Batch File Legend Game OP
1,464
12
12
Posted in TechnologyComputers
Introduction: Batch File Legend Game OP
This is my OP version of the game legend
:: ::READ ME:: :: :::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::: :: ::This is the game Legend. Not everything is perfect. ::As the subject, ensure you have the word LEGEND. :: ::This Version Includes: ::-Character Name ::-Character Gender ::-Forest Fights ::-Arena Fights (Bosses, kill them to level up) ::-Random events in the forest ::-Several secrets (If you enter certain letters at menus, you may get some clues) ::-A new remade fight calculator ::-A new graphical technique, to show special characters (Lines, etc) ::-All options actually go places now in the town ::-The entire game is playable up to level 6 :: ::To run the game: ::Download the attached Legend.txt file. Open it in notepad (Just double click it). Click File>Save As... then ::pick a location. Change the "Save as Type" option from "Text Documents (*.txt)" to "All Files (*.*)". ::Now, name the file "Legend.bat" (Don't use the quotes. If you don't name it correctly, the game won't work.). ::Finally, just double click the file (It should look like a set of gears). The game will open! :: ::To Play: ::Just read carefully, and press the corresponding keys to do things. If you have this menu: :: ::'E'nter building ::'M'ove along ::Your Choice? [E,M] :: ::Press e to enter the building, and press m to move on. :: ::If you are given menus where you are asked to enter a number value, the game will only accept numbers in the ::format of 1 2 3 4 5 6 7 8 9 0. If you use text, the game will error and/or close. :: ::If you want to keep your progress, you must save before you exit. Otherwise, it will be reset to your last save. :: ::Enjoy! ::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::::
Step 1: Coding
sorry for that problem, if this doesn't work i will work on it in more detail
Step 2: Saving
once you have copied this into a notebook document go to save as. Save to your preferred spot. I use desktop and put them in a folder labeled "Batch Files" xX_IMPORTANT_Xx Save as Legend.bat. Notice that ".bat" on the end? if it is saved as a ".txt" document it will not work To do this click on the drop down arrow and select "all files." Encoding should be ANSI
Step 3: Playing the Game!
Go to where you saved it and double-click. press "E" to enter the realm, and press "B" to continue. Once in press "E" your first time and "L" the next time you want to play. The rest is self explanatory. Have Fun!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    12 Comments
    For everyone who saw this, version 1.0 official release is now available. Have fun!
    how did you make it so that when you hit the number/letter key you don't have to press enter?
    Use CHOICE. For example,
    CHOICE /c ABCD /n /m "The options are A, B, C, or D"
    if %errorlevel%==1 (echo A)
    if %errorlevel%==2 (echo B)
    if %errorlevel%==3 (echo C)
    if %errorlevel%==4 (echo D)
    BTW, Moodle, please do not remove my email from the READ ME section.
    -RCAP
    What do you mean? if I did I didn't mean to. if you figure it out please put it in the comments, that would be cool to put in other ones. Any way, it doesn't do that for me.
    my school admin blocked the cmd completely, so I can make more, but it will open and close super fast and say "the command prompt has been blocked by your administrator."
    Cool, reminds me of Wasteland.
    Vary cool, but next time it might be easier to attach a text document.
    i will do this soon, thanks for your advice
    hey I made it and it is just opening and closing really fast plz help
    Ummmm, u guess i need to attach a text document like supernoodle2014 said in a different comment. will do this ASAP
