3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Batarang from "Arkham Asylum" Game
Step 7Finishing Up
Finishing Up
You can now assemble the batarang. I glued a little plastic widget over the machine screw head to cover it. You can still take the batarang apart by unscrewing the furniture connector from the rear. This is why you want to machine screw to be fairly tightly in place.
When this is done, you are almost finished! All it needs is any final shaping and filing, a bit of sanding of the edges, and you are ready to paint. I used a satin black spray paint specifically for plastic, and bronze model paint for the wing bevels.
15 comments
Apr 25, 2011. 5:48 PMEGT1984 says:
What did you use for the "cap" that hides the screw?
Nov 12, 2010. 6:29 PMoud25 says:
im looking at coil springs from knives and stuff so it will whip out and stuff but u would have to use a stronger material probably
Aug 20, 2010. 9:33 PMseltzer10 says:
dude i like it you should make steel one!
Aug 23, 2010. 4:16 PMHamzah says:
yeah, I agree. but, how to install the magnet on the metal?
Sep 1, 2010. 3:51 AMdevinda says:
ya , isn 't there another stronger substance
Nov 12, 2010. 6:27 PMoud25 says:
kydex but its pretty expensive
Sep 24, 2010. 9:33 PMmephit says:
Just as a note to others looking for the furniture connector. These are called chicago screws, screw posts, or (and no, I'm not kidding) sex bolts. You can find them in nylon, aluminum, steel, etc. and flat, phillips, allen, torx, whatever heads.
Sep 1, 2010. 3:52 AMdevinda says:
Good work, i am making it as a gift
Aug 22, 2010. 12:30 PMTecDroiD says:
does it really work like a boomerang? i'd like to see some video :)
Aug 23, 2010. 10:49 PMkaterpeter says:
i'd imagin you cold fashion the plexiglass with a sander to match that of a boomerang... although i'm not sure if the abscence of a 90 degree angle will matter or not... awesome craftsmanship, two thumbs way up
Aug 29, 2010. 6:08 PMInfiniTTTy says:
Beautiful! That explains it. Thanks!
Aug 29, 2010. 7:48 AMInfiniTTTy says:
I don't get how the batarang folds in half (as in the video). The pieces don't seem to allow for that kind of movement / position. Can you post some more pics (side view + folded up) or a video? Thanks!
Aug 23, 2010. 3:09 AMTommy B says:
Nice work!
Aug 23, 2010. 2:16 AM_-hcm-_ says:
That's incredible! Good work
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:spookylean(CookRookery)
