Introduction: Batch Fake Virus/Hack Code
Picture of Batch Fake Virus/Hack Code
This is a tutorial on how to make a Batch Fake Virus/Hacking Code to scare your friends!
Step 1: Copy and Paste If You Are Too Lazy.
Picture of Copy and Paste If You Are Too Lazy.
If you just want the code to scare your friends and do not want to learn how it works, you can go ahead and copy it here and paste it into a New Text Document. (make sure to save the code as .bat NOT .txt)
How to make a Batch File (for windows):
  • Go to your desktop.
  • Right click the empty space.
  • Click/Hover over New.
  • Click Text Document.
  • Copy/Type in coding.
  • Click File.
  • Click Save As.
  • Change the file from .txt to .bat (ex. New Text Document ===> New Text Document.bat)
  • Click Save.
The code is here (copy all of it as it is, there is no changing required, the password in the initial asking is fakehack, which i will teach you how to change):
@echo off
title SecurityGuard v1.03
color C
echo SecurityGuard v1.03 enabled!
echo This program has been...
ping -n 2 127.0.0.1>nul
echo.
echo     _####_
echo    #      #
echo   #        #
echo   #        #
echo   #        #
echo  ############
echo #   LOCKED   #
echo #     ##     #
echo #    ####    #
echo #    ####    #
echo #     ##     #
echo #     ##     #
echo ##############
echo.
echo Enter password to activate the program...
set/p "pass=>"
if NOT %pass%== fakehack goto :incorrect_pass
if %pass%== fakehack goto :correct_pass</p><p>:correct_pass</p><p>cls
echo Password hidden...
echo PASSWORD CORRECT
color 97
cls
title svr_hack_var_aggressive.exe
echo Initializing svr_hack_var_aggressive.exe
tree C:/Windows/System32
echo Initializing Complete! Are you ready to continue enable Proxy Servers?
@echo off
:choice
set /P c=Are you sure you want to continue[Y/N]?
if /I "%c%" EQU "Y" goto :somewhere
if /I "%c%" EQU "N" goto :somewhere_else
goto :choice</p><p>:somewhere</p><p>cls
echo Proxy Servers enabling...
echo Proxy Servers 27%% enabled...
echo Proxy Servers 56%% enabled...
echo Proxy Servers 89%% enabled...
echo Proxy Servers have been enabled. Are you ready to enable software rooting?
@echo off
:choice
if /I "%c%" EQU "Y" goto :somewhere2
if /I "%c%" EQU "N" goto :somewhere_else2
goto :choice</p><p>:somewhere_else</p><p>echo svr_hack_var_aggressive.exe had been closed, exiting out of cmd...
exit</p><p>:somewhere2</p><p>echo Collecting files to root... (Warning, this process may take several minutes!)
@echo off
tree C:\
@echo off
:choice
set /P c=Are you sure you want to root all of the selected files?[Y/N]?
if /I "%c%" EQU "Y" goto :somewhere3
if /I "%c%" EQU "N" goto :somewhere_else3
goto :choice</p><p>:somewhere_else2</p><p>echo svr_hack_var_aggressive.exe had been closed, exiting out of cmd...
exit</p><p>:somewhere_else3</p><p>echo svr_hack_var_aggressive.exe had been closed, exiting out of cmd...
exit</p><p>:somewhere3</p><p>@echo off
cls
echo Rooting files... (Warning this process may take several minutes!)
echo File rooting has been completed.
goto :hardcore</p><p>:incorrect_pass</p><p>cls
echo PASSWORD INCORRECT: svr_hack_var_aggressive.exe has been closed, exiting out of cmd...
exit</p><p>:hardcore</p><p>@echo off
cls
echo Transfering user to passive mode...
title Passive
color B
echo svr_hack_var_aggressive.exe has been enabled...
echo Checking if svr_hack_var_aggressive.exe is running correctly...
cls
echo svr_hack_var_aggressive.exe has initialized
echo svr_hack_var_aggressive.exe has enabled Proxy servers
echo svr_hack_var_aggressive.exe has rooted files
cls
echo Removing traces of svr_hack_var_aggressive.exe in files...
tree C:/Windows/ADFS
cls
echo svr_hack_var_aggressive.exe has been removed...
echo cmd will be replaced in 3...
echo 2...
echo 1...
cls
echo ...
cls
start cmd
exit</p>
Step 2: Explanation of Code.
Picture of Explanation of Code.
I will be explaining what each and every bit of this code does, if you do not want to know how the code works and just want the code, go to Step 1, copy the code, and paste it into a batch file (which I explained how to make in Step 1).
@echo off stops the display of the commands
title changes the title of the command prompt
color changes the color of the text and/or the color of the background
echo displays a line of text
ping sends a amount of data to a IP and tests the response time (I use it for a delay in the coding)
set/p "pass=>" makes the next lines of coding password protected
if/if NOT %pass%== password goto :correct_pass sends the user to different paths of coding depending on if the user uses the correct password (you can change the "password" to any text for your password)
:correct_pass/:incorrect_pass/:somewhere etc... the paths of coding that the user takes depending on if the user chooses the correct/incorrect choice
set /p c= creates a yes or no question
if /I "%c%" EQU "Y/N" goto :example the paths of coding that the user takes depending on if the user chooses the correct/incorrect choice
exit closes the CMD
tree shows a directory map of certain drives/paths
goto :example goes to the path :example
cls clears all displayed text on the CMD
start/start CMD open a new CMD
>nul disables that line of code from showing in the CMD
seamster (author)2015-03-23
Interesting. Will this cause any longterm damage to one's computer? I'm completely unfamiliar with this sort of stuff.
yoyobebo (author)seamster2015-03-23
Here's the simple answer, no. This batch code will not harm your computer or others computers in any way. I did explain what all of the parts did in the second step if you want to know what each section does.
seamster (author)yoyobebo2015-03-23
Cool, thanks!
RandallH10 (author)2016-07-23
help me what is the password
andly654321 (author)RandallH102018-01-02
if NOT %pass%== fakehack goto :incorrect_pass if %pass%== fakehack goto :correct_pass
:correct_pass
cls
So the password is fakehack -> i think...
Ary_Mrlz (author)2016-03-23
when i enter the password it closes automatically, why is this?
yoyobebo (author)Ary_Mrlz2016-03-27
You must have typed in the password incorrectly, make sure the password that you type in is "falsehack" with no quotes (unless you have changed the password). Also the password in caps sensitive so you have to type it exactly how it is.
andly654321 (author)yoyobebo2018-01-02
wait...WHAT!?! I thought it was fakehack --> :O
BeatLyax (author)yoyobebo2016-07-02
this password didn't work for me
lllenderdudelllt (author)2016-06-12
Please can you make me a password software in this style,
Thx
Email me@ lllenderdudelll@gmail.com
what is password software? i think i can help...
BeatLyax (author)2016-07-02
check out the screenshot and help me please
andly654321 (author)BeatLyax2018-01-02
I think the right password is fakehack-- not falsehack:
:correct_pass
cls
JerryP57 (author)2016-08-15
whats the password
andly654321 (author)JerryP572018-01-02
The password it: fakehack --- because of the line:
:correct_pass
cls
andly654321 (author)2018-01-02
Make the color 02- makes it more virus-ish!
ooooommmmmbbbbb (author)2017-10-14
for mine every time type in anything it exits
royal killer. (author)2016-08-15
STEP 1: COPY AND PASTE IF YOU ARE TOO LAZY.
Copy and paste if you are too lazy.
Go to your desktop.
Click File.
Click Save As.
Click Save.
@echo off
color C
echo.
echo _####_
echo # #
echo # #
echo # #
echo # #
echo ############
echo # LOCKED #
echo # ## #
echo # #### #
echo # #### #
echo # ## #
echo # ## #
echo ##############
echo.
set/p "pass=>"
:correct_pass
cls
color 97
cls
@echo off
:choice
goto :choice
:somewhere
cls
@echo off
:choice
goto :choice
:somewhere_else
exit
:somewhere2
@echo off
tree C:\
@echo off
:choice
goto :choice
:somewhere_else2
exit
:somewhere_else3
exit
:somewhere3
@echo off
cls
goto :hardcore
:incorrect_pass
cls
exit
:hardcore
@echo off
cls
title Passive
color B
cls
cls
cls
echo 2...
echo 1...
cls
echo ...
cls
start cmd
exit
RickV34 (author)2016-08-13
@echo off
color C
echo.
echo _####_
echo # #
echo # #
echo # #
echo # #
echo ############
echo # LOCKED #
echo # ## #
echo # #### #
echo # #### #
echo # ## #
echo # ## #
echo ##############
echo.
color 97
cls
@echo off
:choice
@echo off
:choice
@echo off
tree C:\
@echo off
:choice
cls
cls
title Passive
color B
cls
cls
cls
echo 2...
echo 1...
cls
echo ...
cls
start cmd
exit</p>
This is without the password, working on it to fix pw!
About This Instructable
68,245views
15favorites
More by yoyobebo:Batch Fake Virus/Hack Code
Add instructable to:
