This is a project i have been working on for a little wile..
it is made with vb.net 2008 and it makes making a batch simple for the newbies...
!!!!!!!!PLEASE NOTE!!!!!!!!!!!!!
THIS WILL ONLY WORK ON VISTA
it's because i made this on Vista now when i try it on an XP machine it comes up with an error message.. sorry people.
I have to thank TATcreator because even know he doesn't know it he gave me the idea to make this .. lol.
Make sure you look at the First step 'installation' before downloading!!!!
I really hope you like it..
and if you find any problems with it please leave a comment or pm me so i can fix them and repost it...
please comment on what you think to and don't forget to rate it =)
MakeABatch.exe63 KB
Remove these ads by
Signing UpStep 1Installation
1) Follow pic 1 if you just get a page with alot of text when you click on the link
2)Click save
3) Make sure you get all the red bits right!!!
Save as .exe And Make sure you save as 'All Files' or it will not work!!!!!
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentOutOfRangeException: InvalidArgument=Value of '-1' is not valid for 'index'.
Parameter name: index
at System.Windows.Forms.ListBox.ObjectCollection.Insert(Int32 index, Object item)
at MakeABatch.Start.ListBox1_MouseDoubleClick(Object sender, MouseEventArgs e)
at System.Windows.Forms.Control.OnMouseDoubleClick(MouseEventArgs e)
at System.Windows.Forms.ListBox.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MakeABatch
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Bob/My%20Documents/Will%60s%20files/MakeABatch.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.1433 (REDBITS.050727-1400)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
* VB.NET: heaven knows why... but see http://msdn.microsoft.com/en-us/library/2k7ayc03%28v=VS.80%29.aspx anyway.
* In C, it was pointer-array equivalence. In C, array[index] == *(array + index). So the first element had to be element 0 or you lost space equal to the size of the type held by the array, and back in 1972 that was a Bad Thing.
* C++ and C# desired backwards compatibility with C. See above.
On the other hand, several languages index from 1, and one (I think) indexed from a programmer-specified positive integer. Either way, accessing negatively-indexed array items is Not A Good Idea.
Download it here: http://www.microsoft.com/downloads/details.aspx?familyid=0856eacb-4362-4b0d-8edd-aab15c5e04f5&displaylang=en
