Batch File Calculator
Published
Introduction: Batch File Calculator
Hey Guys! marmig0404 here and i just wanted to share my home made simple arithmetic calculator.
Here is the code, just please don't copy and take it as your own. Thank you!
 @echo off
title Calculator
color 0a
echo Welcome to The Basic Arithmetic Calculator
echo Made By Martin Miglio
ping localhost -n 3 >nul
:LOADING
cls
echo Loading.
ping localhost -n 2 >nul
cls
echo Loading..
cls
echo Loading...
cls
echo Loading....
cls
echo Loading.....
color 0a
:START
cls
echo What Type of Math would you like to do?
echo Add, Subtract, Multiply, or Divide.
set /p math=
IF '%math%' == 'Add' GOTO ADD
IF '%math%' == 'add' GOTO ADD
IF '%math%' == 'Subtract' GOTO SUB
IF '%math%' == 'subtract' GOTO SUB
IF '%math%' == 'Multiply' GOTO MULTIPLY
IF '%math%' == 'multiply' GOTO MULTIPLY
IF '%math%' == 'Divide' GOTO DIVIDE
IF '%math%' == 'divide' GOTO DIVIDE
Exit
:ADD
Cls
GOTO NUMBERSADD
pause
exit
:SUB
Cls
GOTO NUMBERSSUB
pause
exit
:MULTIPLY
Cls
GOTO NUMBERSMULTIPLY
pause
exit
:DIVIDE
Cls
GOTO NUMBERSDIVIDE
pause
exit
:NUMBERSADD
echo What is the First Number you would like to Add?
set /p number1=
cls
echo What is the Second Number you would like to Add?
set /p number2=
cls
GOTO ADD2
exit
:NUMBERSSUB
echo What is the First Number you would like to Subtract?
set /p number1=
cls
echo What is the Second Number you would like to Subtract?
set /p number2=
cls
GOTO SUB2
exit
:NUMBERSMULTIPLY
echo What is the First Number you would like to Multiply?
set /p number1=
cls
echo What is the Second Number you would like to Multiply?
set /p number2=
cls
GOTO MULTIPLY2
exit
:NUMBERSDIVIDE
echo What is the First Number you would like to Divide?
set /p number1=
cls
echo What is the Second Number you would like to Divide?
set /p number2=
cls
GOTO DIVIDE2
exit
:ADD2
Set /A result = %number1% + %number2%
echo The answer is %result%.
Pause
GOTO START
exit
:SUB2
Set /A result = %number1% - %number2%
pause
GOTO START
exit
:MULTIPLY2
Set /A result = %number1% * %number2%
pause
GOTO START
exit
:DIVIDE2
Set /A result = %number1% / %number2%
pause
GOTO START
exit
Thats it!
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    13 Comments
    Ok, i like the idea, and i have also made a batch calculator of my own. But you see the issue with mine and all of yours. They don't do decimals, message me back if you would like to see my version, or come up with one so that it will do decimals. Thanks.
    here is my batch calculator way better than this hahhahah lol
    Please don't steal it and say it's your's
    ::start copy here
    @echo off
    color 0a
    :: sets
    set num1=
    set num2=
    set sum=
    set div= /
    :home
    title calculator made by andrey.
    cls
    echo welcome to my calculator
    echo.
    echo pick a choice
    echo.
    echo 1 ) plus
    echo 2 ) minus
    echo 3 ) times
    echo 4 ) division
    choice /c 1234 /n
    if %errorlevel% == 1 goto plus
    if %errorlevel% == 2 goto minus
    if %errorlevel% == 3 goto times
    if %errorlevel% == 4 goto div
    :plus
    title plus
    cls
    echo type your numbers
    set /p num1=numbers1:
    set /p num2=numbers2:
    set /a sum=%num1% +%num2%
    echo.
    echo %num1% plus %num2% sum = %sum%
    timeout 1 > null
    echo.
    echo press 1 to go back
    echo press 2 to continue
    choice /c 12 /n
    if %errorlevel% == 1 goto home
    if %errorlevel% == 2 goto plus
    :minus
    title minus
    cls
    set /a sum=%num1% -%num2%
    if sum==0 set sum= - 0
    echo.
    echo %num1% minus %num2% sum = %sum%
    timeout 1 > null
    echo.
    choice /c 12 /n
    :times
    title times
    cls
    set /a sum=%num1% *%num2%
    if %num1%==0 if %num2%==0 set sum= - 0
    echo.
    echo %num1% times %num2% sum = %sum%
    timeout 1 > null
    echo.
    choice /c 12 /n
    if %errorlevel% == 2 goto times
    :div
    title division
    cls
    set /a sum=%num1% / %num2%
    if %num1%==0 %num2%==0 set sum= - 0
    echo.
    echo %num1% divided by %num2% sum = %sum%
    timeout 1 > null
    echo.
    choice /c 12 /n
    lol idk why i share this.
    @echo off
    :again
    color a
    cls
    echo Type an equation.
    set /p x=
    echo %x%
    "%x%"="%x%" goto done
    :done
    color a
    cls
    Set /A result = %x%
    echo %result%
    timeout /t 5
    cls
    color 6
    echo 1:again
    echo 2:exit
    set /p op=
    if %op%== 1 goto again
    if %op%== 2 goto exit
    :exit
    exit
    this is bad because you can use:
    set /p sum=
    set /a ans=%sum%
    so you can use all the functions
    hey just wanted to share my own I am kind of a Newbee In batch programmingan here is a small as I can get the programm :
    @echo off
    mode con: cols=100 lines=20
    Title Basic 2 numbers operations
    :N
    echo *****Basic Calculator By Auto5k*****
    echo choose an operation {1=addition ;2=substraction ;3=multiplication ;4=division}
    echo to exit the program enter {5}
    set /p m=
    if %m%==1 set l=+
    if %m%==2 set l=-
    if %m%==3 set l=*
    if %m%==4 set l=/
    if %m%==5 GOTO E
    GOTO A
    :A
    set /p one=enter your first number
    set /p sec=enter your second number
    set /a rep=%one%%l%%sec%
    echo ****%rep%****
    pause
    GOTO N
    :E
    I made one myself. I like it. just copy and paste it and tell me if you like it or if it sucks.
    @echo off
    :start
    cls
    echo Welcome to Clown's official calculator Batch file.
    pause
    goto next
    :next
    cls
    echo Like this: 8 * 8 (replace * with the function you wish to use)
    set /p x=
    echo %x%
    :done
    cls
    Set /A result = %x%
    echo %result%
    pause
    exit
    This one is the most compact version of this calculator I could come up with:
    @echo off
    title calculator
    color 0a
    :1
    cls
    echo.
    echo ===========================
    echo claculator simplified
    echo.
    set /p num1= number 1:
    set /p ope= operation:
    set /p num2= number 2:
    if %ope%== + goto add
    if %ope%== - goto sub
    if %ope%== * goto mult
    if %ope%== / goto div
    goto 1
    :add
    cls
    set /a result = %num1% + %num2%
    echo %num1%%ope%%num2% = %result%
    pause
    goto 1
    :sub
    cls
    set /a result = %num1% - %num2%
    pause
    goto 1
    :mult
    cls
    set /a result = %num1% * %num2%
    pause
    goto 1
    :div
    cls
    set /a result = %num2% / %num2%
    pause
    goto 1
    here is a better one with history of calculations;
    @echo off
    title Calculator
    Cls
    color A
    echo.
    echo.
    echo = Start Calculator =
    echo.
    echo Press Any Key To Start...
    pause >nul
    echo.
    echo.
    echo ------------------------
    echo Welcome To Calculator!!!
    echo.
    echo _________
    echo Made
    echo By
    echo NinjaXMAt
    echo _________
    echo.
    echo.
    echo.
    echo.
    echo How To Use?
    echo For Calculator Type 1.
    echo Note ** You can only change colour before using calculator!!!
    echo Note ** To Reset, Press r once and hit enter after calculating digits!!!
    echo --Instructions--
    echo Enter Two or More Digits with Special Characters like;
    echo "+" For "Addition"
    echo "-" For "Subtraction"
    echo "*" For "Multiplication"
    echo "/" For "Division"
    echo For Calculator Colour, Type red,green or normal!!!
    :menus
    echo Directory: %CD%
    echo =========
    echo = Menus =
    echo =========
    echo Type;
    echo {1}
    echo {red}
    echo {green}
    echo {normal}
    set /P CMD=Enter Command:
    if "%CMD%" == "red" goto red
    if "%CMD%" == "green" goto green
    if "%CMD%" == "normal" goto normal
    if "%CMD%" == "Red" goto red
    if "%CMD%" == "Green" goto green
    if "%CMD%" == "Normal" goto normal
    if "%CMD%" == "r" goto Reset
    if "%CMD%" == "R" goto Reset
    if "%CMD%" == "%CMD%" goto 1
    %CMD%
    cd C:\
    goto menus
    :red
    color 0c
    goto menus
    :green
    color 0a
    goto menus
    :normal
    color 07
    goto menus
    :1
    echo Input Digit
    set /p Digit=
    set /a ans=%Digit%
    echo Digits Entered="%Digit%">>Log.txt
    echo Ans="%ans%">>Log.txt
    echo.
    echo Ans=%ans%
    set /p reset=
    if "%reset%"=="r" goto Reset
    goto 1
    :Reset
    Cls
    echo Input Digit
    set /p Digit=
    set /a ans=%Digit%
    echo.
    echo Ans=%ans%
    set /p reset=
    goto 1
    1.create a folder
    2. create another folder inside it
    3. create a shortcut of batch file
    4. put it outside of 2nd folder(in first folder)
    5. Launch It
    sorry steps 1-5 are done after pasting code and saving it as batch
    THIS IS A MUCH SIMPLER CALCULATOR
    @echo off
    title Batch Calculator by Thomas.R
    color 0d
    :top
    echo --------------------------------------------------------------
    echo Welcome to Batch Calculator by Thomas.R
    echo.
    set /p sum=
    set /a ans=%sum%
    echo.
    echo = %ans%
    pause
    cls
    echo Previous Answer: %ans%
    goto top
    pause
    exit
    This code is shorter:
    @echo off
    title calculator
    color 0a
    :calculator
    cls
    set /p a=The first number:
    set /p op=Operation:
    set /p b=The second number:
    set /a c=a%op%b
    echo The answer is %c%
    pause>nul
    goto calculator
    Thumb up for the effort, but this solution is terrible, even for a batch.
    Same thing, easier,faster, much less code, and you could calculate whole series of numbers:
    @ECHO OFF
    COLOR a
    TITLE Simple Batch Calculator
    :START
    CLS
    ECHO.
    ECHO. %RESULT%
    ECHO.
    SET/p input="Let's calculate this: "
    SET/a calc=%input%
    SET RESULT=%input%^=%calc%
    GOTO START^=%calc%
    GOTO START
    Before everything you could just create legend about functions...
