Batch File Matrix + Explanation
Published
Introduction: Batch File Matrix + Explanation
About: I like to computer program. I like soccer.
Here is the code:
@echo off
:loop color 0a echo %random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random%%random% goto loop
It is a very simple code, but is a very cool neat trick.
  1. First, what you want to do is to copy the code
  2. Then paste it in notepad
  3. Click file then save as
  4. Name it: Matrix.bat
  5. Click where it says Text documents and change it to All Files
  6. Click Save
  7. Then open the file
Codes and their meanings:
@echo off :
@echo off just tells the computer to not show every thing that it would normally show in the file. You usually use it at the beginning of a batch file. (but not always)
cls:
cls just tells the computer to clear the screen.
echo:
echo is a way of saying something. Example:
@echo off
cls
echo Hi
pause
That would say "hi"
pause:
pause is not actually in the command for the matrix code, but since i used it in the example above, I should explain it. pause just stops the computer until the user tells it to go again.
%random%:
%random% just echos a random 5 digit number
:(anything of your choice):
The : command labels a part of your code. the goto command (below) goes along well with this command
goto:
goto means to go to a part of the code Example:
@echo off
cls
:label
echo Hi
goto label
In this example, the word hi would be repeated.
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
