. Can you post some more pics (side view + folded up) or a video? Thanks!
Aug 26, 2010. 2:23 AMbartongang says:
Could you post all of the stencils please?!?!? (pivot wing, fixed wing, and back peice) I am a really bad drawer lol If you could that would be GREAT Thanks
Aug 29, 2010. 7:34 AMInfiniTTTy says:
Thanks for including my new stencil!
Aug 23, 2010. 8:55 PMlint66 says:
Could you use a dremil to do some of the fine detailing around the wing?
1-40 of 68next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:spookylean(CookRookery)
