3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Batarang from "Arkham Asylum" Game
Step 5Making the Axle
Making the Axle
Now make the axle of the batarang. Tape the two wings together in the final position, and drill a pilot hole though the center. Separate the wings again, and drill a hole in the pivoting wing just large enough to accept the machine screw fairly tightly (15/64” was right for me). Then through the fixed wing assembly drill a hole large enough to accept the furniture joint connector (3/8” was perfect). The connector needs to pivot smoothly but not be loose.
I then countersunk the machine screw hole in the pivoting wing, and, using the large 3/8” bit, recessed the other side of the hole to accept a small portion of the furniture connector. This was because the furniture connector was a little too long and I didn’t want the wing to be loose when folded up. I could also have ground down the connector a bit but this seemed easier, and it worked fine.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:spookylean(CookRookery)
