Batch Colours, Using Batch
Published
Introduction: Batch Colours, Using Batch
First Off I Must Say That Prof. Pickle Helped Me Fix This Batch File And for That I Must Credit His Work
His Profile Is: www.instructables.com/member/Prof.+Pickle/
He Has Helped Me With The Large Problem I Was Having And I hank him Very Much
If You Have Always Wanted To Know The Codes For the Colours In Batch Files This Batch File Will Help You Greatly, My friend And I Made A Batch File To Help People Get The  Codes For Their Batch File Projects, This Is All My Coding so If You Wish To use It For Something Please Ask Me before You Do, I Will Almost definitely Say Yes But I Wish To Know What It Is Being Used For And Who Is Using It.
If There is Anything Wrong With It Or You want Me To Add Something To It Simply Tell Me in The Comments And I Probably Will
I Have Added All Of The Colours That I Know Of, I do Not Believe That there Are Any Other Colours But AS I Previously Stated If There Is Something to Add Simply Write It In The Comments And I will More Than Likely Add It.
First Things First You will Need To Open Up A New text Document (.txt) And copy And paste The Following Into It:
@echo off
color 0a
title Batch Colour Help, Using Batch
echo                         This Batch file Will Tell You What Letter Or Number Is the Code For The Colour You Would Like
echo       Obviously You Have To write color As The Batch file Code Before You can Type The Corresponding Letters And Numbers For The Colours
pause
cls
:start
cls
color 1a
echo                                                   Choose The respective Number For The Colour You Would Like
echo.
echo.
echo.
echo (1).............Black
echo.
echo (2).............Dark Blue
echo.
echo (3).............Dark Green
echo.
echo (4).............Dark Aqua
echo.
echo (5).............Dark Red
echo.
echo (6).............Dark Purple
echo.
echo (7).............Dark Yellow
echo.
echo (8).............Dark White
echo.
echo (9).............Grey
echo.
echo (10)............Bright Blue
echo.
echo (11)............Bright Green
echo.
echo (12)............Bright Aqua
echo.
echo (13)............Bright Red
echo.
echo (14)............Pink
echo.
echo (15)............Bright Yellow
echo.
echo (16)............Bright White
echo.
echo.
echo                                  !!Remember The First Number Or Letter (That Is The Code For A Colour)Is The Background Colour!!
echo                                              !!And The Second Number Or Letter Will Be The Text Colour!!
set input=
set /p input= Corresponding Number:
if %input%==1 goto black if NOT goto start
if %input%==2 goto db if NOT goto start
if %input%==3 goto dg if NOT goto start
if %input%==4 goto a if NOT goto start
if %input%==5 goto dr if NOT goto start
if %input%==6 goto dp if NOT goto start
if %input%==7 goto dy if NOT goto start
if %input%==8 goto dw if NOT goto start
if %input%==9 goto g if NOT goto start
if %input%==10 goto bb if NOT goto start
if %input%==11 goto bg if NOT goto start
if %input%==12 goto ba if NOT goto start
if %input%==13 goto br if NOT goto start
if %input%==14 goto p if NOT goto start
if %input%==15 goto by if NOT goto start
if %input%==16 goto bw if NOT goto start
exit
:black
cls
color f0
echo        BLACK
echo.
echo                                                            The Code For Black is:
echo.
echo        color 0
echo.
echo What Would You like To Do Now?
echo (1)...Go to Start
echo (enter)...Exit
set input=
set /p input= Choice:
if %input%==1 goto start
exit
:a
cls
color 03
echo        DARK AQUA
echo.
echo                                                             The Code For Aqua is:
echo.
echo        color 3
echo.
echo (enter)...Exit
set input=
exit
:db
cls
color 01
echo        DARK BLUE
echo.
echo                                                           The Code For Dark Blue is:
echo.
echo        color 1
echo.
echo (enter)...Exit
set input=
exit
:dg
cls
color 02
echo        DARK GREEN
echo.
echo                                                           The Code For Dark Green is:
echo.
echo        color 2
echo.
echo (enter)...Exitt
set input=
exit
:dp
cls
color 05
echo        DARK PURPLE
echo.
echo                                                           The Code For Dark purple is:
echo.
echo        color 5
echo (enter)...Exit
set input=
exit
:dr
cls
color 04
echo        DARK RED
echo.
echo                                                            The Code For Dark Red is:
echo.
echo        color 4
echo.
echo (enter)...Exit
set input=
exit
:dw
cls
color 07
echo        DARK WHITE
echo.
echo                                                              The Code For Dark White is:
echo.
echo        color 7
echo.
echo (enter)...Exit
set input=
exit
:dy
cls
color 06
echo        DARK YELLOW
echo.
echo                                                            The Code For Dark Yellow is:
echo.
echo        color 6
echo.
echo (enter)...Exit
set input=
exit
:g
cls
color 08
echo        GREY
echo.
echo                                                             The Code For grey is:
echo.
echo        color 8
echo.
echo (enter)...Exit
set input=
exit
:ba
cls
color 0b
echo        BRIGHT AQUA
echo                                                            The Code For Bright Aqua is:
echo        color b
echo.
echo (enter)...Exit
set input=
exit
:bb
cls
color 09
echo        BRIGHT BLUE
echo.
echo                                                            The Code For Bright Blue is:
echo.
echo        color 9
echo.
echo (enter)...Exit
set input=
exit
:bg
cls
color 0a
echo        BRIGHT GREEN
echo.
echo                                                            The Code For Bright Green is:
echo.
echo        color a
echo.
echo (enter)...Exit
set input=
exit
:br
cls
color 0c
echo        BRIGHT RED
echo.
echo                                                            The Code For Bright Red is:
echo.
echo        color c
echo.
echo (enter)...Exit
set input=
exit
:bw
cls
color 0f
echo        BRIGHT WHITE
echo.
echo                                                            The Code For Bright White  is:
echo.
echo        color f
echo.
echo (enter)...Exit
set input=
exit
:by
cls
color 0e
echo        BRIGHT YELLOW
echo.
echo                                                            The Code For Bright Yellow is:
echo.
echo        color e
echo.
echo (enter)...Exit
set input=
exit
:p
cls
color 0d
echo        PINK
echo.
echo                                                            The Code For Pink is:
echo.
echo        color d
echo.
echo (enter)...Exit
set input=
exit
If You Guys Have Any Problems/Bugs That You Find With My Batch File Or You Want Me To Make A Different Batch File Please Let Me Know In the Comments Or By Emailing Me At MidgetCoder@gmail.com
Thanks Guys Have A Good Day.
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    4 Comments
    Here is a batch file I like to call party.bat:
    @echo off
    mode con lines=20
    mode con cols=80
    goto start
    :start
    title PARTY
    cls
    color %a%%b%
    echo HI
    timeout /t 1 /nobreak>nul
    goto rand
    :rand
    cls
    setlocal ENABLEDELAYEDEXPANSION
    set /a r=%random% %%!15 +0
    if %r%==0 set b=0
    if %r%==1 set b=1
    if %r%==2 set b=2
    if %r%==3 set b=3
    if %r%==4 set b=4
    if %r%==5 set b=5
    if %r%==6 set b=6
    if %r%==7 set b=7
    if %r%==8 set b=8
    if %r%==9 set b=9
    if %r%==10 set b=a
    if %r%==11 set b=b
    if %r%==12 set b=c
    if %r%==13 set b=d
    if %r%==14 set b=e
    if %r%==15 set b=f
    goto rand2
    :rand2
    cls
    if %r%==0 set a=0
    if %r%==1 set a=1
    if %r%==2 set a=2
    if %r%==3 set a=3
    if %r%==4 set a=4
    if %r%==5 set a=5
    if %r%==6 set a=6
    if %r%==7 set a=7
    if %r%==8 set a=8
    if %r%==9 set a=9
    if %r%==10 set a=a
    if %r%==11 set a=b
    if %r%==12 set a=c
    if %r%==13 set a=d
    if %r%==14 set a=e
    if %r%==15 set a=f
    goto start
    Loving the Batch file thank you.
    That Does Work But My Program Is A Little Bit Of Fun For The User, That Is All
